BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Stock Tires on 2014 335i Xdrive w/MPP
proTUNING Freaks
      11-24-2013, 12:58 PM   #1
Sailormannn
Drives: 2014 BMW 335i xDrive
Can someone confirm what make/model of stock tires are coming on a 2014 335i xDrive with MPP. Size is 19" M wheel, perf RFT tire (19x8.0, 225/40 R19 front and 19x8.5, 255/35 R19 rear). Thanks.
      11-24-2013, 01:15 PM   #2
Erics4er
General of the Armies
Drives: 2015 BMW M4
2015 BMW M4  [0.00]
You can click on the BMW US website below and it will give you a breakdown of all the tires offered on the 2014 335i, main difference is the M-Sport brake package, they require wider rims in the back usually.
http://test.resource.bmwusa.com/Pdf_...Specs/DOT.aspx
They probably do not have a standard company they use for tires but if you go to Tirerack.com they will give you an equivalent OEM tire, hope this helps.
      11-24-2013, 01:36 PM   #3
ATX78703
Drives: 2014 335i
You'll prob get either Bridgestone potenza S001 or contiSport contact SSR if you've spec'd mixed summer tires (which you have if you got the 19's).
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
tires
