08-09-2023, 10:09 AM | #46 |
Rep 35
I have a 2016 340i and just hit 50,000 miles. Drive it 6 days per week and it is still the original battery that came from the factory.
I am starting to get "battery discharged. Start engine" message. Some times it will not turn over on the first try and I have to hit the Start button for a second time before the car comes to life. I assume this means the battery is on its way out and I just need to get a new battery. Anything else I should be paying attention to? |
08-09-2023, 10:30 AM | #47 | |
Rep 1,582
When you replace the battery, make sure you get the same type and close to the OEM capacity. You can go over/under by 5 or so percents. But you also need to register the new battery with the correct capacity in order to get optimal charging, and to avert under-charging which will cause errors again.
08-09-2023, 10:35 AM | #48 | |
Rep 35
08-09-2023, 10:50 AM | #49 | |
Rep 1,582
Most car diagnostics phone apps (need a wireless dongle) like Bimmercode, Bimmerlink, Carly, etc can register the battery. An ELM327 Bluetooth that works (for me) with Bimmercode is about $3 on EBay. Compatible battery from Walmart is about $140-$170-$220.
08-09-2023, 11:03 AM | #50 | |
Rep 35
08-09-2023, 11:48 AM | #51 |
Rep 16,088
You should. Or do you enjoy paying a dealer $150 or more to read error codes when you can do it yourself with a code reader app? You don't necessarily need a unit like a Foxwell NT 510, but knowing that a dealer would charge me at least $100 to register a battery convinced me to buy one long before I'd need it for that job. It paid for itself the first time I used it to pull codes.
alohasurftoad3081.50 |
08-09-2023, 12:31 PM | #52 |
Rep 4,333
$170 @ costco
https://costco.interstatebatteries.c...185&Country=US on amazon, there are numerous bmw obd scanners in a variety of price ranges that increase with functionality. just be sure it can do a battery registration. i have an autophix, which is a foxwell knock off. many also use mobile phone apps such as bimmercode |
08-09-2023, 03:18 PM | #53 |
Rep 16,088
I have the bimmer-tool Lite app. It won't do battery registration, but it does a lot, including some things that my Foxwell won't. Bimmercode is a must IMO, but it only does coding. Bimmerlink does code reading and battery registration.
08-10-2023, 09:34 PM | #54 | |
Rep 35
08-11-2023, 05:34 PM | #55 | |
Rep 56
08-12-2023, 10:59 AM | #56 | |
Rep 35
If so, what voltage am I looking for to comfirm/deny it is an alternator issue? |
08-12-2023, 12:36 PM | #57 | |
Rep 35
I think this is telling me the battery is indeed bad (not the alternator) and I just need a new battery. Or am I getting this wrong? Here is a video I took of what is happening: Last edited by chollz; 08-12-2023 at 12:37 PM.. Reason: fix video embed |
pobrienny51.00 |
08-12-2023, 12:59 PM | #58 |
Rep 16,088
What it's telling you is that when the starter engages it sucks a lot of voltage, so much that other applications including the dash read out don't get their normal allotment. That's perfectly normal. What's not normal is reading 11.6v when you switch on the ignition. That could be the battery, but also could be parasitic power drain. If you charge the battery to at least 12.5 v, disconnect the negative terminal and measure more than a 0.3 volt loss overnight the battery is suspect. You have to measure it with a meter at the battery, otherwise if there's a parasitic drain it will start sucking away voltage as soon as you reattach the negative terminal.
pobrienny51.00 |
08-12-2023, 01:05 PM | #59 | |
Rep 35
08-12-2023, 08:05 PM | #60 |
Rep 54
So you can go to orielly auto and buy a battery for about 250 for a p/n 49PLT battery (AGM) install it in the parking lot and use the OBD scanner the store uses for check engine lights and register your battery right there
Boom done! |
08-13-2023, 10:35 AM | #61 | |
Rep 35
But I did watch another video on YouTube that says if your battery drops under 10V during ignition (which mine does), your battery is bad. I am thinking that is the case and I do not have a parasitic drain issue. It would make sense as this is the battery that came with the car. Its a 2016 MY and now its 2023 so it would make sense the battery could be bad by now. Here is the video I found on YouTube leading me to believe it is a bad battery. (it should start at the point where he starts talking about voltage drop during ignition, but if it doesn't forward to about 1:40) |
08-13-2023, 01:20 PM | #64 |
Rep 35
08-14-2023, 10:27 AM | #66 |
Rep 35
Replaced my battery. Coded and registered w/ BimmerCode and BimmerLink. All errors have gone away and is starting up immediately as expected. Seems it was just a bad battery. Thanks all for your input. Hope these posts and videos of my car can help someone later down the line...
