05-17-2016, 04:06 PM | #1 |
Rep 943
Drives: 2012 328i Modern Line
How to adjust hood opening?
Does anyone have a pdf/eBook copy of the F30 Bentley or even just a hard copy and can post the correct procedure for adjusting the front hood/bonnet for opening correctly with two pulls? I've searched and the closest thing to instructions is to unscrew both screws on either side of the hood, then screw them back in until they are hand tight.
There has to be a written procedure to do this correctly.
:wave:
05-17-2016, 10:13 PM | #2 |
Rep 245
I'd like to know also. Mine takes several pulls to release properly. I do know that you pull down the plastic pieces so that the "hooks" (rectangles) can be rotated. I played with a few adjustments in both directions, but could not get a consistent 2-pull release.
05-18-2016, 01:18 PM | #3 | ||
Rep 3,947
05-18-2016, 01:28 PM | #4 | |||
Rep 943
:wave:
05-18-2016, 01:30 PM | #5 |
Rep 3,947
I would imagine that's the contact point between the hood and the parts that it may rest on. You will probably see those for the trunk as well.
05-18-2016, 01:40 PM | #6 | |
Rep 943
:wave:
05-18-2016, 02:01 PM | #7 | |
Rep 1,232
05-18-2016, 06:00 PM | #8 |
Rep 943
Damn, now much hood un-latches with two pulls but the drivers side sits lower than passenger side when hood is closed. I've tried adjusting the stops on either side but I cannot get it lined up.
:wave:
11-17-2021, 10:03 PM | #9 | |
Rep 5
John McDougald
