12-07-2017, 07:48 AM | #23 |
Rep 310
Had mine in recently for squealing rear brakes and they did fix them. Not sure how long for though !
The F cars are much more prone to this than the E series before in my experience and I've had 5 ? |
12-07-2017, 08:22 AM | #24 | ||
Rep 32,881
12-07-2017, 08:34 AM | #25 |
Rep 2,152
haha yea exactly like mine then
i had to wrap the Shim tape over 1 edge (across the back and down 1 side) as my pad was a touch to small and clunked. i did remove the weight etc from the OEM pad but couldnt get it to fit the DS2500
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
12-09-2017, 01:36 PM | #26 |
Rep 797
I've had this for some time (currently just coming up to 10K). Often the problem appears *after* the brakes have been working hard, and it's most noticeable when coming to a stop - but that's probably because there's less road noise to mask it. God knows what pedestrians think about it.
I flagged it to the dealer when I was having my summer wheels swapped over to the winters. They cleaned the brakes, and this seems to have alleviated the problem for the moment. I do recall that this happened when I had the summers put on back in the spring, but of course the squeal came back.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
12-09-2017, 04:17 PM | #27 | |
Rep 4,932
12-09-2017, 04:39 PM | #28 |
Rep 32,881
Ignore the CBS, the pads need to be visually checked. I’m pretty hard on mine and they still had 4mm left at 23k. They could last a fair bit longer but I always change at 4mm because the performance tails off as the pad material get thinner.
12-11-2017, 03:52 AM | #29 |
Rep 116
Mine has done it from day one nearly. 8 k miles and still does it. I'd read it was something to be expected, so haven't done anything about it.
12-18-2017, 03:14 AM | #30 |
Rep 2,271
At the dealer this morning. After a test run they said they could not find anything wrong... standard!
I have asked if they would still take the brakes off and check/clean which they agreed too. But they kept saying that as it is under 12k they would honour this.
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
12-18-2017, 03:35 AM | #31 |
Rep 2,808
It's infuriating. Mine has always done it. I asked the dealer to look at it last service and they found 'nothing'. Something so simple should not happen on £45k car in my mind.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
12-18-2017, 03:46 AM | #32 |
Rep 707
Mine start squealing from time to time, but a couple of aggressive braking manoeuvres and it is gone again. On that basis it hasn't bothered me sufficiently to warrant a trip to the stealers.
12-18-2017, 03:59 AM | #33 | |
Rep 2,271
And these M sport brakes are supposed to be the better and upgraded compared the standard ones... :
IG: project540ix
12-18-2017, 04:02 AM | #34 | |
Rep 2,271
If it happens again I will try a few harsh brake applications!
IG: project540ix
12-18-2017, 05:16 AM | #35 | |
Rep 15,858
The 'normal' setup, due to the different design and performance requirements, will be less prone to brake squeal. |
Junebug851613.50 |
12-18-2017, 07:16 AM | #36 |
Rep 32,881
12-18-2017, 10:29 AM | #37 |
Rep 784
Drives: 2018 F80 M3 CP YMB
Mine have been fine to date... 60,000 miles now. Changed to Pagids all round @ about 50k due to a warped rear disc, plenty of copper grease applied to all touch points... Not to be confused with the squeal that develops for the first 50 yards or so of setting off - which I have had - which seems to be a handbrake lubrication issue...
Junebug851613.50 |
12-18-2017, 12:53 PM | #38 |
Rep 408
Mine do as well, It doesn't really bother me but I reckon my neighbours know when I put it the garage tho. They're noisy f**kers anyway! so what goes around......
A few hard slow downs like a break-in procedure burns off the crap on the surface of the pads & this usually sorts it. |
Junebug851613.50 |
12-19-2017, 12:51 AM | #39 |
Rep 2,271
No, not really heard race cars but have had a read and get what you're saying
IG: project540ix
01-16-2018, 02:11 PM | #40 |
Rep 2,157
Drives: X3M Competition
Sorry for bringing back the thread but I have started to have the dreaded break squeak, and it’s driving me crazy!
Is anyone else experiencing this in their new motors? Hoping to get it looked at on Friday.
CURRENT
X3M Competition- Toronto Red [url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Car[/url] |
01-16-2018, 02:21 PM | #41 | |
Rep 2,271
Agree with you there, I hated it and it was embarrassing pulling up to the lights and getting them looks from other ha! I just used to smile at them
IG: project540ix
RustyBitz1573.50 |
01-19-2018, 07:04 AM | #42 |
Rep 2,271
@RustyBitz
Any update from the dealer on your brake squeal? I'm guessing they looking at it today while you're getting the exhaust fitted?
IG: project540ix
01-19-2018, 01:16 PM | #43 |
Rep 160
I have the M brakes and the squealing started around 1000 miles from new, taking it in to the dealer next week.
See what excuse they can come up with |
01-30-2018, 08:35 AM | #44 |
Rep 160
Just returned from the dealer having had my squealing M brakes checked under warranty.
Car has done 1600 miles from new Both front discs and pads need replacing They are paying for it, so thank goodness for the warranty |
