BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Headlight Leveling Sensor Issues
proTUNING Freaks
      11-24-2022, 08:31 AM   #1
mazen222
Drives: BMW 435i
My headlights started intermittently aiming very high (45 degrees) when i turn it on.
It start at neutral level and then start moving up slowly 1 inch at a time and stops super high, blinding everyone.
This does not happen all the time, just randomly here and there.
If I switch them off and back on, it sometimes stays where its supposed to.
Any ideas on how to fix this? Should I just buy a new sensor or is there perhaps a lub or adjustment to be made?
I've only found posts with issues like this by people who modified their suspension or headlights...
https://f30.bimmerpost.com/forums/sh....php?t=1777136
Anyone had this issue before?
Thansk for your help!
Maz
      02-11-2024, 05:28 PM   #2
da.sz01
Drives: 2016 F36 420d
2016 BMW 420d f36  [0.00]
BMW 420d f36  [0.00]
Hi mate, bit late to the party but I'm having the same issue in my f36. Have you resolved this? If so could you say what it was.
My suspicion is on the headlight level sensor as it's threw up codes several times now. The issue being my rear left senor ( UK passenger) so if anyone would have the parts number as there are 2 listed for it, it would be highly appreciated.
Thanks in advance
      02-11-2024, 11:11 PM   #3
mazen222
Drives: BMW 435i
Yea it was the sensor. It was loose. They bolted it back and it’s all good now
