11-04-2014, 06:24 PM | #1 |
Rep 3
2013 N55 Exhaust question
Hey Guys,
I'm new to the forum, but I bought my 2013 135is last year in San Diego, California. I now live in Minneapolis, Minnesota, so I was wondering if California standards make car companies add extra cat's or mufflers that don't necessarily need to be there in the rest of the country, that would be ok to remove? Also, the car is on a lease, so I was wondering if anyone else has swapped out the stock exhaust for something with a little nicer sound that didn't mess with the warranty. Any info would be appreciated. Thanks Guys!! |
11-04-2014, 06:36 PM | #2 |
European Editor
10512
Rep 22,992
Your "iS" should already have a Performance Exhaust(PE). It's one of the sweetest sounding exhaust out there! Doesn't your exhaust pop and gargle? ???
Dack
11-04-2014, 06:43 PM | #3 |
Rep 3
I do love the sound of it, but I guess I'm getting a little greedy and wanting a little more. I did do the "golf tee" mod, by just unplugging the sensor in the trunk, but I was just wondering if anyone was doing anything differently.
11-04-2014, 06:46 PM | #4 |
European Editor
10512
Rep 22,992
You could get a down-pipe if you want to go catless. But then technically you'd fail any emission test. I would get a high flow cat, like what AR sells. ~$800, it would make the exhaust sound even meaner. Read: LOUD!
11-04-2014, 07:51 PM | #6 |
Rep 964
Drives: BMW 135is | #341/586
OP, you shouldn't mess with perfection.... BMW spent millions perfecting your 135is's PE and PPK's snap, pop and burble in a secret underground German laboratory. If you think a backyard garage fabricator can make a better sound please give your PE to the nearest 1er forum member.
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler |
11-05-2014, 09:30 AM | #7 |
Absorbing
Rep 58
Congrats on joining the "is" club. I beleive the PE to be the best sounding exhaust as far as sound "roundness" goes. What did you think of the results of the "golf tee" mod? I was aware of the mod for the non PE systems, but didn't know there was one for ours. Disconnect some sort of actuator?
/// Leonidas: 13' 135is #98/586, 6MT M-Sport, Space Gray, Terra Cotta, Harmon and Kardon, MPSS 225/255
11-05-2014, 09:47 AM | #8 |
Rep 893
Drives: 135is :) 192/586
Correct me if I am wrong but isn't the golf tee supposed to keep the exhaust flaps open at all times? With that said, doesn't the US version of the BMW PE not have said flaps = the golf tee mod is pointless.
11-05-2014, 09:58 AM | #9 |
Absorbing
Rep 58
That's what I was thinking. I know my exhaust sounds pretty mean at startup, I like it, but it quiets down after about 30 seconds. I am pretty sure this is a result of the valve timing and overlap. Anybody have some input?
11-05-2014, 06:58 PM | #10 | |
European Editor
10512
Rep 22,992
stock 135i exhaust left, PE right.
11-06-2014, 10:14 PM | #12 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Neither does the US one
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
11-09-2014, 11:42 AM | #14 | |
Absorbing
Rep 58
11-10-2014, 01:33 PM | #15 |
BMW Master Tech
587
Rep 850
Also why it's easier to get it to backfire when the engine is cold.
135is #502 of 586
exhaust, n55 |
