06-22-2018, 01:09 PM | #1 |
Rep 60
Wheel Fitment and Tire Recommendation
Will a 19x8.5 et40 and a 19x9.5 et45 fit a stock height f30? I want a flush fit, some poke is ok but nothing extreme. And what tire size would you recommend?
06-22-2018, 01:46 PM | #3 |
Rep 60
06-22-2018, 02:36 PM | #4 |
Rep 4,329
generally, lowering your car results in more negative camber (and change in toe). if you are not able to re-align to original camber after lowering(i.e with a camber kit) you may end up with slightly more tuck, so a lower offset may be used or more spacer can be applied.
kern4174449.50 |
