BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Updating idrive history with HU-ServiceManager
proTUNING Freaks
      10-31-2018, 10:39 AM   #45
ir655
Sweden
Drives: F31 320d and F11 530d
Originally Posted by Sasquartch View Post
Is your ediabas.ini file definitely correct, ie set to ethernet (ENET) ?
I think it was set to OBD and I changed it to ENET.
When I changed it to ENET that the little icon on the right hand lower taskbar for Ediabas was Red. I tried connecting to HU and had a different error message.
I switched it back to OBD and the icon turned Green and I get the current fault message that i posted earlier.
Worth to mention is that I am using a USB to Ethernet adapter since my laptop does not have a real Ethernet port. Latency is set to 1 and COM1 is set for the adapter. Anyway, feels like if something was wrong with that I wouldnt have been able to do functions with ISTA-D and ESYS.
Anyway, I will update tomorrow night after trying different settings with the Ediabas.ini file.
      11-01-2018, 04:13 AM   #46
Sasquartch
Drives: 520i G30
COM port settings are irrelevant
As long as the USB ethernet port functions correctly it should be OK but disable any firewalls in case these are preventing a connection
Make sure there are no other ethernet interfaces in use
When you connect the car it usually takes a few (20-ish) seconds for the PC to auto configure
Use the ipconfig command to check you have a 169. IP address.
Please post up any solution you find for the benefit of others.
      11-11-2018, 08:55 AM   #47
Cetar
Drives: BMW F20 116i 2014 AT
Hi BMW fans,
some remarks i found out today:
The structure of the Service history record is as follows:
A;0xB;C;D;
Where A is type of the record (1= engine oil); B is if it was late; C = how late in KM; D how late in months.
So for example:
1;0x"not sure about the number";0;2; means Engine oil changed 2 months late.
You can found the exact number for "late" record when you change "Service carried out" to carried out late.
Cheers
      11-12-2018, 04:03 AM   #48
cedchung
Mauritius
65
Drives: 2011 F25, 2014 F30
What is this error code?
92: SYS-0002: ECU OBJECT FILE NOT FOUND
      01-15-2019, 06:36 AM   #49
ir655
Sweden
Hi! Been a while I was at this, but now needing this to work to enter some service that I have done myself.
In Ediabas.ini I set the interface to OBD and even tried ENET still no Go.
Com port settings is COM3 with latency to 1 and 1.
OBD.ini file matched COM port setting of COM3.
in Ediabas.ini I read that I have to change the remote host section to: 192.168.68.1 from original 192.168.68.40
Port is 6801.
Today I got a different message when trying to connect to HU:
IFH-0018 INITIALIZATION ERROR
I have the required .prg files in Ediabas/ECU folder (Not all from Rheingold, just those relevant to the different HU's).
New tips and tricks pleeeease
      01-17-2019, 03:27 PM   #50
ir655
Sweden
Just noticed I have 2 different EDIABAS folders...
One located in C:\Ediabas
And one in my Rheingold folder (Rheingold\Ediabas)
Should there be 2? The EDIABAS.ini file in the Rheingold\Ediabas\bin folder refers to C:\Ediabas for certain lines.
Is this supposed to be like this or?
      01-19-2019, 06:49 AM   #51
ir655
Sweden
Just to update: Got it working now!
Reinstalled Ediabas etc using Standard BMW Tools pack and downloaded Ediabas configurator to config the ediabas.ini
HU Service manager connects to car and I am able to write service. I managed to delete all the service history already in there, but took pics before I did anything so I can enter those again 😊
      01-22-2019, 01:35 AM   #52
Chris_330
Drives: F31 330d Msport
can anyone give me a link to download this please?
      01-22-2019, 03:36 AM   #53
Sasquartch
Drives: 520i G30
Just google "hu service manager download"
Its all there if you look
      01-22-2019, 01:36 PM   #54
neo61uk
neo61uk's Avatar
Drives: F31 340i Performance Edition
Hi there
Reading your posts I'm trying to get mine to work.
I have esys and coded my cars many times no problem.
Installed HU-SERVICEMANAGER and had initialization error.
So edited ediabas.ini file from obd to esys and it went to different error saying Cannot Connect
I've checked my Ediabas/ecu files and there is no nbt.prg files or anything similar.
Could you tell me where to take all those ediabas/ecu files needed for nbt connection?
Also what else should be changed in ediabas.ini file to make sure its right?
Should I just edit it or use ini editor?
Can't find any instructions online at all.
Many thanks for all the help.
      02-13-2019, 12:22 PM   #55
coskunhc
Drives: BMW 118D
Service menu disappeared
Hi all,
I hope there still are someone in this thread. I've done everything as written in the comments and got a connection to my NBT. I have a BMW F20 2014 with NBT Prof.
So normally my service history was visible in the idrive menu, and I wanted to add a manual listing as well, because I've just did a service on my car with oil change and so on. But after I did everything with HU ServiceManager, some how my service history disappeared from my iDrive menu.
And I noticed that you need to change the date format manually to MONTH;DAY;YEAR instead of MONTH-DAY-YEAR, but that didn't change anything either.
So guys/girls, what am I doing wrong?
      03-11-2019, 11:00 AM   #56
F30.FAN
Drives: F30
Same thing for my nbt?Did you solved the problem?
      05-05-2019, 10:46 AM   #57
alex-xs
Drives: BMW f31, BMW f25
I have also a F31 NBT, and I am afraid to test the software, dont want to delete the service history.
The software is working and I got connection with the car...
did any of you solved the deleted service history issue.
      05-08-2019, 04:17 AM   #58
RoopD
Drives: F30 Alpine Weiss
Will this put for my bmw f30 everything in KM?
and everything on 'OK' after I update HU?
      05-25-2019, 08:27 PM   #59
Bobbyjee
Drives: BMW F10
Thanks Sasquartch
Your instructions on enet worked a treat.
Managed to get the connection. Just need to input all the values
      06-04-2019, 04:05 AM   #60
ir655
Sweden
Make sure you take pics of service history before beginning. Service history will disappear because you will make an error in the input format when entering the date of service.
Once you choose date the last thing you need to do is change the - between the date numbers to ; in the long string of mumbo-jumbo in the top left corner. Then press Write to HU. Make sure the date is in dd;mm;yyyy;
      06-04-2019, 04:10 AM   #61
ir655
Sweden
Originally Posted by neo61uk View Post
Hi there
prg files are found in Rheingold/ecu map. If you have ISTA-D installed you will find the required prg files in the folder i mentioned above.
Change the ediabas.ini and obd.ini files with wordpad.
      06-04-2019, 06:35 AM   #62
maxwarmer
Drives: M4 F82
Hello
I need help. I installed HU-ServiceManager when I try to connect to HU. The error appears: 28: IFH-0018: INITIALIZATION OF ERRORS
Can someone guide me?
I am using EDIABAS 7.3.0
I am using JAVA 1.8.0_144
I have ISTA + and it works
I have esys and it works
I use the ENET cable
I put the archibo ediabas.ini in:
Interface = ENET and I get error NET 0012 NO CONNECTION, I put it in Interface = STD: OBD and I get error IFH: 0018 INITIALIZATION ERROR.
I have all the PRG and DLL files in the ECU folder.
Any solution?
      06-04-2019, 06:37 AM   #63
maxwarmer
Drives: M4 F82
In OBD.ini file which line you suggest to change? please comment this, thanks a lot.
      06-04-2019, 06:51 AM   #64
maxwarmer
Drives: M4 F82
My EDIABAS.INI
;# EDIABAS 7.3.0 #
[Configuration]
Interface =STD:OBD
Simulation = 0
EcuPath = C:\EDIABAS\ECU
SimulationPath = C:\EDIABAS\SIM
TracePath = C:\EDIABAS\TRACE
TraceSize = 1024
ApiTrace = 0
IfhTrace = 0
; IfhnTrace = 0
; SystemTraceSys = 0
; SystemTraceBip = 0
; SystemTraceIfh = 0
; SystemTraceNet = 0
; BipDebugLevel = 0
; BipErrorLevel = 0
UbattHandling = 0
IgnitionHandling = 0
ClampHandling = 0
RetryComm = 1
SystemResults = 1
TaskPriority = 0
; CodeMapping = C:\EC-Apps\EDIABAS\BIN\ansi2oem.tab
; LoadWin32 = 0
NetworkProtocol = TCP
; --- neu ab EDIABAS 7.2.0 ---------------------------------------------------
ShowIcon = 1
LogLevel = 0
TraceBuffering = 0
TraceHistory = 0
TraceSync = 1
; TraceWriter = <FilePathName>
[TCP]
RemoteHost = IP_VON_ENTFERNTEM_PC
Port = 3000
TimeoutConnect = 2000
TimeoutReceive = 2000
TimeoutFunction = 10000
; TimeResponsePending = 5000
; DisconnectOnApiEnd = 1
; InitCmd0 = FE,04,00,03,01
; InitCmd1 = FD,05,00,03,01
[XEthernet]
RemoteHost = Autodetect
HeaderFormat = 0
TesterAddress = F4,F5
ControlPort = 6811
DiagnosticPort = 6801
TimeoutConnect = 20000
[IfhProxy]
Port = 6700
;## ausf¸hrliche Variante von EDIABAS.ini (mit Kurz-Info und Default) ##
; EDIABAS Basic Configuration
; [Configuration]
;### new Configuration elements since EDIABAS 7.2 ############################
; ShowIcon
; Description : Enable/Disable EDIABAS-Icon in System-Tray
; Value : 0 = EDIABAS-Icon disabled
; 1 = EDIABAS-Icon enabled
; Default = 1
; ShowIcon = 1
; LogLevel
; Description : Logging of fatal faults in EDIABAS.log
; Value : 0 = Logging disabled
; 1 = Logging enabled
; Default = 0
; LogLevel = 0
; TraceBuffering
; Description : Manner of Opening/Closing of Trace-Files
; Value : 0 = Opening/Closing after every dump
; 1 = Trace-Files stay open
; Default = 0
; TraceBuffering = 0
; TraceHistory
; Description : Number of History-Trace-Files
; Value : 0 .. 999
; Default = 0
; TraceHistory = 0
; TraceSync
; Description : Synchronisation of Trace files
; Value : 0 = Synchronisation disabled
; 1 = Synchronisation enabled
; Default = 1
; TraceSync = 1
; TraceWriter
; Description : FilePathName of a private TraceWriter
; Default = . (Default-TraceWriter "TWFile32.dll")
; TraceWriter = .
;### older Configuration elements till EDIABAS 7.1 ###########################
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
; Simulation = 0
; EcuPath
; Description : ECU file path
; Default = .
; EcuPath = C:\EC-Apps\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
; SimulationPath = C:\EC-Apps\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
; TracePath = C:\EC-Apps\EDIABAS\TRACE
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0 .. 32767
; Default = 1024
; TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; 8 = Debug trace
; Default = 0
; ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = User trace
; 2 = User trace + interface
; 3 = User trace + interface + time stamp
; Default = 0
; IfhTrace = 0
; IfhnTrace
; Description : Enable/Disable IFH network trace (with XREMOTE)
; 1 = User trace
; Default = 0
; IfhnTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1 .. 7
; Default = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Default = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Default = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Default = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Default = 0
; BipDebugLevel = 0
; BipErrorLevel
; Description : BIP error level of ECU files
; Default = 0
; BipErrorLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
; UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
; IgnitionHandling = 0
; ClampHandling
; Description : automatic check of clamps for Ubatt and Ignition
; Value : 0 = no automatic clamp check with send_and_receive
; 1 = automatic clamp check with send_and_receive
; Default = 1
; ClampHandling = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
; RetryComm = 1
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
; SystemResults = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
; TaskPriority = 0
; CodeMapping
; Description : Character mapping file path
; Default = .
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
; LoadWin32 = 0
; NetworkProtocol
; Description : Network protocol
; Default =
; NetworkProtocol = TCP
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
; Interface = STD:FUNK
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Ansprechpartner: Manuel.Rothenberger@bmw.de
; WINDOWS-Freig. : WIN NT 4.0 : Ja
; WIN XP 32-Bit : Ja
; WIN 7 32-Bit : Ja
; Interface = STD:OMITEC
; Beschreibung : Nachfolger von OBD / enth‰lt CAN-Anbindung / Anschluss an OBD-Dose
; Installation : \EDIABAS\HARDWARE\OMITEC\AnleitungfuerOMITECInstal lation.pdf
; INI-Datei : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Ansprechpartner: Reinhold.Drexel@bmw.de
; WINDOWS-Freig. : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : siehe \EDIABAS\HARDWARE\OBD\OBD_DOKU.pdf
; WIN 7 32-Bit : Ja
; Interface = EDIC
; Beschreibung : Anbindung ¸ber K-Line
; HW-Derivate : PC-Card, PCMCIA , W-LAN (Interface von Fa. Softing)
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; Ansprechpartner
; * EDIC-PC : Gerd.Huber@bmw.de
; * PCMCIA : Gerd.Huber@bmw.de
; * EDIC-NET : (Richard.Kolbeck@bmw.de)
; WIN 7 32-Bit : Ja
; Interface = EDICC
; INI-Datei : EDICFW.INI, EDICHW.INI, XEDICC.INI
; Ansprechpartner
; WIN 7 32-Bit : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CAN32.INI
; Ansprechpartner: FLASH.SERVICE@BMW.DE (Hotline)
; WINDOWS-Freig. : !nicht mehr im Paket enthalten!
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces ¸ber TCP/IP (f¸r Normalbetrieb)
; Installation : Anpassung der Eintr‰ge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Ansprechpartner
; * Remote-PC : Gerd.Huber@bmw.de => Referenz@bmw.de
; * OP(P)S : Michael.Rowedder@bmw.de
; * ICOM,Fertig. : ! keine Verwendung !
; * ICOM,Vertrieb: Robert.Schwinn@bmw.de
; WIN 7 32-Bit : Ja
; Interface = REMOTE:name
; Beschreibung : Anbindung eines EDIABAS-Interfaces ¸ber TCP/IP (f¸r Parallelbetrieb)
; INI-Datei : REMOTE.INI (insbesondere f¸r Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port).
; Ansprechpartner
; * Remote-PC : ! momentan keine Verwendung !
; WIN 7 32-Bit : Ja
; Interface = RPLUS
; Beschreibung : Anbindung eines EDIABAS-Interfaces ¸ber TCP/IP (f¸r PROXY-Betrieb)
; Installation : Anpassung der Eintr‰ge in [TCP] auf beiden Seiten (insb.: RemoteHost, Port)
; INI-Datei : keine
; Ansprechpartner
; * Remote-PC : ! keine Verwendung !
; * OP(P)S : ! momentan keine Verwendung !
; * ICOM,Fertig. : Manuel.Rothenberger@bmw.de
; * ICOM,Vertrieb: ! momentan keine Verwendung !
; WIN 7 32-Bit : Ja
; Interface = RPLUS:name (z.B.:RPLUS:ICOM_P)
; Beschreibung : Anbindung des EDIABAS-Interfaces ICOM ¸ber TCP/IP
; Installation : Anpassung der Eintr‰ge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) in den INI-Dateien
; INI-Datei : RPLUS.INI (Nutzung im Zusammenhang mit dem Interface ICOM)
; In RPLUS.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port).
; Ansprechpartner
; WIN 7 32-Bit : Ja
; Interface = ENET
; Beschreibung : Anbindung ¸ber Ethernet
; Installation : Anpassung der Eintr‰ge in [XEthernet] (insb.: RemoteHost)
; INI-Datei : ENET.INI (insbesondere f¸r Parallelbetrieb notwendig)
; Ansprechpartner: Gerd.Huber@bmw.de => Referenz@bmw.de
; WINDOWS-Freig. : WIN NT 4.0 : Nein
; WIN 7 32-Bit : Ja
; WIN 7 64-Bit : Ja
; Interface = PROXY:<Interface>
; z.B. Interface = PROXY:STD:FUNK
; z.B. Interface = PROXY:ENET
; Beschreibung : EDIABAS wird im PROXY-Modus betrieben
; Installation : h‰ngt vom benutzten Interface ab
; INI-Datei : h‰ngt vom benutzten Interface ab
; Ansprechparter : Gerd.Huber@bmw.de => Referenz@bmw.de
; WIN 7 32-Bit : Ja
; Konfigurationslemente, die existieren,
; aber nicht in EDIABAS.ini ge‰ndert werden kˆnnen
; BipEcuFile
; Description : Dateititel der aktuell geladenen SGBD
; (nur g¸ltig w‰hrend einer Job-Verarbeitung)
; Value : String
; Default = -
; EdiabasIniPath
; Description : Pfad der verwendeten EDIABAS.ini
; Value : String
; Default = -
; EdiabasVersion
; Description : verwendete EDIABAS-Version
; Value : String
; Default = -
; IfhVersion
; Description : verwendete IFH-Version
; Value : String
; Default = -
; Session
; Description : Name der EDIABAS-Session
; Value : String
; Default = -
; TCP/IP Configuration
; [TCP]
; RemoteHost
; Description : server address/name
; Default = -
; RemoteHost = LMUC203404
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Spezialfall OP(P)S / ICOM:
; Value : 6801 ;OBD-Treiber (CAN)
; Value : 6802 ;Most-Treiber
; Default = -
; Port = 3000
; weitere Details siehe Dokumentationen
; TimeoutConnect
; Description : Timeout for establishing the connection
; Value : 1000 ... 59000
; Default = 5000
; TimeoutConnect = 2000
; TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
; TimeoutReceive = 2000
; TimeoutFunction
; Description : Timeout for a long function
; Value : 5000 ... 59000
; Default = 59000
; TimeoutFunction = 10000
; Description : Time between alive-messages
; Value : 500 ... 59000
; Default = 2000
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
; InitCmd<n>
; Description : Initialization command <n> (normally for OPPS)
; Default =
; XETHERNET Configuration
; [XEthernet]
; RemoteHost
; Value : Autodetect
; 169.254.1.1 ; Beispiel
; 192.168.100.1 ; Beispiel
; Default =
; RemoteHost = Autodetect
; IfhRemoteHost
; Default =
; IfhRemoteHost = Autodetect
; HeaderFormat
; Description : type of header
; Value : 0 ; 6Byte Header (B-Muster)
; 1 ; 3Byte Header (A-Muster)
; Default = 0
; HeaderFormat = 0
; TesterAddress
; Description : list of permitted tester adresses
; Value : F4 ; F1 durch F4 ersetzen
; F5 ; F1 durch F5 ersetzen
; F4,F5 ; F1 zuerst durch F4 ersetzen, dann F1 durch F5 ersetzen
; F5,F4 ; F1 zuerst durch F5 ersetzen, dann F1 durch F4 ersetzen
; Default = -
; TesterAddress = F4,F5
; ControlPort
; Description : port of control channel of TCP connection to ZGW
; Value : 1000 < port < 59000
; Default = 6811
; ControlPort = 6811
; DiagnosticPort
; Description : port of diagnostic channel of TCP connection to ZGW
; Default = 6801
; DiagnosticPort = 6801
; TimeoutConnect
; Description : timeout in ms for connection to ZGW
; Default = 20000
; TimeoutConnect = 20000
; XPROXY Configuration
; [IfhProxy]
; Port
; Description : IP base proxy port
; Ports : +0 = unknown interface
; +1 = EDIC
; +2 = EDICC
; +3 = ENET
; +4 = STD
; +5 = REMOT
; Default = 6700
; Port = 6700
; End Of File EDIABAS.ini
Chequed and no work.
      06-04-2019, 06:52 AM   #65
maxwarmer
Drives: M4 F82
OBD.INI, use this configuration and no work.
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
      06-04-2019, 01:49 PM   #66
ir655
Sweden
If you are using ENET cable then in Ediabas.ini you need to change "Interface=ENET"
In Obd.ini the "port=comx" should correspond with the same com port that you have selected as default under Device Manager "Ports and LPT" tab. Mine is set as Com3 so my obd.ini file says "port=com3"
Not sure if "Hardware=USB" or if it should say "Hardware=OBD". Mine is set to the latter in Obd.ini
