BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > EPS, SZL and SAS question.
      11-18-2023, 12:23 PM   #1
NDA601551
Drives: 2014 BMW 328i
Installed used EPS, used SZL with its original SAS
This is what I believe to be needed:
EPS vin/vo coded and calibrated
SZL vin/vo coded
SAS calibration, issue is one direction reads -19xx and the other direction reads -9xx. Center was triple verified.
All are used parts
However after install, EPS worked, SZL steering wheel buttons and such function. But, still have Chassis stabilization: drive moderately, Steering: Drive moderately, Cruise Control malfunction.
All presumed to be due to program/coding and calibration/ reset.
Am I some what correct as to presuming these issues to be the case?
Any insight would be greatly appreciated!
      11-18-2023, 12:27 PM   #2
TheNine90
Drives: bmw
What is the actual fault codes?
      11-18-2023, 01:45 PM   #3
NDA601551
Ret SFC
From protool
483c2 eps control unit steering angle fault directional stability
48002c Icm acc interface dsc
D01c0c no message actual power rack current position
D01b26 no message current position
D01b2a signal invalid transmitter eps
D019bf no message actual steering torque driver actuator
D02d07 signal actual steering torque driver actuator invalid
480ab8 dsc control unit vehicle start with moving vehicle or driving condition unknown
4823c2 eps control unit steering angle initialization fault, directional stability not learned
Yeah I think that’s all. LOL
      11-18-2023, 01:58 PM   #4
TheNine90
Drives: bmw
Did you initialise the steering?
      11-18-2023, 02:28 PM   #5
NDA601551
No Sir, haven’t done so. I am a diehard E46’er since 2002. My first venture of into the f series. Have ESys, in process of downloading ista D. To plunk around a possibly figure it out myself. Another option would be for someone remotely perform these operations. Really looking for others takeaway of what I’ve stated, to see if my logic is on the right path.
      11-18-2023, 02:30 PM   #6
NDA601551
Also have “Protool”. But not as of yet too deep into what it is capable of.
      11-18-2023, 09:12 PM   #7
TheNine90
Drives: bmw
If you have ISTA you can do it. I can help you remotely if interested. Are you using enet cable?
      11-19-2023, 07:57 AM   #8
NDA601551
I’ve been attempting to dl ista without any luck on the mega sites. I have a dedicated laptop and the enet cable. How does that work, remotely that is?
      11-19-2023, 08:03 AM   #9
TheNine90
Drives: bmw
Yes, using ENET cable only
      12-09-2023, 09:58 AM   #10
biggaz101
biggaz101's Avatar
Drives: bmw f31 330d
Hi I wonder if anyone could shed any light on my problem or sort it out. Car was in a small bump someone caught the front driver corner but in doing so clipped the tire and turn steering wheel and wheels no one was in the car when this happened no power on either no visible damage to the steering but orange steering warning light on. And no eps cleared fault codes expecting it to start working but nothing fault code is 4823A1 EPS control unit internal fault
      12-09-2023, 10:43 AM   #11
TheNine90
Drives: bmw
This is most likley a faulty eps. Better replace it
      02-19-2024, 10:57 AM   #12
Merlino31
Merlino31's Avatar
Italy
Drives: BMW f31 320 modern
SZL vin/vo coded
All are used parts
Did you solve the issue? I have a similar issue on a friend's f36
BMW f31 320d Modern 6MT
      04-16-2024, 08:19 AM   #13
Grateful_Newt
Drives: 2015 BMW 320i
Hey I know this has been awhile, but I really need some help. I should have ISTA P/ISTA +D up and running later today. I have the same situation as the other guy you offered to help. Replaced my EPS unit, and need to program/initialize it. Thank you!
