BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 12v socket
      10-04-2014, 04:45 AM   #1
BMKoges
BMKoges's Avatar
Drives: 420d M Sport
12v socket
Hi, I would like to add a 12v socket in the boot of my 420 coupe, on the right side the panel pops off and battery is here, how easy is this? Anyone done it?
I believe extended storage option comes with boot socket but don't know where it's located.
Any help/advice great fully received
      10-04-2014, 09:00 AM   #2
Fronzdan
Drives: '24 M240 xDrive
It should be very easy, just be sure to use one with a fuse.
      10-04-2014, 09:25 AM   #3
chazmink
chazmink's Avatar
Drives: 2013 328i M Sport
Like Fronzdan said, it should be easy. You can pick up a tap a fuse pigtail at your local auto parts. This lets you use an existing fuse slot while giving you an extra fused lead. For a power outlet I suggest you go with 20 amps. Make sure you have a good ground.
Good luck with this.
Best,
Charlie
2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp
      10-04-2014, 11:16 AM   #4
BMKoges
BMKoges's Avatar
Thanks guys
      10-05-2014, 03:56 AM   #5
BMKoges
BMKoges's Avatar
If I had extended storage option I believe I'd have got a 12v point in the boot/trunk. Anyone know where they locate this socket?
      10-07-2014, 02:29 PM   #6
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
I have '14 F30 and have a 12v cigarette lighter-like socket in my trunk. It is located on the driver's side (left hand as you look forward) on the inside of the recess above the "shelf" and ahead of the taillight assembly.
Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      10-11-2014, 02:03 PM   #7
BMKoges
BMKoges's Avatar
Great job RSnic
Many thanks bud
