05-06-2013, 07:24 AM | #3566 | |
Rep 1,130
Drives: '16 340i AW MSport
or are you still missing the inner tail pipe? |
05-06-2013, 01:10 PM | #3567 |
Rep 169
05-06-2013, 01:18 PM | #3568 |
Rep 169
So, not sure what happened, but after last night's coding (DRL stuff), I am getting this engine light:
I have the car VO coded from 6NH ---> 6NK for enhanced BT. It works fine. But, I am getting this engine symbol in my dashboard while driving...I checked the iDrive vehicle status for errors - nothing. So, I think I am going to reset everything (still keep the 6NK). Can someone please confirm how to reset all the values to defaults? AFAIK, I just right click on the top folder with [VIN] and click code. Please advise |
05-06-2013, 03:19 PM | #3569 |
Rep 239
Everytime i put my car in reverse and the pdc is beeping it stays beeping, even when i put it in neutral or 1st gear. Is there an coding way to turn this off? So it only beeps in reverse and stop in N or 1st
05-06-2013, 04:06 PM | #3571 | |
Rep 1,892
You might try just VO coding the REM module first. Right click on the REM CAFD (not the underlying one) and instead of selecting "Read Coding Data", select "Code". That will reset the REM back to the factory settings. if that doesn't fix it, they you may want to do them all to see if it clears your CEL. |
05-06-2013, 04:16 PM | #3572 | |
Rep 145
Drives: F30 320ed
Which CAF are the parking sensor folders in? |
05-06-2013, 05:31 PM | #3573 | |
Rep 169
05-06-2013, 06:49 PM | #3574 | |
Rep 1,892
In REM, there are 6 PDC sections, 3200, 3201, 3202, 3203, 3204, and 3205. I looked around a bit and saw some potentials: REM / 3203 PdcParkMasterVar : V_SCHWELLE_1 & V_SCHWELLE_2 look to be speed thresholds. D_SCHWELLE_1 & D_SCHWELLE_2 look to be distance thresholds. If you are up to experimenting, please post your results! |
05-06-2013, 09:34 PM | #3575 | |
Rep 169
Is there a way in Esys to clear errors? I hope I don't have to take it to the dealer |
05-06-2013, 10:10 PM | #3576 | |
Rep 40,884
Assuming the fault condition no longer exists, to clear the fault code. 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
05-06-2013, 11:01 PM | #3577 | |
Rep 169
I tried to do this but since I have reset the car, I cannot establish Ethernet connection! :-( Is it because I reset and it somehow disabled the Ethernet connectability? I am going to also check if the cable is good. Any ideas? I have checked my pc. rebooted. Ethernet card settings are ok. Automatic IP address assignment. I turned on and off the car a few times. Not sure what's wrong :-((( |
05-06-2013, 11:03 PM | #3578 | |
Rep 40,884
I would make sure the cable is good and making a good connection on both the OBDII and Ethernet sides.
05-06-2013, 11:12 PM | #3579 |
Rep 169
I did IPConfig in the command prompt,
shows me: Autoconfiguration IPv4 address: 169.254.197.139 then I pinged that IP, it pings no issues. But I can't connect :-( |
05-06-2013, 11:19 PM | #3580 |
Rep 40,884
Is that the IP for your LAN Adapter or the Car? If the LAN Adapter, then I still say you have a problem with your cable.
05-07-2013, 01:17 AM | #3581 | |
Rep 169
After remaking the cable, I could connect and follow the tool32.exe procedure as you indicated. Worked like a charm! Engine checklight is off. Now, I just have to recode all the parameters and hope the CEL doesn't come on. Otherwise, Rinse & repeat until I find the parameter that causes a CEL. Thanks Shawn! |
05-07-2013, 04:40 AM | #3582 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = sl_l REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = sl_r REM > 3062 > MAPPING_TAGAHRL_H2_L_OUTPUT = sl_2_l REM > 3062 > MAPPING_TAGAHRL_H2_R_OUTPUT = sl_2_r Last edited by avgor123; 05-07-2013 at 07:16 AM.. |
05-07-2013, 09:30 AM | #3583 | |
Rep 40,884
05-07-2013, 10:49 AM | #3585 |
Rep 239
For some strange reason i cant connect via VIN anymore. The last time ive coded something was last week. And today the vin box in esys is greyed out.
The other connections are available exept VIN. Where the VIN should be it now says no ZGW available When i try ZGW_SEARCH it says MSWINSCK.ocx is missing or invalid. But the file is in the same folder |
05-07-2013, 11:38 AM | #3586 | |
Rep 1,892
To keep live/internet, you will have to remove BMW Assist from the VO. |
