BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Best upgraded diverter valve N55 ?
      03-12-2021, 02:51 AM   #1
ChrisSmith335i
Drives: 355i
Seen load of people run the Go Faster Bits DV+ but read it needs some maintenance?
A few other state the Turbosmart one is best but I cant seem to find one that states it fits and N55 335i.
What do people run for an upgrade DV ?
      03-12-2021, 04:32 AM   #2
NEWTRON
NEWTRON's Avatar
85
Drives: F32 435i
the turbosmart dv hasn't been out as long as the gfb one so more people have that one. kies has it. thats were I got mine from. They both perform the same, the plumb back is just quieter.
https://www.kiesmotorsports.com/prod...-dual-port-vr9
https://www.kiesmotorsports.com/prod...10d96976&_ss=r
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
      03-12-2021, 08:28 AM   #3
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
turbosmart
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-12-2021, 10:56 AM   #4
mike@x-ph.com
mike@x-ph.com's Avatar
Turbosmart is certainly the more popular one for my customers
https://x-ph.com/sale/
Phone number 702-494-9435
      03-12-2021, 12:26 PM   #5
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
turbosmart
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      03-13-2021, 04:21 AM   #6
ChrisSmith335i
Drives: 355i
I assume I can use the Turbosmart VR9 on my PWG car? Does it work for both PWG and EWG? Many thanks
      03-13-2021, 06:24 AM   #7
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
yeah
      03-14-2021, 07:32 AM   #8
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Been running GFB DV+ for +5 years. Zero maintenance done, but then again - the N55 is self lubricating on the external components also
(A Dane in China)
      03-14-2021, 09:57 PM   #9
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
+1
I've been running GFB DV+ for 2 years with no issues or maintenance required.
      03-14-2021, 10:52 PM   #10
BMWApp
Drives: 2024 X5 M60i, 2015 435i
Sorry for the question if it's dumb but what is the advantage or gain from upgrading the diverter valve?
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune
      03-15-2021, 12:21 PM   #11
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
It doesn't necessarily provide any direct benefit if your stock DV is doing its job. Some people report improved throttle response and/or lower WGDC. The basic idea is that the upgraded DV can respond quicker (throttle response) and hold boost better (WGDC) than the OEM one. Keep in mind the OEM one was really only designed to work in the 7-11 psi range and people are pushing as high as ~20 psi on stock turbo. I am still on stock DV with no issues running up to about 17psi but i may still do the turbosmart at some point and try to quantitatively test.
FL_F306.00
      03-15-2021, 09:32 PM   #12
BMWApp
Got it. Thanks for the information and explanation. I really appreciate it.
      03-16-2021, 06:22 AM   #13
ChrisSmith335i
Drives: 355i
Would the DV to atmosphere version cause it to run rich as its expecting meter air back in the system? Or not an issue on a modern car where the DME can respond quickly ?
Just wondering if I should get the replumb version or the "dual port" which does both
      03-16-2021, 11:17 AM   #14
thejeremyman9
4364
The working theory is that the DME can respond fast enough. A few people have reported running it without issue. This used to be a problem on turbo cars from the 90s, and my 3000gt used to stall if you did a WOT pull and went immediately to neutral when it had a VTA BOV (stock was reicirc). Seems to be a nonissue on modern cars though. The dual port will be much louder FYI.
      03-16-2021, 04:16 PM   #15
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
I have the plumback and it is quieter than stock even with my bms intake.
With stock and the intake I would get the swoosh sound. Now its barely perceivable.
      03-17-2021, 02:17 PM   #16
ChrisSmith335i
Drives: 355i
I think it’s the noise I’m mainly after, I’m childish what can I say lol
      03-17-2021, 03:07 PM   #17
thejeremyman9
4364
You can also achieve noise with a open air intake and plumb back, FYI. My stock DV with CTS turbo intake was extremely loud.
      03-17-2021, 04:31 PM   #18
435gc
435gc's Avatar
174
If you just want the swoosh noise, I would try an intake 1st. They are pretty cheap and much MUCH easier to install.
Think 6 minutes vs 6hrs of anger and frustration.
      03-18-2021, 10:26 AM   #19
ChrisSmith335i
Drives: 355i
Thing is I've read open cone will cause heatsoak, CEL lights, less performance is a high price for noise. Any have experience with any of the above?
      03-18-2021, 12:17 PM   #20
thejeremyman9
4364
I've always been of the school of thought that the open air intakes underhood may eventually heatsoak the IC sooner since you are drawing in hotter air to begin with, but under normal driving conditions its probably negligible (and my data showed that) since its pre-IC.
Not all cause CELs. For example CTS does not, because it has a properly designed MAF housing.
They don't really cause "less performance". Any increase is debatable, but unless you have a really poorly designed intake it shouldnt make your car slower. It may change your throttle response and drivability characteristics.
Read my intake thread here as it basically answers all these questions and more: https://f30.bimmerpost.com/forums/sh....php?t=1765289
      03-18-2021, 03:38 PM   #21
ChrisSmith335i
Drives: 355i
So you’d recommend the CTS intake?
      03-18-2021, 08:38 PM   #22
Munchi435i
Munchi435i's Avatar
If your in the market for one I have a used one for sale in the classifieds.
