01-19-2013, 08:34 PM | #1 |
Rep 975
passenger head rest
I had my car in for the service bulletins a few weeks ago and they supposedly "fixed" the headrest.
However I have noticed that the drivers headrest is flush with the seat, but the passenger headrest is about an inch above the seat and I cannot adjust it lower. Has anyone else experienced this? |
01-19-2013, 11:34 PM | #2 |
Rep 1,892
See this thread:
http://www.f30post.com/forums/showpo...57&postcount=6 You can easily do this without removing the seat back like the original poster shows. |
01-20-2013, 06:31 AM | #3 |
Rep 975
Thanks, I don't see the torx screw that the poster is talking about, but Ill have a look. Im also wondering why the passenger seat headrest isn't flushed like the driver's side.
01-20-2013, 07:36 AM | #4 |
Rep 1,892
You shouldn't need to unscrew anything.
The 1 inch level is the minimum set by BMW. If you lift the driver side headrest up, you won't be able to drop it down to flush again either. Here is the procedure I followed, copied from another forum: "On the head rest rotate the round cover clock wise and counter clock wise back and forth on the right post until you can lift the round cover ever so slightly, on the opposite side of the notches with a puddy knife or something thin like that. When you lift the cover you will see a mechanical spring loaded mechanism. press that to wards the post while pressing in on the release button on the other post and press down on the head rest Before you press the head rest all the way down just in case you lifted the cover a little to high make sure you press it down. This is a temporary fix until somebody raises the head rest again Good luck cheers" |
01-21-2013, 11:02 AM | #6 | |
Rep 176
Good luck cheers vern |
