BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Hartge N55 F30 335i Engine Software Tune Yields +56HP / +59TQ for F30, F10, F25
      07-05-2012, 10:36 PM   #45
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Would this void the BMW warranty? Actually would they even come to know?
And what about the 0-60 and 0-100 times for the 335i with this tune?
      07-06-2012, 10:42 AM   #46
Alan l.
Alan l.'s Avatar
5428
Drives: 2020 F95 X5M Competition
Price drop from $1599 to $1299
Turner's website reflects this change. Still expensive but this is from one of the biggest and best Bmw tuners in the industry.
Alan
      07-06-2012, 09:45 PM   #47
RPM90
Drives: 340i M-sport AT
Originally Posted by jtuds View Post
What impact do these piggyback tunes have on fuel efficiency and the different drive modes?
I had GIAC in my 06 A4 2.0T. It's full software not piggyback.
My MPG increased by nearly 2MPG, driving it the same way day to day.
However, you get these tunes for one thing, POWER.
When you want and use more power, of course MPG will go down lower.
If your engine is developing 40hp and 50lb ft more than stock, then it will require more fuel to develop that power.
I prefer Full ECU software over piggyback as power levels increase.
This is one expensive piggy. It does appear to be an advanced piggy system as it plugs into various sensors, seemingly to take over the readings the stock sensors are putting out. It takes time and money to crack ECU protection codes, and perhaps this company didn't want to crack the ECU or couldn't. ECU tunes also use the OEM sensors, but they are taking the sensor readings by which to adjust maps, instead of using sensor readings and altering them to make the computer think all is well.
If this works in a different way, then I hope the manufacturer chimes in and explains.
Simple piggybacks are cool for modest gains around 4-5psi. The JB+ is one such piggy and it works great. I've driven a 135i with the JB+ and the added power is very noticeable, very. It increased boost by 4.5psi. over stock. The price is but a fraction of this thing.
With CAN tool and JB+ the cost is only $329!
Excellent price for the added performance, and the tool allows you read and clear codes before dealer servicing.
If there was one for the N55 that would be ideal for those who want more power, but want to keep it safe. It really does wake the engine up when you want it, and drives like stock when driven normally day to day driving.
      07-08-2012, 09:11 AM   #48
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
I think I'm going to try this out. I just worry about code clearing as this doesn't appear to have it. Will it leave a trace? There is not much info on it though.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      07-09-2012, 01:57 AM   #49
verbs
Drives: 2015 M235i
Originally Posted by m balla View Post
Aren't there cooling issues with the dinan? I can attest that the 335i m-sport with the ppk, pe is no where close to the power of the is even though they match up on paper. I would mos def do ic upgrade. I would just wait it out or do turbo upgrade.
I had a dinan stage 2 tune on my n54 e92 335i and never had a problem.
Originally Posted by csween86 View Post
For anyone interested, look into the Dinan stage 2 upgrade for the n55. It bumps power to 355hp and torque to 401 lb-ft.... There will eventually be a stage 3 as they mentioned that on their site. The stage two is like $2g's so a bit pricey, but they will match your warranty and BMW will acknowledge this tune and will still service your car hassle free.... Just saying.
This is NOT true. BMW and Dinan have fallen out of bed so to speak over the years and all BMW dealerships won't just overlook a Dinan tune if you have one. Even my dealership 3-4 years ago warned me about this, and so did the Dinan installer. Dinan and BMW are now competitors with their new performance product line, and BMW has zero incentive to place nice with Dinan.
Dinan's stage 3 tune on the N55 motor for the E90 model cars required $3000 in additional upgrades before labor/tax including an upgraded intercooler and oil cooler. Now you're looking at having to spend probably an extra $4000 on supporting mods, plus they charge an extra $500 on the stage 3 tune. $4500 for an extra 18hp? No thanks. Only if I was tracking the car would I spend the money on the oil cooler and intercooler (but not theirs anyway).
      07-09-2012, 02:01 AM   #50
verbs
Drives: 2015 M235i
Originally Posted by ybbiz34 View Post
AFAIK, there is no Dinan software currently available for the F30.
Their website incorrectly lists 2011-2012 335i sedans, but when you drill down on the view models section it says e90 only.
      07-09-2012, 02:06 AM   #51
verbs
Drives: 2015 M235i
Originally Posted by Balzz View Post
[and the engine tuning is unchanged below 70% throttle to preserve all factory driveability and emissions certification*.
I think this aspect is a let down. I want to feel that extra power in the low-mid range at lighter part throttle....not just 70% plus.
      07-14-2012, 10:26 PM   #52
RPM90
We all have our own likes and dislikes for power band.
I actually like the idea of having the greater boost come on later.
It's more like turbo's used to be, where the big power came once the revs were up. To me, it's easier to modulate the power at higher rpms, and thus easier to modulate power in the curves.
With modern turbo's and direct injection, we get nearly all available torque before 2000 rpm, and in the N55 there is a LOT of it. These modern turbo's power output is like a diesel. Just look at the dyno's, huge torque at low rpm that then fades off as rpm increases. Nearly opposite of how turbo engines used to develop power.
Having even more at that low of an rpm makes it harder to get a great launch, as it just ends up in wheel spin.
Having the power increase above stock as rpm rises, imo, should give easier launch will better power modulation at higher revs.
You may find you do like it if you get that tune.
      07-14-2012, 10:36 PM   #53
verbs
Drives: 2015 M235i
I think you might be confusing it? I think it means the throttle has to be mashed more than 70% of the way for the extra boost to kick in, but you'll feel it down low as long as you're flooring it.
If you've got good tires, traction shouldn't be an issue. I had no problem hooking with 380hp/420tq in my 2007 335i.
      07-19-2012, 11:36 AM   #54
bananachipz
Drives: F30 Mineral Gray 335i
Originally Posted by tojo_m View Post
Do you think that the f30 335i PPK that is due to be released in December 2012 would require the car to have the higher top speed limiter? I ask because I ordered my car and although I found it to be pretty fast, it did not seem overwhelmingly fast. While ordering, I thought I could always add the PPK later in December, but I ordered the "no lines" which means I don't have the high speed limiter
If not, I guess there is nothing I can do to make the car faster, while still preserving the warranty. Right? (I don't think Dinan will work out for me since it won't work with the warranty direct's extended warranty).
Option 840 (High Top Speed Limiter) on the F30 is just:
- remove the TOP speed limiter
- add Summer tires
That's it.
So, there *shouldn't* (IMHO) be any real technical limitation to the PPK, rather a recommendation from BMW due to the higher capable speeds. I believe some folks had the e90 ppk installed without the 840 option (I also think 840 on an e90 added the extra oil cooler - correct me if I'm wrong).
In any case, we won't know until it's released. I know they said December, but my sources say don't bet on it until next year.
      07-21-2012, 01:06 PM   #55
omar_liendo
Drives: F30 335i Melbourne Red
It looks great but I have always been skeptical about these sort of devices. Have a lot of you guys install them? Do they void the warranties? Can it really mess the car up?
      07-21-2012, 11:30 PM   #56
verbs
Drives: 2015 M235i
Bad tune can blow a motor (very rare), or be blamed for other engine/drivetrain problems by your dealer and then denied warranty coverage. It's a risk; many uninstall tunes when taking it in, some don't care. Every dealer is different with how they handle it.
      07-22-2012, 04:16 PM   #57
Walt
Drives: 2013 335i m-sport
Does the 335 ecu log boost pressure? If so, the dealer will always know there was a chip or boost controller on it if they bother to look.
      07-25-2012, 01:36 PM   #58
FotiosF90M5
Just learned that the 70% throttle only applies to diesel engines. Full power is available after 1500 rpm. Just spoke with turner and they are changing it on the site. I'm going to test this and burgers.
      07-25-2012, 02:07 PM   #59
bananachipz
awesome.. Keep us posted!
      07-25-2012, 05:21 PM   #60
FotiosF90M5
Will do
      07-25-2012, 07:29 PM   #61
bananachipz
Will do
unfortunately Burger doesn't have one that works with the F30 335 yet.
      07-25-2012, 10:41 PM   #62
FotiosF90M5
      07-26-2012, 10:29 AM   #63
bananachipz
you cheeky bugger!
      07-28-2012, 08:00 AM   #64
skymast
Drives: 2102 BMW 535
I am just coming out of a Porsche Turbo. There are a significant number of ECU Flashes that range in price from $700 - $2,000. The price variation is largely based on upgradibility (stage 1, 2, 3) and customization but on the low end you can get 70HP for $700 which is a great HP / $ price.
As far as I know, there are not any pig tail options.
I am wondering if the limited amount of tuning options for the BMW is specific to the fact that turbo engines are so new to BMW and if we can expect to see some of the major tuners focusing on BMW based on the proliferation of Turbo engines in the BMW lineup ...
      07-29-2012, 08:32 AM   #65
bananachipz
Cobb, Procede, Dinan, Hartge, BMS, Giac, and BMW PPK not enough for you?
The F30 chassis doesn't have a lot because BMW altered the DME on the N55 engine this year. If you owned an E90, there would probably be more tunes than your Porsche.
The F30 landed earlier this year. In that short time Hartge was released, JB is beta, PPK was announced, and others have stated they are working on it. Patience young Padawan...
      07-29-2012, 09:00 AM   #66
skymast
Sorry, this post was pinned to the front page and I thought it was for the 5 series .... In terms of the 5 ... I am only seeing Hartage and the very expensive Dinan right now.
335i ecu, 335i software, bmw 335i tune, bmw n55, bmw n55 ecu software, bmw n55 engine, bmw n55 engine software, bmw n55 engine tune, bmw n55 engine tuning, bmw n55 piggyback software, bmw n55 piggyback tune, bmw n55 software, bmw n55 tune, bmw n55 tuning, f30 335i piggyback, f30 335i software, f30 335i tune, f30 335i tuning, hartge n55, hartge n55 engine, hartge n55 software, n55 ecu, n55 engine, n55 engine ecu, n55 engine tune, n55 hartge, n55 hartge ecu, n55 hartge tune, n55 piggyback tune, n55 software, n55 tune, n55 tuning
