11-30-2023, 10:22 AM | #1 |
Rep 92
I am an idiot please come and laugh at me
I had ONE JOB! De-pin this!!! …….
I snapped the locking bit off it….. Never worked out how to open it… can anyone advise??? Please |
11-30-2023, 10:53 AM | #2 |
No 55mph
1622
Rep 8,477
In left side row of windows - use a small screwdriver to push down on the little metal tab of the contact while pulling out the wire at the same time
Don't put tension on the wire (pull out) until you have the tab depressed Best if you push IN on the wire, push down on the little clip, then pull out the wire
11-30-2023, 10:54 AM | #3 |
Rep 452
https://www.aliexpress.com/w/wholesa...-tool-kit.html
I am using these and they work pretty good |
11-30-2023, 11:02 AM | #5 |
No 55mph
1622
Rep 8,477
The locking clip u broke off is just the 2nd line of defense that holds the contacts in - you still need to do as I described as the tabs on the contacts you see thru the window are catching on inside of plastic connector housing
11-30-2023, 01:36 PM | #7 |
Rep 890
It would help to know what connector that is…
Here’s the TIS info on what I’m guessing is this connector. The ‘flap’ you’re referring to doesn’t open - there’s a 2-part locking method to remove the wires. |
