05-05-2014, 02:19 AM | #24 |
B1990BB
Rep 43
nice ride by the way! and I have a question though, I was thinking of inserting 20" into it with h&r installed, will my tire 255/35-20 for front and 275/30-20 for the rear rub when using this tire specs? or should I just go with eibach sportline?
sorry for another new questions
05-05-2014, 02:28 AM | #25 | |
Driving Mika all over California.....
57
Rep 619
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
05-05-2014, 06:22 AM | #26 |
B1990BB
Rep 43
so to be sure, when I used that 275/30 for the rear it will rub if I lower it using eibach sportline? and that means the front will be safe? 255/35? thank you!
05-05-2014, 06:36 PM | #27 |
57
Rep 619
The fronts will be just fine. My front tires aren't even close to the fender. I am even thinking about putting 5mm spacers on them. The rears, in my opinion, would be close. This all depends on the camber of the rear of course. Just to be curious, how much will the Eibach Sportlines lower the car?
05-05-2014, 07:49 PM | #29 |
Rep 443
Looking great! Is your xenon kit just installed in the halogen headlight housings or was an aftermarket projector kit installed into your headlight housings? Either way the light color and output look fantastic.
05-05-2014, 09:13 PM | #30 |
57
Rep 619
They are in the housing. I am very happy with them, but one of my ballasts is twitchy in the fog lights now, so I need to replace it. Otherwise, the light output is DEFINITELY tremendous!!
05-06-2014, 05:18 AM | #31 | |
B1990BB
Rep 43
05-06-2014, 11:47 AM | #33 |
57
Rep 619
20s would fill the last remaining gap perfectly on my car. I would just be worried to go any wider than 265s in the rear. The front would not matter at all as it isn't close width or height wise. Thank you for the compliments and post pics when you get your wheels on! Cheers!
05-09-2014, 09:31 PM | #34 |
B1990BB
Rep 43
nice fitment! what ring size is this? 20" and may I know the tire setup? and do you have any rubbing when lowering with h&r, h&r has the most lowered base rather than eibach sportline yes? very nice ride!
05-12-2014, 06:46 PM | #36 | |
57
Rep 619
05-12-2014, 07:12 PM | #37 |
Rep 371
Looking Good...
2014 335i M Sport - Mineral Grey/Coral Red, Nav., Premium, HK, MPE, 8AT. Mods: Macht Schnell Spacers (12mm-front, 15mm-rear) with 403M's, Bilstein B8 Struts/H&R Sport Spring combo, M-Performance black kidney grilles, IND Distribution color-matched reflector inserts and key hole cover.
