07-14-2015, 02:41 AM | #45 |
Rep 4,325
bummers, i was hoping stock w/GSR tune had no issues. i hope GSR is going to resolve this...
07-14-2015, 09:22 AM | #46 |
IG @bmwF9xG80
3813
Rep 7,593
teapain any videos of how the car sounds idle and at WOT ?
60-130mph 6.5s X4M #HCP
07-14-2015, 10:34 AM | #47 |
Rep 577
Guys, I have been doing a lot of research on this. It appears the Engine is prone to developing a stutter as stock (http://f30.bimmerpost.com/forums/sho...d.php?t=873019). And that tunes amplify the effect. I know of stutters in exactly the same place (around 3000rpm under load and medium to hard acceleration) with various tunes including this one.
There are various items that probably should be looked at, cleaning MAF, Injectors, PCV, and most importantly chargepipe's and their seals. Some folks have changed coils and plugs, but that seems to be less of a fix. I also have a suspicion that once the car gets a few miles under its belt some carbon or dirt build up has an effect on how the car transitions from normally aspirated to boost. The crank case ventilation system is very complex. I think something may be going on here. Speaking to the guys that provided the DV+ (they have a lot of experience with the newer VW/VAG group engines that suffer with this), apparently the PCV can also be a real PITA. |
07-14-2015, 11:58 AM | #48 |
Dream crusher
984
Rep 2,421
Wow. Great discovery. How the hell do we clean the injectors? It's pretty much replacement, isn't it? I mean we could run some techron, I guess. Damn, back to the drawing board. Thanks again for the update.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-14-2015, 01:09 PM | #49 | |
Rep 129
Thanks for posting this! I am experiencing the stuttering issue intermittently as well. |
07-14-2015, 11:49 PM | #50 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Nice to hear it's not the tune that's the cause and seemingly more an annoyance ..
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-15-2015, 02:58 AM | #51 |
Rep 368
07-15-2015, 03:17 AM | #52 |
Rep 1,436
hey man i think you have carbon build up problem had this stutter on my previous car with bms st.1 although after removing the bms , the car seemed smoother but sttuter was still there so i got system cleaner and did 2 tank cleans then with injector sprayer spayed in intake directly. problem was gone. Hope it helps
07-15-2015, 11:12 AM | #53 | |
Rep 577
You put it in with a full tank? With this being a direct injection engine I'm not so sure how the intake/valves are effected. I don't think that much? Also what was the spray cleaner you used? And where did you spray it in? Before the MAF? In which case it went through the turbo, intercooler and Chargepipes too? |
07-15-2015, 12:26 PM | #54 |
Rep 1,436
I use what we have in my country gunk, cyclo ect. any American stuff that's for trucks so it can be concentrated. i pour it on more than half or half then empty tank and do it again. then
i got injector sprayer i use known brands not cheap chinese stuff. open intake spray quarter can then turn car on and press pedal to remove all that gunk its all black stuff coming from exhaust. as for maf we don't have maf cleaner so i use carb or alcohol but that's on your own risk, get MAF cleaner I'm sure you'll find it in usa. lastly open chargepipe from throttle side and spray throttle cleaner on throttle body you'll find it dirty as well. if you can take it off but that's pita so it's up to you. Hope it helps, I'm starting to get stutter between 2.5 to 3 k rpm but that's a first in this car il do a system cleaner shot |
07-15-2015, 05:07 PM | #55 |
Rep 3,258
MAF cleaner is pretty easy to find. I have a can that I use on my SS. I don't know how the BMW unit is, but you can use a qtip and clean the wire sensors GENTLY as well if the design is similar. I have to dissect my GC to learn this stuff at some point but right now I just hit the button and go
25% 3M Tint| |
07-15-2015, 05:40 PM | #56 | |
Rep 577
I did it and it certainly helps. I also just used techron fuel system cleaner in my tank. Early on yet to be sure, but so far it has done the trick. I got the car upto temp and also did some high rev runs. Car is pulling strong and smooth. I plan to put some cleaner (seafoam) through the induction and vacuum lines per the can instruction. Even though the car is running great I got a can with the techron so going to give it a go. Definitely give the fuel system cleaner a go though. |
07-15-2015, 06:50 PM | #57 | |
Rep 3,258
25% 3M Tint| |
07-15-2015, 07:01 PM | #58 |
Rep 577
My car has just gone through 10k miles. Was serviced at 8k if I remember rightly and there were no issues then.
I'll give it some time and a dyno before I say everything is 100% |
10-22-2015, 08:48 AM | #59 | |
Rep 2,577
10-22-2015, 05:03 PM | #60 |
Dream crusher
984
Rep 2,421
EDITED
IG: @bmwdoubles |
10-22-2015, 11:35 PM | #61 |
Rep 261
^ Thanks for the tip. I'm just starting at 65k miles.
2014 BMW F30 328i - Base line 8AT, Alpine White, metallic black roof, Megan Racing CF decklid, CF canards, CF eyelids, CF rear diffuser, matte black kidney grills, gunsmoke tail lights/reflectors, VMR 721 Hyper Silver 19x9.5/19.x8.5, 5mm spacers all around, Bilstein B8s, Injen CAI, H&R Sport Springs, muffler-deleted quad pipe, 20% 3M rear tint, M Performance Pedals
10-23-2015, 10:34 AM | #62 |
Rep 790
have you ran it at the strip yet??
any plans to do so?? my camaro put down also exactly the same numbers but a tad higher hp and ran a low 13 @ 104 ish at the track. But that was at 3250 raceweight too.
2010 335i M sport
2008 328i 2006 325i 1995 Z28 6spd - 377rwhp rip |
10-23-2015, 10:39 AM | #63 |
Rep 790
2010 335i M sport
10-23-2015, 03:02 PM | #64 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
