BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > DIY N55 Spark Plug Change
      11-17-2016, 05:38 AM   #45
Polo08816
Drives: 2014 335i M Sport
Originally Posted by harkes View Post
Polo08816
Awesome - thanks!
Now that you are at it... Can you help with the 22 11 xxx specs also? Then my guide is complete
Let me know what you're trying to accomplish. ISTA's search feature isn't that robust. It's much easier if I know what you're trying to do that involves that torque spec specifically.
      11-17-2016, 12:54 PM   #46
zcspec
zcspec's Avatar
212
Drives: 911/Boxster/Model Y
What's the consensus on running colder plugs on a 14' 335i N55 with the following:
- JB4 running Map 2 or 5
- FOB
- e30 blend
Thanks in advance!
      11-17-2016, 01:38 PM   #47
R32DBP
Drives: 2014 335i M Sport, 2004 .:R32T
I'm running the latest N20 plugs on my FBO 14 335i. Well almost FBO, I'm just missing the FMIC. When you start hitting high boost, the stock plugs tend to misfire so since you have JB4 I'd recommend going to the N20 plugs.
      11-18-2016, 09:49 PM   #48
harkes
harkes's Avatar
China
1077
Drives: M135i, E39 M5, NSX and AE86
ahhh ok. it's the specs for the engine mount. use it for changing the Pure Stg2.
      11-20-2016, 12:02 PM   #49
Polo08816
Hopefully this helps...
      11-20-2016, 12:43 PM   #50
zcspec
zcspec's Avatar
212
Thanks! I'll read up a bit more because I know plugs can make a difference on ours/any boosted car.
      11-20-2016, 07:42 PM   #51
harkes
harkes's Avatar
China
1077
I am running +20psi on stock N55 plugs - no issues.
Is it due to boost, combustion temps or octane that different plugs are needed? I know that higher octane combust slower so maybe also more difficult to ignite?
(A Dane in China)
      12-29-2016, 01:36 AM   #52
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Maybe I missed it - how long did this take you to complete the plug change, and did you happen to have a link to the correct thin wall socket to use? Thanks a lot.
Helpful DIY
      12-29-2016, 05:05 PM   #53
_bdiddyb_
Drives: 2013 335i
Helpful DIY
I took about 1 hour and 1/2.
https://www.turnermotorsport.com/p-3...cket-38-drive/
      12-29-2016, 08:08 PM   #54
CntryClub007
490
Helpful DIY
Thanks a lot,
      12-30-2016, 01:57 PM   #55
Polo08816
This.
      05-03-2017, 06:08 AM   #56
projector
Drives: 2014 BMW 328i
http://www.realoem.com/bmw/enUS/show...diagId=51_8381
I believe it's under "vehicle trim" and then "3' F30 335i Reinforcement for body, front". It took me a while to find it.
02 Torx screw with collar ASA M10X20 4 07147270121
Would this fit for the N20 engine as well?
      06-22-2017, 03:04 PM   #57
zcspec
zcspec's Avatar
212
I changed my N55's plugs last night. Thank you to the pioneers who provided DIY info as it was a tremendous help. I ended up using NGK 97506 2-Step Colder Spark Plug, gapped to .020.
Total time to replace all 6 plugs: 1 1/2hrs. Afterwards, I warmed up the car and performed a test drive. It felt like a freight train boosting 16-19lbs. Logs looked great too!
Polo088161610.00
      09-19-2017, 08:05 AM   #58
RaceleaderQC
RaceleaderQC's Avatar
Drives: BMW X3e 30i M-Sport 2023
Quick question guys.
My dealer told me my spark plugs are due in 2000 km. I am planning on replacing them my self but need to know if there is something we must do on the ECU to reset the counter ?
      09-19-2017, 08:53 AM   #59
Orion4
Nope
      10-23-2018, 11:10 AM   #60
integuy98
Drives: 2013 F10 535i
Just an FYI I was able to find the BMW Torx Screw with Collar on amazon, priced well with free shipping if you have amazon prime.
http://a.co/d/6cd1gWr
Also, I got my spark plugs from ebay for way cheap. 6 for $26 shipped. I've received them and they look genuine.
      10-24-2018, 08:07 AM   #61
harkes
harkes's Avatar
China
1077
Remove the strut bar??? Why the hell would you do that?!
(A Dane in China)
      10-25-2018, 12:37 AM   #62
TK335iMSPT
TK335iMSPT's Avatar
Drives: F30 335ixdrive M Sport
Hello everyone! I just did my plugs over the weekend. I tightened the last three to spec but felt it wasn't tight enough so I loosened them and re tightened. After doing the plugs I am getting a gas smell through the vents at idle. The front three are torqued to 17ftlbs but it felt like it wasn't tight at all. The car runs fine but just has the smell at idle. Could the smell be from undoing the already tightened plugs and re tightening them? Or from the front three that I felt weren't tight enough?
      10-26-2018, 11:50 AM   #63
dvaz
Drives: 2015 E84 X1
Whats the PITA factor? I have always worked on 4 bangers Hondas so they were ez-pz ( except my 2017 WRX, that was 11/10 PITA )
Looks simple enough, just taking bunch of stuff out of the way. The strut tho.. why?
      10-26-2018, 11:56 AM   #64
jh_f30
jh_f30's Avatar
1306
Drives: 2013 335i Sportline Auto RWD
The last couple cylinders are set pretty far back in the engine bay, especially compared to a Honda where things are pretty much all front and center. There's not a lot of room to work back there. I did mine without removing the strutbar, but it did involve a bit of finagling.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      10-27-2018, 09:09 AM   #65
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://www.newtis.info/tisv2/a/en/f...-plugs/5rctKot
Double check the torque spec for your plugs?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      10-27-2018, 11:16 AM   #66
Orion4
Torque spec for his 335 N55 is 23 nm or 16.96 ftlbs. If all plugs are torqued to spec AND his torque wrench is in cal, appears something else is causing the odor.
