04-19-2014, 12:05 PM | #6315 | |
Rep 41,101
My File Hoster takes donations though...
04-19-2014, 09:37 PM | #6316 |
Rep 204
Can you send me the links as well? Much appreciated!
2014 328d MSport ED: 5/2/2014 2013 F30 Activehybrid3 MSport (Gone) 2012 F30 328i Sportline (Gone) |
04-19-2014, 10:29 PM | #6317 |
Rep 41,101
04-19-2014, 10:57 PM | #6318 |
Rep 29
Mirrors open on unlock for keyfob?
Hi guys,
First of all, awesome thread!! I got mirrors and windows closing fine with keyfob, but can't get mirrors to open during unlock, but I can still open windows and sunroof when holding down unlock button. Is it even possible for mirrors to open with one click unlock? So far I coded the following for opening: KOMFORTSCHLIESSUNG_FB aktiv werte 01 ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN aktiv werte = 01 Also, I can't find the unlock all doors, when turning car off? Does anyone already have this one? Thank you for any help!! |
04-19-2014, 11:09 PM | #6319 | |
Rep 41,101
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK
04-19-2014, 11:18 PM | #6320 | |
Rep 29
I will try the mirror one the next chance I get. But for unlocking the doors, I found that code in a previous thread somewhere, and it said 3002CLM was CAS, but I dont have the CAS Module. Is it named differently on the F30? |
04-19-2014, 11:23 PM | #6321 | |
Rep 41,101
04-19-2014, 11:29 PM | #6322 |
Rep 29
04-19-2014, 11:31 PM | #6323 | |
Rep 41,101
I don't have anything newer. Sorry.
04-20-2014, 07:15 AM | #6325 | |
Rep 32,881
04-20-2014, 10:46 AM | #6326 |
Rep 23
04-20-2014, 10:57 AM | #6327 |
Rep 32,881
Yes bus nav from March has BT streaming, album art, full voice control & can connect iphone/ipod with standard Apple cable. Plus you can code EBT if you want office and 2 phones connected for calls.
04-20-2014, 12:09 PM | #6328 |
Rep 23
I am disappointed as I wanted to to coding for these two things and it comes up that I don't need coding for them
04-20-2014, 04:09 PM | #6329 |
Rep 11
Drives: M235i F23
Hi please could send me the links for latest E-sys, PSdZData and the new Patch / Token
March 2014 F21 M135i Thanks
M235i F23
Mini Cooper Roadster Porsche 944 2.7 |
04-20-2014, 04:26 PM | #6330 |
Rep 41,101
PM sent.
04-21-2014, 09:26 AM | #6331 |
Rep 204
04-21-2014, 11:38 AM | #6332 |
Rep 39
Hi Shawn
Please could you send me the links for latest E-sys, PSdZData and the new Patch / Token and all the stuff? It will work with Icom A2 clone ,"native" install under Win XP , IBM X200 using IToolRadar?I don't wanna "damage" ista....For coding is enough 60A external power source? Do you know if VO alignement with ista/p is the same with VO coding with E-sys?My car F30 F020-13-03-503... Thanks and respect!!! |
04-21-2014, 11:41 AM | #6333 |
Rep 41,101
PM sent.
You can use it with ICOM, but there is no reason to, and ENET is far simpler. For coding, you can simply run the Engine, and you can code all ECU's except DME / DDE without using a charger. If you must use a charger, 60 Amps should be fine. VO Alignment and VO Coding are the same thing.
04-21-2014, 11:46 AM | #6334 |
Rep 14
I retrofitted LED fog lights and coded this
NSW_L_DUALSP_aktiv NSW_L_KALTUEBERWACHUNG » nicht_aktiv NSW_L_WARMUEBERWACHUNG » nicht_aktiv NSW_L_KURZSCHLUSS » nicht_aktiv NSW_L_IS_LED » aktiv NSW_R_DUALSP_aktiv NSW_R_KALTUEBERWACHUNG » nicht_aktiv NSW_R_WARMUEBERWACHUNG » nicht_aktiv NSW_R_KURZSCHLUSS » nicht_aktiv NSW_R_IS_LED » aktiv but after few turn-ons they started flickering. What shall I do to improve it? |
04-21-2014, 11:48 AM | #6335 | |
Rep 39
