10-28-2015, 04:20 PM | #23 |
Rep 68
Understood... I think I'd rather stick with a more reliable baseline test, however. These guys didnt even know how to open the hood of my car, and I had to explain to them to put the car in sport mode, etc. Want to start with a BMW tuner. Should have done more research first.
2012 E93 M3 Convertible - BMW Individual - Azurite Black Metallic/Rust Brown - MPE - Dinan Software and Intake
10-28-2015, 06:07 PM | #24 | |
Rep 242
Anyway, it's something you can do to satisfy your curiosity after getting another dyno with current mods. |
10-28-2015, 06:19 PM | #25 | |
Moon Parasite
654
Rep 1,336
A baseline on my STS-V came into play after the dealership worked on the car and screwed up my supercharger bleed off calibration. Driving it back I could feel the car was weaker. Took it back to the same dyno to check and it was down 60whp. I tried to be nice and give it back to them to check out telling them something didn't feel right power wise. They kept it a day and gave it back saying "everything is fine, it even squeals the tires" So I told them I was going to take it back to the dyno and have three pulls done on the car, and if it wasn't within 20hp of the baseline I was bringing it back to actually be fixed and they were going to re-reimburse me for the dyno cost because I provided them the opportunity to check the car and they said it was fine. Back to the dyno I went, it was down at least 60hp, I took it back to them and they had it for three days. They found what they did, fixed it, and gave it back to me. I dyno'd it again and it was within 5hp of the baseline. They compensated me for the dyno costs with oil changes. (STS-V held 9 qts of Mobil 1) Without that baseline to prove they messed the car up. I could have been stuck with a car with that much power loss.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
10-29-2015, 02:27 AM | #26 |
Rep 2,354
Between a badly launched RWD and a well launched AWD with the same crank hp - you can probably find a pretty big difference in trap speed (I am 100% guessing here - 1/4 mile is not my thing)?. A 60-130mph will show the true power as even weight is less of a factor because of the drag. 60-130 does however pose other legal challenges
(A Dane in China) |
10-29-2015, 07:33 AM | #27 | |
Rep 1,107
10-29-2015, 08:26 AM | #28 |
Rep 939
The good thing with the 1/4 mile is that it's legal and you won't get arrested if caught. Always a plus. A bad launch will really show up in the 1/4 mile times but the trap speed should be close unless there is actually a problem with the car's performance. The nice part is a 1/4 mile run gives you several snap shots as you go. 60' time to see traction and launch, 330' time, 1/8 mile time and mph. A wealth of info, especially if you can compare the times with someone else at the strip with a similar setup. The best is to run against your peers and just see what you got.
10-29-2015, 08:57 AM | #29 | |
Rep 115,980
Mike |
11-03-2015, 07:53 AM | #30 |
Rep 681
Yes, it could be realistic.
Absolutely correct.
BMW M3 G80 Isle of Man
