05-07-2017, 07:09 AM | #1 |
Rep 1,455
2017-2 maps for CIC now available
Just a reminder for those of us with older cars with CIC Pro Nav that 2017-2 maps are now available
The torrent file is available at bmwfsc.ca If using the key generator that uses the lookup.xml file you need the following bit, the important bit is the 0028002B : <SgbmId id="NAVD_000004CE_002_001_511" SWID_FscShort="0028002B" name="Road Map Europe West PREMIUM 2017-2" supplier="NTQ" sop="01.09.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> It took around 4 hours to download the 20 odd gigabytes. I already had my FSC file ready to I could generate a key straight away I used a single 32GB USB stick. Once plugged in to the glovebox USB the idrive will recognise the new update after abouit 30 secs or so and you are prompted to start the upgrade. It took perhaps 45 mins |
05-07-2017, 07:19 AM | #2 |
Rep 426
Thanks. Mine is a Dec 14 and never been updated as I'm a complete feckwit when it comes to anything that resembles technical. Could you tell me in very basic terms what I do to get updated. I don't mind paying of course but ideally not the crazy labour fees from bmw.
05-07-2017, 08:04 AM | #3 |
Rep 240
Thanks for that Sasquartch - what version of 7z (or winzip) did you use to unzip the contents - the latest available?
I always seem to have issues when unzipping / extracting them depending upon the version of the unzip software that I use. Thanks. Andrew. |
05-07-2017, 09:05 AM | #5 | |
Rep 1,455
If you have NBT then I think once you have the FSC file (you need to extract from car using esys) the procedure is similar All the information you need is in the coding forum I can extract your FSC code for you if you fancy a trip to Herts - but all Ive done is follow the various guides in the coding forum |
05-07-2017, 09:12 AM | #6 |
Rep 240
05-07-2017, 10:01 AM | #8 |
Rep 1,455
Yes
http://www.bmwfsc.ca/map-data/ Note that all this site hosts is a torrent file. You need to install something like uTorrent to use it. If you're not aware a torrent is a peer-to-peer method of file sharing (like the old limewire and napster music sharing was a few years ago) You can get uTorrent here : http://www.utorrent.com/downloads/win |
oli342.00 |
05-07-2017, 10:02 AM | #9 |
Rep 1,455
05-07-2017, 10:05 AM | #10 | |
Rep 1,455
When in Navigation press the option button on the idrive controller and scroll down, I think the last option will report your map version and details |
05-08-2017, 01:54 AM | #11 | |
Rep 240
I am usingthe latest version of the 64 bit 7 zip and get this message - not had time to try the update in the car yet though but I think that it will fail if I get this message after unzipping? Thanks Andrew |
05-08-2017, 03:38 AM | #12 | |
Rep 1,455
I'd suggest right clicking on the downloaded file and select 7-Zip, Test Archive. My guess is something's corrupted Have you downloaded the same maps as me ? If so I can check the byte sizes etc to see if there's any mismatch. Alternatively I can copy the data onto a USB stick if you wanted to post me one. Let me know |
05-08-2017, 03:55 AM | #13 | |
Rep 240
I did the test archive yesterday and it also gave me this warning - the download did not say it had any issues but maybe something has got corrupted as you say. Thanks for the offer to copy it onto a USB - I might take you up on it if this fails. Last edited by andrew.webber; 05-08-2017 at 04:28 AM.. |
05-12-2017, 07:05 AM | #16 |
Rep 8,087
Slipperyshoe - your Dec 14 will be a later system (NBT)
The latest map data for NBT is 2017-1 XML is: <SgbmId id="NAVD_000014B9_255_002_185" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1" supplier="NTQ" sop="01.11.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId>
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
05-12-2017, 08:18 AM | #17 | |
Rep 1,470
06-27-2017, 08:48 AM | #19 | |
Rep 192
10-17-2017, 06:28 AM | #20 |
Rep 1,455
Unfortunately the site at www.bmwfsc,ca/map-data seems to have been taken offline
If anyone knows an alternative source please share. It probably wont be that long before 2018 maps start becoming available |
10-17-2017, 08:12 AM | #22 | |
Rep 8,087
Ian
