BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Revs dip below 500 RPM during idle in 335i
      02-06-2015, 03:51 PM   #1
richie_s
Drives: 335i x drive M sport (F30)
When the car's all warmed up, it starts to shake a little for a few seconds and the revs drop to as low as 300-400 RPM. Only happens after being in idle @ neutral for about 30+ seconds. Anyone else have this issue with their 335i?
I'm sure I'm not abusing my car because I do everything I can to keep it running nicely
The picture here was actually caught while the revs were rising up from being at about 350RPM.
(Traction control was off because I had to make it up my icy driveway!)
      02-06-2015, 04:30 PM   #2
DTP1980
DTP1980's Avatar
Drives: M5 F10 LCI Monte Carlo Blue
If it sounds smooth, it's usually not a problem. Side of effect of decent engine design, parts and management.
      02-06-2015, 04:32 PM   #3
kingmonkey8
Drives: BMW 428i
Could be the coils.
      02-06-2015, 05:05 PM   #4
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Happened to me before, took it to dealer explained what happened like what you described(it shakes at idle) to the guy. Fixed within 3 days. I am not sure what they did but I noticed a new software on my nav.
G05 - M Performance roof spoiler
      02-08-2015, 01:11 PM   #5
DTP1980
DTP1980's Avatar
If there is no misfire and antistall isn't kicking in, what exactly is the problem? There is no mechanical reason why this is a problem, unless caused by an actual problem.
      02-08-2015, 01:39 PM   #6
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
do you have bms intake?
Docrace 6266
      02-10-2015, 07:03 PM   #7
Shazsta
Drives: 2013 335i xDrive
I'm just a weekend diy mechanic but I don't see why it would be a problem.
      02-12-2015, 05:13 PM   #8
richie_s
nope, completely stock vehicle
      02-13-2015, 06:48 AM   #9
jwilly
Drives: They're all white now.
Vacuum leak.
That's a lot of white
      02-14-2015, 03:28 PM   #10
ji99lypuff
Drives: 2014 bmw 328xi
I read this post and have been looking ar my idle the past couple days and it never gets that low. Even after ive driven it a while.
      02-21-2015, 05:22 PM   #11
34.50
34.50's Avatar
Drives: 2013 335i xDrive Sport Line
Take it to the dealer OP. My car starts at 1k+ RPM, and drops down to 750-800 RPM for idle. I live in upstate NY, and it has been COLD the past week (-15 F in the morning). Even though my car is garaged and car starts perfectly fine, it does take a while to warm up.
2013 BMW 335i xDrive Sport Line
      03-28-2015, 04:20 PM   #12
richie_s
Alright, I've finally resolved the issue. I gave the car a good "italian tuneup" a.k.a. revving up the engine to blast away carbon deposits and things seem to be running smoothly now. Idle is completely smooth and the low-end torque is more prominent. The engine runs a little smoother.
This makes me think that the rough idle was due to carbon deposit buildup blocking the flow of fuel from direct injection.
All I did was warm up the car for 15 minutes by driving slowly around town and then hopped on the freeway in 3rd gear for a good non-consecutive 30 minutes. The revs were at 4,500 at 70 miles per hour. I exited the freeway and let the car idle every now and then so it wouldn't overheat and hopped back on and continued after the oil temp drop a little.
      03-28-2015, 04:23 PM   #13
richie_s
nope- completely stock. I'm guessing the rough idle was just caused by crap loads of carbon buildup. My daily commute is really short and my car often sees temps below freezing, so there's no surprise there. I also rarely stretch its legs... i keep the revs below 3,000 RPM 99% of the time.
      03-28-2015, 04:35 PM   #14
M-terkait
M-terkait's Avatar
Kuwait
209
oh ok everyday i extend my 5 km to work to 10 km trip just to go from 70-190 kmph almost everyday i do it
Docrace 6266
      03-28-2015, 08:07 PM   #15
richie_s
Maybe I should find a longer commute and do a 0-100 kph test run every day from now on to stop this from happening again
      03-28-2015, 08:17 PM   #16
richie_s
you should watch out for carbon deposits too. I live in a cold area just like you (frequent morning temps of single digits or negatives) and I'm more than 100% sure that the extreme cold mixed with my short commute lead to nasty carbon buildup that ruined my idle. it's better to prevent the problem than to fix it.
now I use fuel system cleaners and run my car really hot (5k RPM) every now and then to blast out the carbon deposits. just make sure to switch out your oil and oil filter regularly because some carbon chunks get dispersed in your oil.
I'm so glad I found out about these techniques
