BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Coding now working on latest SW updates!!!
Studio RSR
      04-12-2015, 06:06 AM   #23
MarkG_M5Comp
Supreme Being
MarkG_M5Comp's Avatar
Drives: M5 Comp
Just recoded everything this morning!
Furthermore, this latest incarnation has resolved my issue where I couldn't connect with my new laptop(s)....
This is truly a revaluation and huge thanks to Jay for sending me the links and bringing the resolution to me... there is definitely a favour owed.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
      04-12-2015, 06:15 AM   #24
JonD
Drives: 1 Series Coupe, M Sport
Originally Posted by SkyJawa View Post
Then for step 8 you must be double clicking the esys premium shortcut so its already installed. go to control panel and uninstall it, then double click on the msi installer again and re-install it.
As I said, I've done that several times over, just does exactly the same
      04-12-2015, 06:47 AM   #25
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
Have you tried opening eSys and removing the link/path to the token (options/settings/est)?
In thinking if there is nothing in the box it may think it needs to create one. If there is a token saved in C:\data delete it.
Also, you must have .NET. v4 installed as well.
      04-12-2015, 06:52 AM   #26
JonD
There should be nothing saved, I've uninstalled and reinstalled
What's .NET.V4
I've had the previous version working fine, it's just this version of 3.24.3 and the launcher doesn't follow the v9 instructions for some reason.
edit : for some reason there was a token file created in C:data, detected that the ran the installer etc again and bingo !
      04-12-2015, 06:58 AM   #27
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
What's .NET.V4
I feel your pain - I've had so many issues trying to get the software working on a new pc - but this latest a version has fixed it all.
Since you've installed/uninstalled just delete the whole data folder (uninstall doesn't delete this).
Just google Microsoft .net or go to Microsoft.com/net/downloads - .net is the software framework required to run lots of windows programs.
Good luck
      04-12-2015, 07:01 AM   #28
JonD
Cheers Mark, see my edit above
      04-12-2015, 07:18 AM   #29
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
Boom, nice one.
      04-12-2015, 08:22 AM   #30
JonD
Originally Posted by JonD View Post
bingo !
False alarm
Only the initial time you first run it to set it. After that it just runs esys. The pin will then only be asked for when you select to edit the cafd/ncd.....
Now tells me the pin I've entered is wrong.....WTF
BMW could you have not just left it alone.......
      04-12-2015, 08:24 AM   #31
SkyJawa
SkyJawa's Avatar
3716
Drives: F10 530d
Cool.
Did you have a previous install as when you uninstall it doesn't delete the data directory, for a clean reinstall you have to delete it manually, which assuming using default location would remove previous tokens too.
Now get coding!
Edit arse! Literally uninstall and delete everything including c:data, and start again....
What laptop/os?
      04-12-2015, 08:31 AM   #32
JonD
Cool.
Now get coding!
What laptop/os?
It's just a samsung windows based note book, been coding with it for two years now with no issuses, just this dosent want to play ball for some reason, will do a manual delete again as you suggest.
      04-12-2015, 08:39 AM   #33
SkyJawa
SkyJawa's Avatar
3716
Drives: F10 530d
Fingers crossed!
      04-12-2015, 10:10 AM   #34
JonD
Still no Joy, this is the message I get
      04-12-2015, 12:24 PM   #35
SkyJawa
SkyJawa's Avatar
3716
Drives: F10 530d
How bizarre. What version of the os are you using? Tho if ok before don't see why it shouldn't be now?
      04-12-2015, 12:39 PM   #36
jayakrishnanv
jayakrishnanv's Avatar
81
Drives: BMW G20 M340d
Uninstall everything then do delete the folders of the previous install and do reboot the laptop. Do a fresh install and when you install the .msi file make sure this time the token folder is with a unique name Which you know and get it configured in the esys. Then try the same
Cheers
Jay
      04-12-2015, 02:06 PM   #37
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
+1
Rebooting after deleting seemed to make a difference for me today.
      04-12-2015, 02:29 PM   #38
JonD
Did exactly that, deleted the entire data folder & the EC-apps folder
      04-12-2015, 09:11 PM   #39
jayakrishnanv
81
Jon when you install the esys the ec apps folder and the c:\data folders will appear as below
Now inside the data folder exists the pszdata folder and the Freetoken.est as below
So if you uninstall the esys and token generator them restart the laptop, then before you install delete the folders of the first picture and then restart and do a fresh install
Cheers
Jay
      04-13-2015, 02:19 AM   #40
JonD
Yes looks exactly like that, I'll do another delete and reinstall procedure tonight, although having done it so many times already not sure it will be any different.
      04-13-2015, 04:16 PM   #41
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
So this evening, I have managed to code my March 2015 car with the latest data files and nothing special. In fact if anything, it was more reliable than on my September 2014 car. How is this possible when everyone is saying you can't code them without jumping through all these hoops?
      04-13-2015, 04:27 PM   #42
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
Essentially because the very latest release has been reworked by tokenmaster to removed all the barriers people were experiencing. There was a period when it all looked impossible.
I agree though, the software seems super reliable and stable now.
      04-13-2015, 04:47 PM   #43
Daftasabrush
Fool
England
1857
Drives: F31 340i
All I did though was copy the new data files to the directory of my old data files and code. Nothing else. I thought I had to do something more than that?
      04-13-2015, 04:52 PM   #44
MarkG_M5Comp
Supreme Being
Drives: M5 Comp
I think it's the data files that have been reworked. There was an issue with the very latest software so I guess you're not using that anyway,
