04-30-2023, 03:32 PM | #1 |
Rep 3,304
Our pointless Bungalow rebuild project.
May be or not be interest to some, but we are finally on the road with our major renovation of the house.
Builders started in Feb, the brief for the architect was to come up with a design that allowed us to view the garden from as much of the house as possible. Original plan was to keep most the existing structure and build above it but almost as soon works started it was obvious the old house wasn't well-built, including finding unfilled well. This week building has finally started, and quotes for glazing been finalised. It's only now we are appreciating the scale of the 'design' 4×4.5 meter of glazing for the entrance, the architect has 100% met the brief of us asking for more light/views from any where in the house!! Next few weeks should see the walls start going up, and steels starting to appear . |
04-30-2023, 04:34 PM | #2 |
Rep 1,766
Why is the thread titled 'pointless'?
Is the point not to give you a better house, with what you require? Looks like you are getting that! FWIW; the 'well' looks like it may have been an old cesspit in a former life, judging by the lack of mortar and the discolouration of the bricks. Brick cesspits had gaps in the mortar to allow the 'grey' water to seep into the surrounding ground. The 'sewage' was then supposed to break down through anaerobic respiration and microbe breeding, then dilute. Not the most pleasant of processes, but worked (to a degree) for thousands of years! |
05-01-2023, 02:11 AM | #3 |
Rep 25,148
Looks a great project. Where was the well outside I assume or under the existing bungalow ?
PS why is the project pointless?
My car made front page of Bimmerpost
05-01-2023, 05:30 AM | #5 |
Rep 3,304
Pointless only interms of anyone looking at the project from an ‘investment’ point of view would think its mad. We are not adding any extra rooms, and instead losing a large family bathroom whilst spending in the region of £400K+.
JustChris The hole in the ground with water in was apparently ‘well hidden’ by who ever build the original extension to the house. The old/new entrance gable/hallway sits above the hole!! The builders were surprised we haven’t been flooded before, but it probably explains the weird run off/pooling of water we had around that area every time the rain got heavy! As they say, never dig around an older property as you never know what your going to find. The surveyors have been out again as well, and we are basically now rebuilding 75% of the old house from the ground up. There isn’t a single bit of floor space that isn’t been ripped up/swapped, and the whole roof will be new. So actually the cost of the build is looking pretty ‘reasonable’ given the job. The builders are great guys, they are very much just getting on with things, currently about 2-3 weeks behind target due to all the ground work issues, but they are hoping to catch up as the walls go up. The steals is still the bit am not sure about still, I cannot quite visualise who this all going to go up, but than again that’s why I’m not a builder . |
JustChris17605.50 |
05-01-2023, 05:41 AM | #6 |
Rep 671
Looks like a big project. Hopefully it’ll all go to plan with no more gotchas like the well being uncovered.
We had the same in our last house when extending the kitchen. It certainly surprised the builder who was using a pneumatic drill on the bricks covering it when he heard one fall and land with a splash a second or two later. Sadly it was on the line of the foundations otherwise we would have made it a feature in the kitchen. |
05-01-2023, 07:49 AM | #7 |
Rep 5,265
Good luck on the build..
My current view is that extensions and rebuilds start to make sense because of one thing...LBTT I can't get my head around the fact that if I wanted to buy a house worth 1.2 million I'd have to pay 102k for that privilege in LBTT. |
05-01-2023, 02:12 PM | #9 |
Barge driver
8712
Rep 12,449
Someone's got to pay for the motor home
730d/Z4C
05-01-2023, 04:33 PM | #10 | |
Rep 1,766
'moving tax' has cost me a fortune over the years. I've moved many, many times. It's like taking candy from a baby for the Government. It's a brilliant tax. No-one actually pays it in cash. All gets thrown into the massive cost of moving house. Never paid a (waste of space parasites) estate agent in cash either. Probably how they keep the monopoly going TBH |
05-08-2023, 12:19 AM | #11 |
Rep 3,304
Front foundation work nearly done, the 'opening' been formed is going to be where the 4×4.5meter alu smart wall glazing will sit.
I can start to see the 'line of sight' obsession our architect has about getting light that goes from the front door straight into the back garden. The rear when build up will have a 3 meter sliding door that site in line with the front glazing with no walls in between. So essentially the current view into the garden thanks to all the demolition work will be partially preserved once walls are rebuilt. |
05-20-2023, 01:14 AM | #12 |
Rep 3,304
Slower progress over the last week, as the steels guys have been to take measurements and now fabricating. Next week should see the first steels go in and than progress should be quicker.
The front is still where I'm excited at the moment, cannot wait to see the steels go up to outline the almost wall to wall glazing at the front . Last edited by gangzoom; 05-20-2023 at 01:20 AM.. |
06-24-2023, 09:31 AM | #15 | |
Rep 3,304
I'm leaving the builder to it, they know what they are doing. I'm trying not to interfere but we have changed the downstairs glazing layout about a dozen times. Have now hopefully settled on the final glazing openings as the walls will hopefully start appearing soon. Still not sure about essentially having a glazed 'wall' in the living room versus just a normal window (3)? Going for aluminium frames all round. |
06-25-2023, 12:02 PM | #16 |
Rep 1,766
06-25-2023, 12:34 PM | #17 | |
Rep 5,265
gangzoom1722.50 |
06-25-2023, 02:38 PM | #18 | |
Rep 3,304
The aim of the project was always the stairs and entrance, so the living room glazing was/is an after thought in many ways. I’ve left my armature drawings with the builders……will be interesting to see what kind of openings get formed. The glazers will make the windows to fit, so its essentially the blind leading the blind on actual/final opening sizes . |
07-07-2023, 11:04 PM | #19 |
Rep 3,304
Most the steels have now arrived, but still needs installing. At least we now have some walls, and window/door openings are starting to form.
07-29-2023, 12:04 PM | #21 |
Rep 2,010
Drives: F30 335d
I had 3 beams of steel in total about 7 metres for some interior alterations and that was £1k. Yours must be at least an order of magnitude greater!
07-29-2023, 01:16 PM | #22 | |
Rep 3,304
Better be good once it's done. |
MY340i731.50 |
