02-05-2018, 12:30 PM | #199 |
Rep 7
F31 330d install
Hi has anyone tried this on a 2014 F31 330d xdrive, is it worth it? or should I just get a normal strut brace, I have seen the back alloy strut going for reasonable prices but not the CFBR yet so may just try that for now if not too difficult
I have ordered Bilstein b14s so may be a good time to do this mod when they are being fitted? Thanks in advance for any help Darren |
02-13-2018, 02:26 PM | #200 |
Rep 986
Finally completed all the work for the strut brace retrofit on my M235. It was a little bit of a project. Some major plastic trimming on the left and right plastic covers, along with the fender trim pieces. I drilled one hole on each side for those strut extension rods into the body and used an M10 rivnut. Similar to the large torx bolt in the fender, except the hole is already there for that one. You just have to rivnut it into place with the tool. Ground control camber plates for my 235 were retrofitted for the M4 studs. They use the same plate for the 2/3/4 series and M2/3/4. So it worked out.
Lancelot568.50 |
02-19-2018, 07:29 AM | #202 |
Rep 986
Too bad you didn't live closer, I would've helped you out fitting them
Wait for my update on the stage 3b alternative, I'm fitting the M2 front strut braces instead of the expensive Carbon Fiber piece. I got all the parts, and I've started mocking up the fitment. It requires a pair of brackets for each side that I'm going to use 3m structural adhesive to bond to the frame. |
02-22-2018, 12:17 PM | #204 |
Rep 159
Your car came with provisions on the strut towers to bolt up the corner braces? I wonder if that's the same on the F30
02-22-2018, 04:05 PM | #205 | |
Rep 2
Nice mods, congratulations everybody!
I have a F36 2015 Sport line and thinking about getting them done. Quote:
I live in France region, is it possible to help me getting these struts hat adapters? Are the ones that you designed earlier? Geometry has to be redone after the mods, right? Thanks a lot |
02-22-2018, 04:26 PM | #206 |
Rep 986
Negative you have to buy two sets of brackets and either glue them or weld them. I used 3m panel adhesive.
https://www.amazon.com/3M-08115-Pane.../dp/B000PEW4MI Don't forget you still need the tool and nozzles So I bought this kit and it worked perfectly. https://www.amazon.com/3M-08115-Adhe...6ZJZEGANRC707G Last edited by zipphreak; 02-25-2018 at 07:39 PM.. |
02-22-2018, 07:52 PM | #208 |
Rep 159
02-22-2018, 08:24 PM | #209 |
Rep 10,473
I’m having trouble seeing how these 2 side braces (if you can even call them that as flimsy as they are) can add much to this design
02-22-2018, 08:37 PM | #210 |
Rep 986
I didn't say IK6SPEED had to do it did I? And how do you even know they are "that flimsy" as your noting. They serve the purpose of providing additional bracing towards the front of the strut tower.
The m4 uses a Carbon fiber brace in a similar position, and bolts to the crosslink in the same holes. The M2 uses the stock F22 strut brace along with these side braces.... You don't have to do it I took the M4 strut brace and instead of the CF piece, I used the M2 pieces. Does the same deal. Less $$$ I am posting here for people to have as an alternative to spending 1200 on a piece of CF. Doesn't look as flashy but my hood is closed 99% of the time. dotjonnL Part #'s Quantity 2: 41007346815 (side bracket L/R) 41007346817 (strut tower bracket left) 41007346818 (strut tower bracket right) 51647301929 (strut brace left) 51647301930 (strut brace right) Quantity 6: 22326760945 (metric hex bolts) 51647294928 (front crosslink) Quantity 2: 07149229516 (metric hex bolts) Last edited by zipphreak; 02-25-2018 at 07:40 PM.. |
02-22-2018, 08:43 PM | #211 |
Rep 2
Could this adhesive be used to attach the 2 additional A pillar mounts for the strut bar? what is the type btw?
Did you guys think about a rear strut bar? Would it make a noticeable difference in driving feel? |
02-22-2018, 08:47 PM | #212 |
Rep 986
alex2018 The M4 A pillar mounts don't work. They add to the stack height and interfere with the hood closing mechanism, IE. your hood won't close There's a very simple solution to mounting the strut rods.. They line up perfectly to the A pillar, mark it, drill incrementally w/ a step bit, and then install a 10mm rivnut with a rivnut tool... Nice large 10mm bolts right to the frame That's what I did and it is perfectly solid. Remember every chassis is different, so this works for the F22. Can't say it works for all chassis' though, YMMV.
alex20180.00 |
02-23-2018, 12:53 PM | #213 | |
Rep 159
02-23-2018, 01:00 PM | #214 |
Rep 986
dotjonnL This is new territory, not something many people have done. I'll let you know towards the end of year.. After all my track days
If your concerned, you can always weld it Since it's not primarily a vital structural component, I chose this route. If it fails, I'll weld it. |
02-25-2018, 07:32 AM | #215 |
Rep 986
I wanted to share this with you guys. I made some brackets for the left/right trim covers, since you have to cut off the OEM tabs to fit the M4 strut brace.
I used some ABS plastic sheet from Amazon, placed piece of paper on the strut brace, traced the edges/pop-rivet hole with a pencil, transferred the lines to the ABS sheet. But I only used a razor blade/exacto knife to cut it out, and dremel would've been quicker/easier/more elegant Soo I lost some blood on this project. Good Luck Last edited by zipphreak; 02-25-2018 at 07:45 PM.. |
alex20180.00 |
02-27-2018, 01:50 PM | #216 |
Rep 986
For phase3b, where the strut tower brackets are bolted to the new braces. I swapped the two 3/8 washers i was using with an aluminum spacer. They are needed because the bolts are not fully threaded, so it just takes up that space.
https://www.mcmaster.com/ part #92510A491. One for each side. |
06-15-2018, 12:05 PM | #217 |
Rep 93
I have a CF brace for sale if anyone is undertaking this project.
http://f30.bimmerpost.com/forums/sho....php?t=1506538 |
07-10-2018, 05:28 PM | #219 | |
Rep 10,473
Is this the part and dimension needed for OEM F30 Struts and F80 Caps? https://www.shapeways.com/product/CJ...li=marketplace |
