02-10-2018, 03:01 PM | #947 |
Rep 4
Hi, i'm new to the f30 scene and trying to get information to enable ebt, my car is 2013 and when i go to configure bluetooth the only option is telephone does this mean i need to code it using software and can you explain what a comboxis and do i have one? thanks
02-10-2018, 03:03 PM | #948 | |
Rep 32,881
02-11-2018, 03:30 AM | #949 | |
Rep 1,201
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
Mottok54.00 |
02-11-2018, 07:16 AM | #950 | |
Rep 319
..appealing for help (along with others) on this, hopefully we will get some advice. I will look at doing the voice stuff at a later date as shawnsheridan has told me it requires FSC coding (if anyone can actually tell me what that actually is that would be good and how it differs from vo and fdl coding haha) which I believe is much more advanced, so may pay for that down the line if I ever feel I really want voice commands. Many thanks. |
02-11-2018, 08:07 AM | #951 | |
Rep 1,201
An FSC code (I think) is a system, like a license file or code, that BMW has put in place to attempt to control the loading of software into their cars.
02-11-2018, 08:41 AM | #952 |
Rep 40,951
PM sent.
02-11-2018, 08:45 AM | #953 |
Rep 1,201
02-11-2018, 08:46 AM | #954 | |
Rep 40,951
02-11-2018, 09:07 AM | #956 | |
Rep 32,881
If you just want BT streaming you could try one of these https://www.amazon.co.uk/dp/B01MSUWC..._7VfGAb148HBQE |
02-11-2018, 11:44 AM | #958 | |
Rep 319
Thanks also shawnsheridan, how do you know what the VO, FDL and FSC codes are for your car? Hopefully you don’t need to be able to speak German! �� Last edited by Mottok; 02-11-2018 at 04:55 PM.. |
02-11-2018, 11:56 AM | #959 | |
Rep 1,201
02-11-2018, 11:59 AM | #960 |
Rep 40,951
FSC Codes are not something one normally needs to worry about. Unless retrofitting something that needs one, it is irrelevant. As for Coding, 99% of all Coding are FDL Code based, and they are on Cheat Sheets and built into E-Sys Launcher. VO Coding is seldom used, with EBT being the primary exception.
02-11-2018, 12:22 PM | #961 |
Rep 584
Just found a NBT head unit and controller on eBay, not too far from me, no screen. How easy/difficult would it be to install and would it be compatible with my small CIC screen?
Mick |
02-11-2018, 12:25 PM | #962 |
Rep 541
Please can someone confirm the following.
I am going to FO code for EBT. My car is May 2015 with business media. 1. Where I have seen pics of the silver combox in this thread, mine is black. Smooth cover with no cooling fins. What is this? 2. Do I have the combox built into the head unit. If yes then I just need to do the FO coding and then FDL code the options in demig's post #368 3. I have previously done about 15 FDL settings changes. These will be returned back to standard when I do the VO coding? 4. Doing the VO coding will cause no issues for future FDL coding? 5. I should VO code the gearbox mod at the same time I do EBT? |
02-11-2018, 01:12 PM | #963 | |
Rep 32,881
3 only the fdl changes you’ve made to the hu 4 no 5 might as well |
02-11-2018, 02:38 PM | #964 |
Rep 541
02-12-2018, 05:21 PM | #966 |
Rep 319
Ok I think I’m going give esys a try because I would prefer to VO code EBT than do FDL coding for this.
I saw shawnsheridan’s postmodern a while back that shows how to do this: http://www.bimmerfest.com/forums/sho...d.php?t=722706 if you are around could you confirm this is still relevant to a Sept 2015 with ENTRNAV with S6ACA SOS call and S6AE TeleServices (is this the same as connected services?? I’m sure I have that option, Christ BMW makes it difficult sometimes!) there for should I use the 6NL code? Many thanks. |
02-12-2018, 05:48 PM | #967 | |
Rep 40,951
02-13-2018, 10:50 AM | #968 |
Rep 319
