12-16-2021, 07:16 AM | #1 |
Rep 56
Average Battery Life?
Average Battery Lifetime?
I'm wondering what the average battery life most have found with their F30. My 2013 F30, N26 xDrive still has the original battery with a date of Oct 2012. Is 10 years about average? I guess the Intelligent Battery System does optimize performance! |
12-16-2021, 08:33 AM | #2 |
Rep 16,088
8 years would probably be average, with a lot depending on climate and driving habits. Batteries don't care for either very hot or very cold conditions. Lots of short trips are harder on them than fewer long trips. Auto start/stop reduces battery life. BMW batteries are oversized to handle auto stop/start demands, so if you don't use ASS that over sizing results in longer than average battery life.
12-16-2021, 09:20 AM | #3 | |
Rep 56
12-18-2021, 09:47 PM | #5 |
OG Tray Deee
82
Rep 261
I recently replaced the battery a couple of days ago at the dealer. My car is a 2016. I’m sure I could have rode it out a couple more years but decided to just replace and forget about it.
12-26-2021, 10:52 AM | #7 |
Rep 183
I Just replaced my AGM battery, it had 7years. It was working fine but wasn't able to reach the max CCA when fully charged (around 500 / 850CCA). Last winter I had 4 or 5 battery warnings. I've changed it more as a prevention rather than to wait to be stuck in the middle of nowhere
02-04-2022, 11:30 PM | #9 |
Rep 1,582
I just checked in ISTA my F30 2012 battery, and it has an average of 76% (capacity? -> last 5 charges). Bought the car when it was 1.5 years old and apparently (based on ISTA) this is the original battery, so 10 years old. Car is/was garaged in moderate climate.
I guess the BMW smart battery-charging system works quite well. |
02-05-2022, 01:40 AM | #10 |
Rep 420
'14 F30 in NYC non garaged and mine has been fine though I'll get a readout to see the remaining capacity, haven't gotten any battery warnings ever since owning the car but I don't do much short distances but will probably just pick up a new battery this year as it's done me justice don't want to get stranded with it
sspade2466.00 |
02-08-2022, 07:08 AM | #11 |
Rep 352
My car is a 2017 and my battery began causing some electric gremlins in my car (e.g. stop start not working, random errors on the dashboard). The battery was not holding sufficient charge. Changed it, all problems went away
02-12-2022, 02:43 PM | #12 |
Rep 10,256
Two data points.
2017 440i GC: battery replaced by the dealer shortly before expiration of 4 year warranty 2015 X5: battery replaced at exactly 7 year mark as expected for AGM battery |
02-15-2022, 04:52 AM | #13 |
Rep 172
Drives: 2015 328i
2015 with original battery still. Hot Italian weather and now cold German weather. Plenty start/stop. I am pretty happy with the life.
02-15-2022, 12:28 PM | #14 | |
Rep 562
Drives: 2017 BMW 330i xDrive
Things that will prolong battery life: Garage kept (less dramatic temperature swings), using a trickle charger when parked unused for more than a couple of days, disable auto stop/start, reducing short trips (<15m), being careful not to drain the battery by repeatedly opening doors and leaving them open with the car off over several hours, etc.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
fe7565552.50 |
03-10-2022, 02:46 AM | #17 |
Rep 69
Drives: 2013 F13 M6, 2013 F30 328i
Mine since 2013 til now still working good, urban driving style with at least 30m each trip, Daytime running light - OFF, Auto Headlamp - OFF
03-13-2022, 10:56 AM | #18 |
Rep 27
I just replaced my 2013's original battery. It was giving signs it was time for replacement. Stop Start which I usually turn off was not working and iDrive crashed a few times.
Used BimmerLink to register new battery. Only issue was BimmerLink / BimmerCode didn't have option for 95 Ah replacement (original BMW 90 Ah). |
04-04-2022, 09:49 AM | #20 |
Rep 75
2014 335i, just replaced the battery 2 weeks ago. Autozone Duralast Gold. We'll see how well it holds up. My battery was the original. Began to have labored starts and random iDrive crashes. Replaced and all is well. 7-8 years certainly does seem to be the norm for these AGM batteries. Garage kept, no big temperature swings here in Seattle area. No short trips. (mostly because I don't want condensation in the oil system, but seems to help the battery as well. Girlfriend thinks I'm nuts. lol)
I noticed in Bimmerlink, that when I first got the new battery and registered it, it said 84%. After having it installed for the past 2+ weeks, it now says 94%.
2014 335i - BM3 Stage 2+ Race Gas, VRSF Catless DP, Race IC, CP, Muffler Delete, xHP Stage 3, NGK 97506, Eldor Coils, Turner Motorsport intake with BMS filter, BMS Oil Catch Can, Red Line fluids.
fe7565552.50 |
