BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
proTUNING Freaks
      09-15-2018, 01:28 PM   #265
HB E90
HB E90's Avatar
60
Drives: 2010 E90 335i Space Gray
Originally Posted by YuminNuman View Post
EDIT: nevermind ... found the answer in a video. "Style 400M"..
Can anyone tell me what "style id" wheels these are?
These are on my 2017 340i xdrive (square setup, 225/45/18 all around, msport pkg, NO track pkg).
It's possible I may be using a second set of those for the summer, though I will probably go with a different (wider!!) style. Just put 4 blizzaks on them for the winter!
I just checked out a 2015 335i m-sport and it had the same wheels (400M)225's all around? I was like WTH? I thought all RWD M sports had staggered setup 255/40 in the rear? Even the OP says 8" front and 8.5" rear for the 400M. There were 2 other M sports on the lot and they both had 225/255 tires on the same 400M wheels. So I got out a tape measure and started measuring wheel widths. Sure enough on the car I was looking at had 8" all around and the others had 8.5's in the rear? The dealer was going to switch the wheels for me but the service mgr stopped it because the door sticker said 225's all around. I walked and said deal breaker and we were all bummed. I know I could just go buy some custom wheels and tires but when spending over $30k for a certified car with new tires I dont have another $2k+ to go out and do that. Help me understand the confusion why most M sports have 225/255 tires but not all apparently. I verfied it has the M sport pkg from the factory and is NOT an x drive
      09-16-2018, 04:58 AM   #266
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
All seasons tires (square), summer performance tires (staggered).
      09-16-2018, 04:10 PM   #267
juicy
juicy's Avatar
Drives: F80 M3, F87 M2
So what will be the widest rim that I can put on a f30 340
      09-17-2018, 09:01 AM   #268
HB E90
HB E90's Avatar
60
okay yes they had a fresh set of all seasons on it! This on a RWD Hot climate version? I'm learning that trying to find a used one that has just what you want is very difficult and confusing. This site is helping for sure. I'm not in a hurry so the search continues. Thank You
      09-21-2018, 04:50 AM   #269
Milkman670
Drives: 2018 330i F31 MSport II
[img]
View post on imgur.com
[/img]
I just checked out a 2015 335 m-sport and it had the same wheels (400M)225's all around? I was like WTH? I thought all M sports had staggered setup 255/40 in the rear? Even the OP says 8" front and 8.5" rear for the 400M. There were 2 other M sports on the lot and they both had 225/255 tires on the same 400M wheels. So I got out a tape measure and started measuring wheel widths. Sure enough on the car I was looking at had 8" all around and the others had 8.5's in the rear? The dealer was going to switch the wheels for me but the service mgr stopped it because the door sticker said 225's all around. I walked and said deal breaker and we were all bummed. I know I could just go buy some custom wheels and tires but when spending over $30k for a certified car with new tires I dont have another $2k+ to go out and do that. Help me understand the confusion why most M sports have 225/255 tires but not all apparently. I verfied it has the M sport pkg from the factory
Was it a xdrive?
      09-21-2018, 09:43 AM   #270
HB E90
HB E90's Avatar
60
Originally Posted by Milkman670 View Post
Was it a xdrive?
No, RWD 335i M sport.
      09-28-2018, 10:09 AM   #271
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
Here's a silly question. My car has the 18" 400M square setup (225/45/18) with all seasons.
Will my old Rial 17" winter/tire wheel setup from my 2009 328xi fit my '18? They've been in storage since 2014. I don't really want to make the trip to storage to get them if they won't fit. The tires are probably shot at this point but if they fit, I would put new winter tires on.
      10-02-2018, 08:26 PM   #272
ryan@calgary
Drives: 2018 440xi m-sport coupe
Hi, does anyone know if any 18" wheel will fit over the 2018 f32 blue M Sport brakes? I am having fitment issues with Style 67 rims, and not positive if its just the offset of 47 being the issue (easy 12mm spacer fix), or the diameter of the rim itself. The callipers look to be grinding the inside of the rim on of outer most edge of the calliper and not the front of the calliper which has be second guessing..
Thanks!
      10-29-2018, 02:44 PM   #273
bprevost
Drives: BMW 335i M Performance
I have 2014 F30 M performance, would the following fit?
235/40/19 19x8 ET32
265/35/19 19x9.5 ET35
Using this to figure it out:
http://www.rimsntires.com/specspro.jsp
Not sure what to make of this? Will I rub or not?
Suspension clearance: 100% clear (leaves even more room than OEM)
Fenders clearance:
REAR: Package 2 will stick out 17 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
FRONT: Package 2 will stick out 9 mm (0.4'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells clearance: Will fill out the wheelwell by extra 4 mm. Almost no difference
SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 60.7mph (97.7km/h): 1.2% faster.
      11-21-2018, 08:13 AM   #274
bmwmdistrict
bmwmdistrict's Avatar
Drives: 2020 X3M
2020 BMW X3MC  [10.00]
Hi guys, sorry I’m the FNG on the forums but I’m interested in getting gloss black M Sport 19” wheels that match these dimensions and offset:
19" Double Spoke Style 442 - 19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear
My question is that I read this is the common staggered set for RWD 3 series. I have a 2014 328i xdrive and I do not want any rubbing on the tires. Dealt with that on a different car with aftermarket wheels and it sucked. Can anyone vouch that this will not cause rubbing with those tire sizes?
Thanks in advance!!
EDIT: After doing more research, it looks like there should be no rubbing or issues as the above wheel widths and tire sizes are standard OEM spec. So thanks anyway!
      02-14-2019, 01:18 AM   #275
martinskovenboe
Drives: BMW F30 2012
Will it Rub - any experience?
Hi
I just joined this lovely forum since i joined the F30 club last month.
Need to get rid of my stock wheels and now i need the help from pro's!
I have come across 245/40-19 9,5 rims that i really would like to get on my f30 2012 stock edition.
Is it possible to have 9,5's in the front as well as in the back?
and what would be the right tire setup with no rub and most possible comfort?
Se the rims here
https://images.guloggratis.dk/62/197..._0_0_0_0_2.jpg
      03-09-2019, 08:41 AM   #276
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
A perhaps asked and answered, but would wheels from my F10/1 (OEM, 19x8 ET33 - square setup - with 245-40-19 rubber) fit a normal RWD F30 without issues, rubbing, etc?
F30.F11.E86.E90.E90.E36
      03-24-2019, 05:24 PM   #277
JustWatch
Drives: Bmw f30
Thank you very much for the information.
      03-26-2019, 10:37 AM   #278
Arun.Rahi
Drives: 2013 328i XDrive
I recently got a 2013 328i xdrive and the rims are pretty messed up from the previous owner. I was wondering if there are any cheap places to get a new set of factory rims from ?
      04-06-2019, 04:59 AM   #279
Wizz031
Drives: BMW f30
Hello... I have now on f30 2013 g. sedan, 17" 7.5j 225/50 et37.... I want to buy from my friend 18" 8.5j 225/45 et35 for all four wheels...is that ok and go on well or its not recommended? Thank for helping
      04-26-2019, 09:04 PM   #280
Rassclaht
Drives: 2015 228i xdrive convertible
Will 17 inch wheels fit my F31?
Hello all,
Just purchased an F31 Xdrive with M performance and M sport package. It does not have the M series brakes. Current wheels on it are style 403 with 225/40/19 ET 34 in a square set up.
Need a set of wheels / tires for winter. Will 17 inch wheels fit this car? Tire calculator says 225/50 should be a good fit. Tire rack claims a 17 inch wheel will fit the base model but not the M performance model. The extra sidewall height is good for our horrible winters What does the hive mind say?
Thanks!
      04-28-2019, 03:10 AM   #281
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Grey brake calipers and 17" will fit, blue M Sport (or other colored M Performance) brake calipers and 18" is needed.
      06-11-2019, 11:50 AM   #282
mission21
Drives: 2016 BMW 340i xDrive
Originally Posted by ryn004 View Post
Not sure if this has been shared before, but here is a list of all F30 wheels with factory tyre sizes and the usual wheel specs - https://www.carsaddiction.com/en/whe...?m=3series-F30
Very helpful, thanks!
      07-01-2019, 08:38 AM   #283
OlgKama
Drives: BMW F30 328i M Sport
Hello,
I'am new there and want to ask will this wheels fit my bmw f30 328i M sport with m sport brakes :
R19x8.5 ET35 5x120 72.6
R19x9.5 ET38 5x120 72.6
Also if it will fit are they will not scratch wheel arch ?
      07-18-2019, 08:52 AM   #284
sdjro
Romania
Drives: BMW F82
Hello,
I want to ask what tyre sizes are recommended for these wheels:
R19x8.5 ET35 5x120
R19x9.5 ET40 5x120
Car is 428 xdrive with KW V3 coilovers, thanks!
      08-08-2019, 05:11 PM   #285
gopackgo5
I have stock 18 inch wheels with a 225/45 sidewall on a 2016 340i and I would like to put more rubber on the road. I have an intake, charge pipe, downpipe and jb4 so it could definitely use it. If i put 19s on my car how wide a wheel and how wide a tire could I safely fit? I also was wondering what offset people had noticed kept the wheels flush with the body?
      01-23-2020, 06:42 PM   #286
smuudge2020
Drives: E93 320i M convertible
Hey everyone. My E93 M Sport Convertible has the standard 313 19" staggered alloys, which I love. Sadly, my rear left is completely shot, with a number of welds and now non repairable so I need to replace it or move to a different wheel all round..
Fronts are absolutely fine, rear right has 2 welds but been fine for the last 2 years so no reason to say its not got more miles in it. Bridgestones RFs all round with loads of tread..
My question is, (as I cant find a descent 313 rear without a HUGE hole in my pocket) will the 4 series 400M staggered 18" alloys sit ok on the car, I understand the offset is different but I cant find any pix of what the e90 looks like with these wheels on it!.
I can buy a good set locally so just need to know if I'm going to regret the purchase! Ultimately I need to get some trouble free motoring as the 313 has been frankly an absolute F'ing nightmare to live with!
Anyone fitted them on their e90 on here??
Cheers
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
