BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Touch controller on business navi
Studio RSR
      07-18-2017, 06:42 AM   #1
macs
macs's Avatar
Italy
Drives: f31
Hi everybody, did somebody retrofitted touch controller on business HU?
Is it possible or only on professional unit it will work?
Thanks
Macs
      07-18-2017, 11:21 AM   #2
Tavicu
Romania
23
Drives: F31
From what i know it is possible but not worth it!
Better and cheaper method: https://www.ebay.com/itm/132160080493
      07-18-2017, 12:22 PM   #3
macs
macs's Avatar
Italy
Drives: f31
Thanks, but this doesn't have the touch function.
I already have the knob and the control unit but, before disassemble the car, I'd like to know if it will work or there's no choice at all.
Macs
      07-18-2017, 06:25 PM   #4
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
The touch function sucks in my opinion. It's too slow. I never use it.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      07-19-2017, 12:39 AM   #5
Tavicu
Romania
23
Drives: F31
Macs
The touch function will work only on NBT.
So you have to change the Head unit too with NBT or NBT EVO in order to have the touch working.
      07-19-2017, 02:33 AM   #6
macs
macs's Avatar
Italy
Drives: f31
Understood, thanks. I will look forward to change the whole unit.
      07-19-2017, 04:34 AM   #7
HFW003
HFW003's Avatar
Australia
5683
Drives: 2024 M340i xdrive
It's yet another gimmick in these cars, wouldn't even bother if I were you.
      07-19-2017, 05:12 AM   #8
jalami
Drives: f30
I retrofit touch idriver with HU_ENTRYNAV.
It works perfect, You have to code if you want to use touch.
      07-19-2017, 06:57 AM   #9
macs
macs's Avatar
Italy
Drives: f31
This is a very nice news, I have HU_ENTRYNAV either, how did you code it?
Thanks
      07-20-2017, 04:22 PM   #10
jalami
Drives: f30
Thanks
HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER set to aktiv
HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH set to aktiv
      07-21-2017, 01:06 AM   #11
macs
macs's Avatar
Italy
Drives: f31
Thank you Jalami, yesterday I tried, I've installed controller and control box, then coded the four lines with E-Sys.
Controller is working perfeclty but, unfortunately, exactly like the OEm one, this mean I don't have touch functionality.
I don't understand where the problem is, the controller lights up and works correctly but I don't have the controller line in the settings menu.
In E-Sys I see the TBX in the ECUs tree but with all black dots, maybe I have to inject the CAFD in the TBX?
      07-21-2017, 11:40 AM   #12
macs
macs's Avatar
Italy
Drives: f31
Ok, the problem was the one from my previous post, I injected CAFD on the ECUs and everything now is working with touch function.
      07-22-2017, 12:22 AM   #13
Tavicu
Romania
23
Drives: F31
Thanks
Nice. Did not know you have entrynav
Top tip: you can also change the display to the bigger one.
      07-24-2017, 02:25 PM   #14
gpdrama
gpdrama's Avatar
Greece
Drives: F30 316i
For us having the entrynav, will the touch function work if we just put the new controller and just fdl code, or the touch module ecu must be installed?
Όμοια γάρ ως επί το πολύ τα μέλλοντα τοις γεγονόσι.
Ευριπίδης, 480-406 π.Χ.
      07-25-2017, 02:18 AM   #15
macs
macs's Avatar
Italy
Drives: f31
Also the TBX ECU has to be installed to have the touch function. Without this you only have same function as the OEM one but with larger knob.
      07-25-2017, 02:24 AM   #16
macs
macs's Avatar
Italy
Drives: f31
Nice.
I know, it's alreay on my to do list, after folding mirrors and surround view cameras.
The only doubt is about the cameras, someone say that will not work with Entrynav and I must upgrade to NBT, someone else say tht it will work, I 'don't know.
I already have the hardware, only miss the wiring, as soon I found it I'll try and see if I have to install NBT also, if not I will upgrade only the screen for sure.
      07-25-2017, 04:42 AM   #17
Tavicu
Romania
23
Drives: F31
On the online configurator you can select the option without adding professional navigation. Don't know if that helps you
      10-17-2017, 03:25 PM   #18
macs
macs's Avatar
Italy
Drives: f31
For everybody's information, finally I retrofitted surround view cameras on HU_ENTRYNAV with small 6,5" and everything works as OEM, I'm very satisfied. Only the screen should be upgraded, as soon I find one pricey.
      04-23-2018, 05:01 PM   #19
Minims
Drives: F54 Cooper S
Hello macs
I have the same iissue, Can you tell me how to inject CAFD in the TBX via esys. I am still new with this software ?
Thanks a lot.
      05-12-2018, 04:39 PM   #20
macs
macs's Avatar
Italy
Drives: f31
Originally Posted by Minims View Post
Hello macs
Thanks a lot.
Hi, sorry for delay I've been out for a while; to answer you question: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. that's all
