E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > DIY advice Oil Change
Reply
      02-06-2010, 11:30 AM   #1
Metalgear
Metalgear's Avatar
18
Drives: 530xi
Can anyone tell me. Where is the oil drain plug and the filer is located? I just bought a 06 530xi not from the dealer. Just want to know how to change it? I was searching for the oil filter under the hood no luck. I assume the filter is under the car somewhere and that it will involve removing some of the panels. Any advice/pictures/recommendations you can give would be greatly appriciated. Thanks.
      02-06-2010, 11:37 AM   #2
PINeely
PINeely's Avatar
Drives: 2013 535i, 2015 Tundra 1794
Search. There are threads all over the DIY section about this.
      02-06-2010, 12:05 PM   #3
Metalgear
Metalgear's Avatar
18
Drives: 530xi
Yes. that's why I post this for help. Did not find? DIY post on this subject.
      02-06-2010, 12:12 PM   #4
PINeely
PINeely's Avatar
Here's one for the e90. I don't know how similar the 3er oil change is to the modern 530 but it should help to point you in the right direction.
http://www.e90post.com/forums/showthread.php?t=4768
The process in my 2002 530i was similar to this so maybe not much has changed.
      02-06-2010, 12:15 PM   #5
Metalgear
Metalgear's Avatar
18
Drives: 530xi
Thank you!!!!
      02-06-2010, 03:00 PM   #6
bavarian19
bavarian19's Avatar
Drives: Car
After my scheduled maintenance is up, Ill be doing all the work myself. Oil changes are pretty easy, but free at the dealership is better.
Reply
e90post
