BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 1-8 Shortcut Keys
      11-22-2013, 08:51 PM   #67
Dannytj18
Drives: BMW 328 I 2013
Originally Posted by CK335iMSport View Post
Preset buttons 1-8 on the radio.
wowwww how do you to this I see people program different things there.................
      11-22-2013, 08:56 PM   #68
CK335iMSport
CK335iMSport's Avatar
Drives: 2014 335i M Sport
Yeah, pretty cool feature that aids in some additional customization ability. Read through the above posts for instructions.
Good luck and have fun
2014 335i M Sport - Mineral Grey/Coral Red, Nav., Premium, HK, MPE, 8AT. Mods: Macht Schnell Spacers (12mm-front, 15mm-rear) with 403M's, Bilstein B8 Struts/H&R Sport Spring combo, M-Performance black kidney grilles, IND Distribution color-matched reflector inserts and key hole cover.
      11-26-2013, 07:46 PM   #69
Dannytj18
      11-28-2013, 07:45 AM   #70
Flakmunky
Amateur Brain Surgeon & Olympic Knitting Champion
Drives: E85, E92, F31, G31
Read this thread or better still read the manual. I bet if you read the manual you'd find all sorts of other cool things your car can do!
      01-05-2014, 06:57 PM   #71
regular_joe
regular_joe's Avatar
Drives: 2014 320XI Modern Line
how do you remove an item from any of the 1-8 buttons so it returns to unassigned status again?
      01-05-2014, 07:05 PM   #72
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
1) My home address
2) Not assigned
3) Not assigned
5) Not assigned
6) Cancel route guidance
7) not assigned
8) not assigned
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      01-05-2014, 07:05 PM   #73
Frogman
Drives: 2012 F30 328i
You can't. You can only reset all 8 of them at once by pushing and holding both 1 & 8 for 5 seconds.
      01-05-2014, 07:08 PM   #74
regular_joe
That sucks but better than nothing i guess...
Thank you
      01-05-2014, 07:22 PM   #75
Mermaid
Queen of the Sea
Mermaid's Avatar
Drives: 2014 320i & 2012 X3
I just read through this thread and found this:
You can clear all of them by pushing and holding 1 & 8 simultaneously for about 5 seconds. I don't know of anyway to clear a single button.
      01-05-2014, 07:32 PM   #76
regular_joe
I did read that too but somehow being in the mindless state of mind I am now needed some verification. Also 'hoping' that somehow magically it was discovered by someone on how to remove them individually.
I should have more carefully.
      01-05-2014, 07:39 PM   #77
SomeRandomer123
SomeRandomer123's Avatar
England
306
Originally Posted by Aritaurus View Post
1) My home address
2) Not assigned
3) Not assigned
5) Not assigned
7) not assigned
8) not assigned
Living the high life
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      01-05-2014, 07:51 PM   #78
Mermaid
Queen of the Sea
Mermaid's Avatar
I've read this thread twice and I still learned something new....and just went and redid my presets.
      01-15-2014, 06:24 AM   #79
HoustonEaDo
Drives: 2019 X3 M40i
Originally Posted by boltjames View Post
Blast from the past thread, just read this. Thanks.
Something I'll share with others that may not be aware: you really only need to store one single radio station as a preset button.
If you set that one radio station from your Presets menu, and then tuck the presets menu back under with a left push of the controller, whenever you tap that 1-8 key for that single radio station, the HUD will now bring up your scrolling list of up to 40 station preset favorites. Tap that one shortcut button to get to your favorite radio station then scroll the rest from there. It's a lot better than dedicating a lot of those eight buttons to just radio stations.
BJ
If you set your radio presets from the idrive preset menu, you can then set another function to the buttons by pressing and holding them -- for example, I have button 6 set to night display for my maps, but it is also set for an FM preset. To access the radio preset though, you have to scroll using the steering wheel button (and idrive has to be set to the presets screen) - if I press button 6, I only get the night display on/off
      01-17-2014, 04:58 PM   #80
DanielBimmer
DanielBimmer's Avatar
106
Drives: YMB M4
How exactly do you set it to your home address? What screen do you have to be on then hold?
      01-17-2014, 05:46 PM   #81
Frogman
Push and hold on the button when the Home entry in the destination list is highlighted, but not clicked on yet.
      03-25-2014, 08:42 AM   #82
thehobbit
thehobbit's Avatar
Italy
Drives: F31 Sportline
2014 BMW F31  [0.00]
My setup:
1) FM
2) FM
3) FM
4) Navigate home
5) Trip computer
6) Vehicle status
7) User manual
8) Call wife
      03-25-2014, 09:12 AM   #83
Professor///M
Professor///M's Avatar
Drives: 2022 M3, 2022 X5 40i;
1 Home #
2 Wife #
3 Message Center
4 Friend #
5 Work nav
6 Home nav
7 Work 2 nav
8 Work 3 nav
      03-25-2014, 06:03 PM   #84
joedoe
Drives: 2014MY BMW328i
Couldn't programm "Cancel Navigation" command to a hot key.
Anyone?
      03-25-2014, 07:10 PM   #85
Frogman
Anyone?
Sure, I just tried it and it works fine:
1. Have guidance active.
2. On the nav screen, left-click the knob to select the icons on the left.
3. Select the top left hand icon and click it (push down). A new screen will display.
3. Turn to the "Stop Guidance" line (don't click it) and push-and-hold the 1-8 button you want to program. Done.
The program-a-function trick is to be at the step just before you click to activate the function, and then memorize the button from there. You are memorizing a click, not a screen.
      03-26-2014, 02:49 PM   #86
joedoe
Hmm, that is how I did it. Will try one more time.
      03-26-2014, 03:28 PM   #87
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
Originally Posted by SomeRandomer123
Another quick reply thread! I like these .
Gimmie your 1-8 designations! Interesting to see how people use this very nice and very useful functionality.
I'll go first!
1 - Navigation, Start Guidance Home
2 - Radio, FM Station
3 - Radio, FM Station
4 - Activate PlugIn
5 - Sport Display
6 - Split Screen on/off
7 - EfficientDynamics Display
8 - Navigation, Start Guidance Office
1-traffic info
2-messages
3-HUD on off
4-Parents House
5-my house
6-
7-Split screen
8-Sport Displays
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      03-26-2014, 03:38 PM   #88
fecurtis
Drives: 2014 BMW 335i M-Sport
Oh traffic info and auto split screen, clever use.
