04-21-2014, 10:24 AM | #1 |
Yr1OfD1
106
Rep 900
auto close window via fob
spring is here and its been a while after i did my last coding. everything is set correctly. i do have configuration like side mirrors will automatically close when hitting the keyfob. roll up and down via keyfob.
anyone have the code for this... automatic roll window up / side view mirrow fold after locking via keyfob? thanks in advanced!
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport 2011 X5 xDrive50i 2009 X5 xDrive 30i 2008 135i Coupe |
04-21-2014, 12:16 PM | #2 |
Rep 23
http://www.f30post.com/forums/showthread.php?t=696777
I think it has all instructions. Mostly summarized in first post. |
04-21-2014, 12:23 PM | #3 |
Yr1OfD1
106
Rep 900
can't find it... paging shawnsheridan lol
04-21-2014, 01:29 PM | #4 |
Rep 1,892
http://www.f30post.com/forums/showpo...postcount=5532
FEM_BODY / 3110 / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv FEM_BODY / 3110 / ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN -> aktiv FEM_BODY / 3053 / KOMFORTSCHLIESSUNG_FB -> aktiv (NOTE: aktiv = 00 is correct, do not change the werte value!) FEM_BODY / 3053 / KOMFORT_SCHLIESSEN -> werte to XX (Button push delay time to fold mirrors in 100ms/unit, typically set to 03 (300ms)) If you want to fold the mirrors every time you lock, set KOMFORT_SCHLIESSEN to 00. |
04-21-2014, 01:55 PM | #5 | |
Yr1OfD1
106
Rep 900
04-21-2014, 04:44 PM | #6 |
Yr1OfD1
106
Rep 900
help! my license expired lol is there a workaround here???? or really need to buy another token?
04-21-2014, 07:31 PM | #7 |
Rep 40,744
What versions of E-Sys and PSdZData are you using?
04-21-2014, 07:39 PM | #8 |
Yr1OfD1
106
Rep 900
3.22.5 and im not sure if im using 49.1
04-21-2014, 07:41 PM | #9 |
Rep 40,744
Well, you need new Token solution, so you might as well update E-Sys at the same time, and optionally your PSdZData.
PM sent.
04-21-2014, 08:36 PM | #10 | |
Yr1OfD1
106
Rep 900
04-21-2014, 08:42 PM | #11 |
Rep 1,892
04-23-2014, 08:45 AM | #12 |
Yr1OfD1
106
Rep 900
i just did set to 03 now but locking the door doesnt close the window. i need to press and hold to make them closed. much cooler if just one touch "lock" then they will closed all together. im not sure if im missing something?
04-23-2014, 09:37 AM | #13 | |
Rep 1,892
I don't know of any code that will enable a 1-touch open/close. |
