BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Member's Car Journals > M performance exhaust... Is something wrong?
proTUNING Freaks
      11-10-2013, 04:22 PM   #1
alexgosh
Drives: 2014 335i M Sport
I just got my exhaust installed yesterday and I feel like it doesn't look right... I feel like it's too low but also what is inside? [IMG]http://i1349.photobucket.com/albums/...ps0bf9cdc4.jpg[/IMG][IMG]http://i1349.photobucket.com/albums/...ps9983c4cb.jpg[/IMG]
      04-13-2015, 06:22 PM   #2
jinnrice
jinnrice's Avatar
58
Drives: 2015 BMW 335i Xdrive
That's really low and sticking out pretty far. Who did it? I believe you can adjust where they hang to get the height right.
Estoril MUTHA Fn BLUE...II
      06-14-2015, 11:37 AM   #3
Nicolas W
Nicolas W's Avatar
Drives: F30 F87
  [0.00]
2017 BMW M2  [0.00]
  [0.00]
  [0.00]
Just take to the dealer to check out
      10-02-2015, 01:02 PM   #4
Ngnet
Drives: F10 535i msport 6mt/F15 x5 35i
Had the same issue, they just need to realign the mid pipe and muffler pipe correctly. There are no adjustments where the muffler hangs. If it's not aligned correctly your mid pipe will also be misaligned and start hitting the X bar framing under the car and you'll here a very loud rattle at some RPMs.
N26Ghost496.50
      02-19-2017, 12:13 PM   #5
iMinLuv
iMinLuv's Avatar
Drives: BMW 340i M-Sport track pkg
Agreed
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
      05-27-2017, 01:12 PM   #6
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
Yea way too low and out.
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport
      11-14-2017, 04:57 PM   #7
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Strange photos aren't coming up for me.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      01-28-2018, 08:11 PM   #8
silverf30x
silverf30x's Avatar
Drives: 2014 BMW 335i
There's a dimple where you are supposed to cut the original muffler off but I found it would have been to short. It sounds like they cut it longer to be careful but I cut it an inch closer to the muffler (or to the back of the car) from the dimple. I can't see your pictures but the tips are adjustable too, so you may be able to push them in.
      10-31-2018, 10:56 PM   #9
ghinshell
ghinshell's Avatar
Drives: 2016 340i M Sport 6MT
2016 BMW 340i  [0.00]
I took a picture of my friend's for comparison; he just got his installed a couple weeks back.
Yours looks lower than his. Hope it helps.
Edit: OP was 5 years ago
      03-27-2019, 07:55 PM   #10
jcordier
jcordier's Avatar
Drives: 2013 black F30 N55
Look underneath and there should be a screw that you can loosen in order to slide the tip back.
J. D. Cordier
      05-19-2019, 10:03 PM   #11
B58
B58's Avatar
558
Drives: 922 Turbo
It's way too low I had the same issue even when I cut the dimple. I had to cut it another 1/2" to help it sit higher. I even thought about having a muffler shop cut the hangers and shortening it a little/re-welding it to help it sit slightly higher, but it's sitting fine now
2024 X3 M40i
2014 BMW M5
