BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 328i BMW M Performance Exhaust INSTALLED! Real World Videos
proTUNING Freaks
      12-11-2018, 07:19 AM   #243
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Originally Posted by RMachuca3d View Post
Its super simple, should take no more than 45m at a shop, or an hour or two on your own. 100$ should be more than enough to cover installation costs at a shop.
Fair, $200 seemed a little high but I guess it's definitely too high. Thanks for clearing that up...
      12-13-2018, 12:33 PM   #244
RMachuca3d
RMachuca3d's Avatar
724
Drives: F30 328i Msport
You have to keep in mind, they see you driving in a recent BMW they will try to charge you premium prices, as opposed to driving in with an old honda or something, for the same work.
      12-14-2018, 01:06 PM   #245
Astone22
Drives: F30 320 xdrive, f32 428
Is the valve removable? So am I able to transfer the one from my original exhaust and transfer it to the mpe one? The one I am buying the guy removed the black box for valve. Just want to make sure before I buy! See pic below
      12-14-2018, 03:33 PM   #246
rjd_F30
rjd_F30's Avatar
I'm not sure how difficult or involved it would be, but I'm sure there's a way to install a flap back in there.
      12-14-2018, 03:49 PM   #247
RMachuca3d
RMachuca3d's Avatar
724
Super easy, 3 bolts and you can take it off from your stock one to the MPE and bolt it on.There is a heat shield that goes between the plastic box and the MPE exhaust, same as stock, so dont forget to put that inbetween!
Oh and dont forget the little spring that actually controls the valve that connects to the actuator, before you fully tighten the bolts on the mpe, reinstall the spring and then tighten the bolts down, otherwise its a PITA to put that spring in.
rjd_F301999.50
      12-14-2018, 04:12 PM   #248
Astone22
Thanks for the help? Will I see the heat shield and spring once I remove the 3 bolts? Is it a bad idea to buy one where it's missing??
      12-15-2018, 05:27 PM   #249
Astone22
Should I be worried about them cutting the oem exhaust? I just am worried the new one will rattle with the clamp. Thanks
      12-15-2018, 05:42 PM   #250
mattwong92
Drives: 2012 BMW 328i Sedan
Got mine for $650 off this forum and had it installed for $80. Was considering a resonator delete as well but I've been running just the MPE itself for now 1.5 years. After breaking in its a really nice daily exhaust, not overbearing on the drone. You can definitely get crackles and pops out of this exhaust without anything else. When its warmed up, and you shift into Sports + and really push it at gear shifts you hear the farts in between shifts which is nice as well.
      12-15-2018, 07:16 PM   #251
Astone22
Awesome thanks!! Have you had any issues with rattles?? That's my main worry
      12-17-2018, 03:17 PM   #252
RMachuca3d
RMachuca3d's Avatar
724
The rattling is from the valve inside one of the pipes, it only happens when cold, once it warms up there is no rattle, one way around this is to disconnect the valve and wire it open permanently.
      12-17-2018, 06:19 PM   #253
Astone22
Thanks for the insight!! Hopefully I can find someone with a used one in golf condition
      03-23-2019, 10:49 PM   #254
F30bih
Drives: F30 328xi
Installed the exhaust today on my 328i, 100% worth it. It made the car sound sooooo much better. Install was straight forward, followed the install threads on the forum and a few videos. For anyone considering this, I highly recommend you get it.
Here's a video of it:
      03-25-2019, 06:35 PM   #255
MacklinUSOB
Drives: f30 328i 6MT Sport
I picked mine up used for 325 bucks, got a clamp off another member for 25. Very worthwhile mod, thousands of miles later and I still love the sound.
I used picture wire to keep the flap open all the time, makes it a bit throatier down low. The mechanism is still in there but the pin flew out during a track day, it was like I was driving a can full of coins for the last session. Not again.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      09-30-2020, 01:40 AM   #256
F30lancs
Drives: BMW F30 328i msport
I confess I'm an imposter. Got mine booked in for a muffler delete! Would have loved this set up sounds awesome, but guessing very expensive.
      07-08-2021, 03:59 PM   #257
steijn
Drives: bmw f20
      07-10-2021, 09:40 AM   #258
Guus keunen
Guus keunen's Avatar
Netherlands
I got a 335i exhaust for my 328i F30 and I also placed an exhaust cut out. With the car in sport mode (so the original exhaust valve open) and the exhaust cut out closed, the sound is sporty. With the exhaust cut out open, the shifts are very audible and the sound is even sportier. The overall sound is rather throaty, especially up in the rev range. You can also clearly hear burbles when letting go of the gas and they are quite pronounced when revving.
Update:
Removed the resonator, it is a PITA to do since it has to be welded for a proper fit.
      08-13-2021, 10:29 PM   #259
cocy999
cocy999's Avatar
Drives: F30 328i
Originally Posted by Guus keunen View Post
I got a 335i exhaust for my 328i F30 and I also placed an exhaust cut out. With the car in sport mode (so the original exhaust valve open) and the exhaust cut out closed. The shifts can clearly be heard and sound a bit like a muffled DSG fart and overall the sound is more sportier. With the exhaust cut out open, the shifts sounds like a fart. The overall sound is rather throaty, especially up in the rev range. You can also clearly hear burbles when letting go of the gas and they are quite pronounced when revving.
Did you feel any lost of power with the 335 exhaust installed?
      08-21-2021, 08:29 AM   #260
Guus keunen
Netherlands
No power loss, just sounds better and louder on cold starts.
      08-23-2021, 11:16 PM   #261
cocy999
cocy999's Avatar
Drives: F30 328i
Looks like thats next on my list
      02-12-2022, 09:54 AM   #262
KRYC
Drives: BMW 328i
M Performance Exhaust (#18302293771)
This M Performance Exhaust #18302293771 was the best mod I ever made on my 2013 328i. The exhaust tone is simply amazing. I removed it before I traded in my BMW. I put about 20k miles on it and its in great condition. $750. Philadelphia area.
      06-01-2022, 03:18 AM   #263
mvdbogaard
Netherlands
Drives: BMW 320i Touring F31 2018
Nice!
      04-12-2024, 04:20 PM   #264
F30Mo16
Drives: 2016 BMW 328i
Is this still available?
