10-12-2018, 08:12 AM | #89 |
Rep 2
Hello Shawnsheridan,
I'm a bit confused. I own an '10 e92 LCI with combox. I see ConnecteDrive menu in my CIC, but actually can't see any app and bmw online doesn't work. I would like to have bmw apps, and whatever I can.. Could you please help me explaining what needed? Many thanks |
10-12-2018, 08:14 AM | #90 | |
Rep 40,824
10-12-2018, 08:26 AM | #91 |
Rep 2
10-12-2018, 10:57 AM | #92 |
Rep 40,824
No. You would code Head Unit and Combox. PM sent.
11-11-2018, 10:32 PM | #94 |
Rep 40,824
No. Totally different and far more expensive. I replied to your same PM.
12-04-2018, 02:15 AM | #95 | |
Rep 1
I generated a ‘Lifetime’ FSC code following a DIY a couple years ago... can the same software be used to generate the FSC code required? Also I scanne through this post and count see where to enter the FSC code in E-Sys? I would have PM’d but I don’t have the privileges! Thanks in advance Alex |
12-04-2018, 07:29 AM | #96 | |
Rep 40,824
01-01-2019, 02:42 PM | #97 |
Rep 5
Hi shawnsheridan
I have read the way to do it but just to be sure as I am beginner with BMW and coding is on a F10 with navi pro 609 and combox with BT is possible to ad 6NR? My car was made in October 2010. |
01-01-2019, 02:51 PM | #98 |
Rep 40,824
01-02-2019, 06:40 AM | #100 |
Rep 40,824
You can add 9C. PM sent.
01-30-2019, 05:00 AM | #101 |
Rep 5
hi all, i have a f20 118i 2015 with hu_entrynav, and i'm trying to code bmw apps, i suppose i need a fsc code but i didn't understand where to get it and then what i need to code exactly, can someone of you help me pls?
thanks a lot |
01-30-2019, 06:33 AM | #102 |
Rep 40,824
PM sent.
03-01-2019, 08:03 PM | #103 |
Rep 12
CIC keeps rebooting
I have a CIC.16 and one of those lucky ones that don't need the FSC for apps activation I believe.
I have FA_WRITE the FA/VO with $6NR and then SG_Codieren to CIC and Media. The CIC Head Unit now shows BMW Connected Drive with Apps Sub Menu. When I connect the phone using the USB in armrest and start the "BMW Connected" App on the phone, I see "BMW Apps Loaded" on the CIC. And then it reboots, it does this every time without fail. Tried two different genuine Apple USB cables with same results. Any ideas?. ALso checking the SG_Codieren Job on the CIC and media doesnt need to have any MAN or TRC files correct? Thanks |
03-01-2019, 08:25 PM | #104 |
Rep 40,824
Is CIC.16 v.41.0 firmware?
03-01-2019, 08:28 PM | #105 |
Rep 12
03-01-2019, 08:30 PM | #106 |
Rep 40,824
No idea. I don't do any E-Series work myself.
03-02-2019, 12:00 AM | #107 |
Rep 12
CIC keeps rebooting
Hi Shawn,
I have tried all the tools I have got, except ISTA, cant seem to see beyond the CIC.16. Anyway the question is, assuming I have the correct version what could I be possibly doing wrong to have the system reboot like that? I am not sure if the Coding I am doing is correct, especially when some folks are saying I need to code with an empty MAN file. Also how do I validate what version of Daten file I have ? (If you know ) How is it done in the F series anyway? Thanks again. |
03-02-2019, 02:51 AM | #108 | |
Rep 40,824
E-Series or F-Series, it is just VO Coding CIC and CMB_MEDIA Modules for 6NR. Car needs v.41 firmware, of newer firmware combined with a 9C FSC Code. And make sure 6VB is not in FA.
03-17-2019, 12:08 PM | #109 |
Rep 11
Hi all,
Can somebody confirm to me if either of these 2 VIN numbers support BMW Apps? They both have ConnectedDrive in the menu. P709274 production date 06.15 VZ29629 production date 07.14 Thanks! |
03-17-2019, 02:26 PM | #110 | |
Rep 40,824
VZ29629 production date 07.14 - Possible
