11-05-2022, 07:44 PM | #2 |
Rep 773
Either you have a boost leak, or the wastegate arm was not set correctly. It's kind of strange you almost hit boost target and then it falls off and can't maintain anything close to target
11-05-2022, 08:03 PM | #3 |
1296
Rep 3,534
Can you post the actual link to the log and that that datazip stuff please?
11-05-2022, 10:59 PM | #4 | |
Rep 214
I checked multiple times for boost leak. I am 99 percent sure that there is no boost leak now. How do we check for that wastegate thing? Your response will be highly appreciated. i have added some more logs in my topic too. Btw i dont have any codes before and after few pulls. Can it be still the wastegate issue? Last edited by Zinia; 11-05-2022 at 11:32 PM.. |
11-05-2022, 11:04 PM | #5 | |
Rep 214
https://www.bootmod3.net/log?id=6364...0b439ed7c5d873 Last edited by Zinia; 11-07-2022 at 11:03 PM.. |
n55david1295.50 |
11-06-2022, 04:32 AM | #6 |
Rep 773
Its a process using the scan tool. If you installed this yourself, and didnt use a scan tool to install the wastegate actuator, then that is almost def your problem.
11-06-2022, 05:35 AM | #7 | |
Rep 214
I,ll be grateful. I am running oem inlet currently. Last edited by Zinia; 11-06-2022 at 06:53 AM.. |
11-06-2022, 12:47 PM | #8 |
1296
Rep 3,534
Huge boost leak
11-06-2022, 01:33 PM | #9 |
Rep 7,611
Yeah its almost certainly a boost leak, not only because of the boost below target, but because the STFTs are pulling 25% fuel. So you are almost definitely leaking air after the MAF
11-06-2022, 01:56 PM | #10 | |
Rep 214
11-06-2022, 03:53 PM | #11 |
1296
Rep 3,534
No.. 100% not. You have a leak between the turbo and the throttle body. Likely at the intercooler and charge pipe or at the charge pipe coupler.
However the oem inlet is hurting your power capability.. but that's has nothing to do with your boost leak.
11-07-2022, 08:28 AM | #14 |
Rep 190,945
Sub'd for updates.
11-07-2022, 12:54 PM | #16 |
Rep 4,160
You already got all the advice you need. There is a boost leak - you're at 100% WGDC because your turbo is trying to meet target.
Get it to a shop or start checking the Chargepipe and IC connections yourself.
Mods: Yes.
11-07-2022, 03:18 PM | #18 |
Rep 190,945
+1
11-07-2022, 05:54 PM | #20 |
1296
Rep 3,534
More than that turbo will do safely and reliably over time.. about 22 to 24 max. If you have the proper supporting mods.
11-07-2022, 05:56 PM | #21 |
1296
Rep 3,534
The advice is fix your massive boost leak.
