09-08-2019, 01:35 PM | #14851 |
Rep 2
Correct software and files
Hello all,
I have downloaded these below to code my 16 428 GC. I am mainly looking for seatbelt chime disable and initial idrive warning disable to start with. Is this all need below or do i need an updated version? Thanks in advance. Psdz data 4.18.33 Esys 3.27.1 |
09-08-2019, 01:51 PM | #14852 | |
Rep 40,786
09-10-2019, 08:55 AM | #14855 |
Rep 40,786
PM sent.
myszano118.50 |
09-15-2019, 08:39 AM | #14857 |
Rep 40,786
PM sent.
robert4u1.50 |
09-15-2019, 11:46 AM | #14858 |
Rep 16
I used bimmercode to code my tailgate for closing from the button in footwell and close without long press on key fob and it effected my soft close mechanism. All coded functions worked but boot lit slams when closing instead of slowing down when nearly closed and sucking in.
I reverted coding with bimmer code but still slams when closing however it does slow down when opening. Couple of questions as E-sys is new to me. Is there a way to basically reset the all HKFM to what it was before bimmercode? Do I need Launcher to do it? Or maybe I'm looking at this issue incorrectly and need to start elsewhere? I tried re-initialisation of boot lit with ISTA and still the same and no faults shown. |
09-15-2019, 11:49 AM | #14859 | |
Rep 40,786
09-15-2019, 12:00 PM | #14860 |
Rep 16
09-15-2019, 12:03 PM | #14861 |
Rep 40,786
VO Coding Guide is included in E-Sys Coding package. PM sent.
09-15-2019, 01:34 PM | #14863 |
Rep 40,786
PM sent.
09-15-2019, 02:15 PM | #14864 | |
Rep 16
I believe I've done it. Saved the FA file, calculated FP etc, wrote it in VCM Master, then went to Coding, Read SVT and Coded HKFM. All successful as far as I could see. But the boot lid still slams when closing... |
09-15-2019, 02:30 PM | #14865 |
Rep 40,786
Then issue is not a coding issue.
09-16-2019, 04:43 AM | #14867 |
Rep 40,786
09-16-2019, 07:06 AM | #14868 |
Rep 8
Cannot edit E-Sys data
I'm using the following:
E-Sys Version 3.33.0 (build 53640) - 2018-09-18 PSdZ Version 5.07.01-2018-09-17T14:25:05Z Code AwayDKF01.est PSDzData Extracted from ISTA version 4.19.21 Everything works OK except for when I edit the codes I get the error: An error occurred while processing the EST file "C:\Data\EST\Code AwayDKF01.est". See details for more information. [C157] Not sure what I'm doing wrong? |
09-16-2019, 07:18 AM | #14869 | |
Rep 40,786
Why aren't you using E-Sys Launcher instead, which is .EST Token Solution, CAFD Mapping,and Cheat Sheets all-in-one?
09-16-2019, 11:05 AM | #14870 |
Rep 42
Hi Shawn,
Can you please send me the links for the latest files (programs and data)? Cars are 2015 F30 320d and 2016 F30 LCI 330e. Many thanks in advance. Cheers, Col. |
09-16-2019, 12:03 PM | #14871 |
Rep 40,786
PM sent.
09-16-2019, 02:38 PM | #14872 |
Rep 47
What connection Target do I need to select for F31? Same as F30?
https://cdn.bimmerpost.com/forums/at...1&d=1483291144 |
