BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Cv shaft spacer replacement
Studio RSR
      07-04-2020, 08:47 PM   #1
hollovoid7
hollovoid7's Avatar
Drives: 2016 BMW 428xi Gran Coupe
Greetings!
I just did a rebuild of my cv shaft, and unfortunately when taking it out, I broke the plastic spacer that meets up to the front differential, is there a way to buy this? I can't see it in realoem or any other part list. Here is where it sits for reference... or maybe it doesn't matter? But want it in there if it serves a good purpose... the new shaft is 1200 so I'd rather not go that route!
Thanks'
      07-04-2020, 11:06 PM   #2
Pauloxxi
Pauloxxi's Avatar
Drives: 2014-320Xi / 2017-330Xi
Please add pictures of broken piece.
      07-05-2020, 06:38 PM   #3
hollovoid7
hollovoid7's Avatar
This is what photos of a new unit look like, you can see the piece im talking about compared to how mine looks. I dont know where my broken piece went, ugh..
Thanks in advance!
      07-06-2020, 11:54 AM   #4
Pauloxxi
Pauloxxi's Avatar
This part probably is a slinger to seal or protect the CVJ. You may consider checking the salvage shops for a used half-shaft.
      07-06-2020, 12:12 PM   #5
hollovoid7
hollovoid7's Avatar
Originally Posted by Pauloxxi View Post
This part probably is a slinger to seal or protect the CVJ. You may consider checking the salvage shops for a used propshaft.
I will do that. Thank you sir.
      07-06-2020, 01:01 PM   #6
blumagic
blumagic's Avatar
309
Drives: 2014 328i xdrive , 2013 SHO
This should help:
https://www.getbmwparts.com/v-2014-b...--differential
from your description I believe it is #4/#10 (same part #)
https://www.getbmwparts.com/oem-part...ItMGwtbDQtZ2Fz
      07-06-2020, 04:05 PM   #7
hollovoid7
hollovoid7's Avatar
Originally Posted by blumagic View Post
This should help:
That is actually the seal that goes into the differential, I replaced that when I pulled the shaft. Though the drawing does make it look like what's in the picture I posted! BMW doesn't seem to have individual parts listed for these cv axles outside of the boot repair kits, I'm guessing they want you to buy the whole thing!
Pauloxxi339.00
      03-08-2024, 05:34 PM   #8
Dobrin
Drives: 2015 455i xDrive convertible
Sorry, but did you ever solve this problem? I am in a similar situation and wondering if these plastic spacers can be bought from anywhere? If you can find the magnetic rings, how come this part is not available, even as an aftermarket.
