02-09-2016, 09:05 AM | #1 |
Redline Addict
Rep 783
OEM 313 square setup on 335 xdrive
I was hoping to get a little help on options for running a square setup using OEM 313 wheels. What's the best option if I want to run 235/40/19 on all four corners, the 19x8 et37 or 19x9 et39?
The car is an m sport, completely stock. I know I can run the standard staggered setup fine, but I'd like to stick with a square setup if possible. |
02-09-2016, 10:03 PM | #3 |
Rep 4,361
from your choices i would go 19x8 +37, except 245/35/19 tire size. if the sidewall is bulging too much for you then the 19x9 +39 with 245/35/19.
02-10-2016, 09:28 AM | #4 |
Redline Addict
Rep 783
I think I like the 19x8 et29 idea. Sounds like the et37 require a 10mm spacer on the front, so could do a 3mm spacer with the 29 and have the room I need to clear the brakes. Then the backs would be pushed out 5mm over the stock et34. Maybe I'll just stick with stock 225/40 size all around, with some summer tires I'll have plenty of grip. Thanks guys.
