05-20-2015, 08:51 AM | #1 |
Rep 69
Wheel bolts were loose... ?
After changing to 20" rims from stock, the guys that put on my wheels asked if the new rims needed any special/different wheel bolts other than stock.. i said i dont know so they just put the wheels on using the standard wheel bolts and told me to check the bolts in a couple days. So today is a couple days and all the bolts on all 4 wheels were loose.. how do i know what wheel bolts too use?
05-20-2015, 08:57 AM | #2 |
208
Rep 1,161
There are a couple of different kinds of bolt head shapes. You should check to see that the wheels you put on have the same shaped journals as the wheels that you took off. If not, you'll need to get new hardware. The mechanic probably should have noticed if the hardware was incorrect...
05-20-2015, 12:17 PM | #4 |
Rep 713
Talk to whomever you purchased your wheels from and ask them. Most aftermarket wheels use the same taper as stock BMW wheels, 60 degrees.
The other thing to consider is that the shop may not have torqued the wheels properly to begin with.
05-23-2015, 05:38 PM | #7 |
Rep 320
You should have roughly 7 full turns of the lug bolts to tighten. Depending on the offset of the wheel, you may need longer bolus to achieve this. As other have mentioned there are two lug options: conical and ball. Be sure your wheels match the seat of your lugs. If you are not using the correct shaped bolt you will have notably less surface area to seat agains.
Hope this helps! Mike |
05-24-2015, 02:39 AM | #9 |
Rep 766
Im betting the shop just impact gunned the lugs on and sent you on your way and they just werent torqued properly.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
05-24-2015, 08:03 AM | #10 |
Rep 69
05-24-2015, 10:26 AM | #11 | |
Rep 5,316
Drives: G80 M3 6MT
I use the BMW jack kit pretorqued wrench to tighten my lugs and haven't had an issue.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
