11-17-2014, 03:21 PM | #90 |
Rep 28
I still can't tell if I had DHP or not with my sportline package. If you have Msport/sportline in the US does this automatically include DHP? Also, if you have the sport/eco mode switching buttons and the option to select chassis/drivetrain in these modes on your idrive, is that DHP? No one seems to be able to give a straight forward answer to these questions.
Traded in my 2015 428i Coupe for a 2018 Grand Coupe: Black on Black with red trim.
Upgrades: JB+ | H&R Springs | Spoiler | 20% Tints |
11-17-2014, 03:48 PM | #91 | |
Rep 5,056
11-17-2014, 03:51 PM | #92 | ||
Rep 6,299
If you really want to see if you have it or not, why don't you just use a VIN decoder? A VIN number contains all of that information. Just go here, http://www.bmwarchive.org/vin/bmw-vin-decoder.html. If you see the code S2VFA pop up under "Optional Equipment", then you have DHP. You can also find it on your window sticker. Not sure why you'd buy a car without knowing exactly what you were getting... You can also tell by driving a car down a crappy road in Comfort or Eco modes, then drive down that same stretch of road in Sport or Sport+ mode....if it's noticeably more uncomfortable then you'd have DHP. |
11-17-2014, 04:44 PM | #93 |
Rep 201
It's amazing that there is still so much confusion over DHP.
Sportline/M-Sport= Eco Pro, comfort, Sport, Sport + toggle switch options, plus M suspension in cars without Xdrive, which lowers car by 10mm. Xdrive cars are not lowered 10mm as they delete M suspension because from what I heard they need the extra space for the Xdrive changes and can't allow for the lowering.(not confirmed as to the reason). DHP(does not lower suspension any lower, in Xdrive OR non Xdrive cars) However, adding DHP does give you VSS plus electronically controlled dampers that adjust to environment, and ability to customize Chassis and Drivetrain settings from Comfort(or Regular), to Sport which will stiffen ride and tighten steering if chassis is selected, and change throttle mapping, raise RPMs and shift points if Drivetrain is selected, or both at the same time. That's it. If you have Chassis/Drivetrain option in iDrive, you have DHP. Case closed. The wire near your shocks confirms it. Maybe there are new packages in which they are including DHP, no longer as a standalone option, so you aren't seeing it in the sticker? Or they made a mistake. Good for you guys if it's the case. |
11-17-2014, 06:42 PM | #94 | |
Rep 70
11-18-2014, 12:02 PM | #95 | |
Rep 201
Only Sport and M Sport line without xDrive get lowered with M suspension, with or without DHP. |
11-18-2014, 12:05 PM | #96 |
Rep 2,266
He's saying 10mm drop with DHP or Passive Sport Suspension. The xDrive gets no drop.
F30 Sapphire Black M-Sport 335i 6MT
11-18-2014, 03:25 PM | #98 | |
Rep 201
Can anyone else confirm this? |
11-18-2014, 06:03 PM | #101 |
Rep 2,266
The Sport Suspension is 10mm lower than the standard height, but I thought when you order DHP on a line other than Sport or M-Sport, you get the same Sport suspension, i.e. same components. Note: only referring to RWD.
So it is not lowered in that case? It's probably a moot question for this forum as most of us have M-Sport and Sport already.
11-19-2014, 12:49 AM | #102 |
Rep 70
11-19-2014, 09:04 AM | #104 | |
Rep 2,290
If you get Msport and xDrive, you have the same suspension as if you didn't get Msport. The only way to get rid of xDrive sloppy suspension is to get DHP, which allows you to move between Comfort (basically standard xDrive suspension) and Sport (which you would get if you had RWD Msport). It's really not clear, but basically if you're getting xDrive, you should get DHP if you want a better handling vehicle. It's easy to tell if you have DHP. In settings, if you can modify your suspension settings per drive settings separately from throttle responsiveness, then you have DHP. |
11-19-2014, 09:12 AM | #105 | |
Rep 1,135
Whether you have a no line, a luxury line, or an M sport line, even an XDrive, if you have the DHP you have the DHP suspension (known as the Adaptive M Suspension). |
11-19-2014, 09:16 AM | #106 |
Rep 1,135
I have a rear wheel drive Gran Coupe M-Sport with DHP. Are you saying that when I add DHP my ride gets lowered an additional 10mm? Or are you saying that I get a 10mm drop because of the M-Sport and DHP makes no additional drop difference?
11-19-2014, 09:48 AM | #107 | |
Rep 201
So I don't know how accurate this picture is. When you choose DHP it does delete M sports suspension in the Sport models and give you Adaptive M suspension, and it does seem to maintain the lowered stance of the M suspension cars, so maybe it does lower the car. Although the Xdrive lowering makes me question the accuracy of the pictures. |
11-19-2014, 11:27 AM | #108 |
Rep 36
I'm all confused... So per joewalton.. if you get DHP you get adaptive m suspension? I thought if you got the M Sport Package you get adaptive M suspension included? Im wondering because there's a model that has M Sport/DHP package included... are they ideally the same suspension? ... sorry need to clarify if its worth the extra money as it seems it will be like you're paying additional 1k for DHP, but if it has been included in M Sport, why pay for something that it already has??
11-19-2014, 11:35 AM | #109 | |
Rep 1,503
DHP is a package that includes adaptive m suspension and variable sport steering. You can only have one suspension on a car. If you get DHP, the adaptive m suspension replaces the standard static m sport sport suspension. |
