BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Post pics of F30 with MEATY tires
      08-07-2018, 11:52 PM   #23
jose2g
Drives: f30 2016 328I
help! fitment question.
I just ordered new wheels and tires for my 328I and I was wondering if a 245/45/18 would fit in the rear without rubbing lowered on H&R sport springs?
      08-08-2018, 04:16 AM   #24
thisismikeyb
thisismikeyb's Avatar
115
Drives: 2014 328i xDrive M-Sport EBII
How about some 245/45r18's for meat?
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
      08-08-2018, 07:02 AM   #25
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
The best part of running 275+ in the rear
Youtube/Instagram/TikTok: @kern417
      08-08-2018, 07:11 AM   #26
Pinkykillaz
Pinkykillaz's Avatar
23
Drives: 320i,custom Ohlins R&T
Originally Posted by E90 LCI View Post
Yesss this looks sick. How many inches did you drop it? Post more from further away if you can pls
about inch or 1,5. Pics will be soon
      08-09-2018, 01:04 PM   #27
Rokoz
Rokoz's Avatar
Drives: 2016 f80 M3
I hate to plug my own instagram but if you check it out, I have 245/40 and 275/35 on 19s.
I'd post a few pictures on here, but, all my files are huge and I'm at work
Instagram: @f80ghost
      08-09-2018, 02:37 PM   #28
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
I like!
      08-12-2018, 03:24 AM   #29
sambonator
Samtaro!
sambonator's Avatar
Drives: 2014 F32 N55 Alpinweiß
Talking
That's the setup I have on my lifted (rather than lowered) F32.
      08-13-2018, 07:04 PM   #30
50shadesofhockenheim
50shadesofhockenheim's Avatar
Drives: 2005 Toyota Prius
So 17s won't fit on my front due to big brakes.
I was thinking 18x8.5 with 255/40/18 tire up front
and for the rear 17x9.5 with 275/40/17
      08-13-2018, 07:53 PM   #31
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
255 on 8.5 bulges a bit. I'm not sure if I'm going to keep it, 245 would be a more sensible choice.
I wouldn't imagine running smaller wheels in the rear over the front, that's just wrong...
Here is mine with 255/40/18 on 18x8.5 et38 lowered about 2.5"
I'm going to go with 245/40/18 for the winters and see where it goes from there
      08-13-2018, 09:17 PM   #32
What tires are you running? And what do your rears look like?
      08-13-2018, 09:45 PM   #33
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Give me all the wheel/suspension specs and photos. This is perfect
      08-14-2018, 02:30 AM   #34
sambonator
Samtaro!
sambonator's Avatar
It's odd it looks bulged on 8.5's as 255's are the OEM size on 8.5" wide wheels.
      08-14-2018, 04:30 AM   #35
thisismikeyb
115
Thanks!
328i xDrive with Dinan Springs rolling on Michelin MP4S+Apex FL-5's for summer and Alpin PA4+Apex EC-7's for winter all spec'd at 245/45 on 18x8.5et35. I have around 5" of ground clearance with the front lip.
I have a few other pictures posted around.
https://f30.bimmerpost.com/forums/sh...0&postcount=10
https://f30.bimmerpost.com/forums/sh...4&postcount=11
https://f30.bimmerpost.com/forums/sh...&postcount=212
Logicoeur992.50
      08-14-2018, 07:25 AM   #36
kern417
Cheapskate
4450
Like I said before, it only looks right if you're running a small wheel with a big radial on the back. But really no reason to daily on a small wheel, and it looks really dumb just running a tall summer/all-season tire. But OP seems hellbent on running that setup.
It looks bludged on the stock wheels too.
      08-15-2018, 06:32 PM   #37
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
Originally Posted by Pinkykillaz View Post
front 18x8,5 et35 235/45 -2,3
rear 18x9,5 et35 265/40 -2,0
eibach pro-kit , bilstein b8, millway camber plates
Finally I get a spot on picture of the specs I'm going with. Fronts look a tiny bit more stretched than I would like and the rears look ok.
I wanted to go with 245/275 but the PS4s doesn't come in 275/40R18.
      08-15-2018, 09:21 PM   #38
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Are those Ferrari center caps?
      08-15-2018, 10:29 PM   #39
ONEof500
ONEof500's Avatar
Drives: 2017 M3 30 Jahre
[QUOTE=Rokoz;23569474]I hate to plug my own instagram but if you check it out, I have 245/40 and 275/35 on 19s.
So what's your insta? I want to see that setup
      08-16-2018, 02:02 AM   #40
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
It's in his signature
Instagram: @glacialf30
Rokoz294.50
      05-31-2019, 05:52 PM   #41
Mkswoosh
Mkswoosh's Avatar
93
Drives: 2018 340xi tanzanite blue
[QUOTE=1911and340;23598778]
Not able to locate you man. I want to do this tire set up!
Nvrmind saw the previous post ahaha
      06-02-2019, 07:43 AM   #42
haasport
Drives: 2018 328xdt
245/40/ZR19 square
I would have gone wider but my wheels are 19x8 so I maxed them at 245.
I too really like the meaty look.
      06-19-2019, 09:32 PM   #43
Mkswoosh
Mkswoosh's Avatar
93
did you have to add some camber or spacers? i keep seeing mixed responses they rub and then they don't. planning on getting the same rear specs 9.5 et 40
      06-20-2019, 10:11 PM   #44
Rokoz
Rokoz's Avatar
Drives: 2016 f80 M3
-2 camber in the rear which is just about factory spec, and I think I have -.9 ish in the front as I can't adjust it.
The only time I rub is in reverse on a hill with the wheel fully locked. And even then it's not 100% of the time
