07-09-2015, 01:11 AM | #1 |
Rep 308
swirl on plastic
i noticed that there's a ton of swirl marks on the black B-pillar plastic piece.
Would scratch X from Meguiars or m105(?) from meguiars work?
F30 328i sedan
07-09-2015, 03:40 AM | #2 |
Rep 109
If you have a machine polisher use the scratch x on a buffing pad and it will work great. Scratch x does work decently, If you have really deep scratches you may need to use a compound first and then scratch x after to remove the swirls from the compound. Then preferably swirl remover to get it perfect. But yes should work fine. Good luck. Let me know if you need any more tips or help.
07-09-2015, 04:04 AM | #3 | |
Rep 308
I was kind of doubting on Scratch X on black color because it gave me hologram on black paint. Not sure if black plastic would appear hologram.. I'll just try it anyways
F30 328i sedan
07-09-2015, 02:06 PM | #4 |
Rep 5,056
The gloss black on the B pillar is very soft and prone to swirls. Scratch X is probably too abrasive. You should probably have a pro so it with a machine polisher and a less abrasive compound.
07-10-2015, 04:58 AM | #5 |
Rep 268
Use a very light polish as suggested above. I have some light polish, but I used Meguiars Tech Wax on the B pillar while waxing the car and the swirls came out. It has been a few months and no signs of swirls on the B pillar.
07-13-2015, 02:36 PM | #9 |
Rep 4,981
Once you get the swirls/scratches out, consider some Xpel film.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
08-09-2015, 09:54 AM | #11 |
Rep 5,316
Drives: G80 M3 6MT
Menzerna SF4500, those pillars are very gentle.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-09-2015, 11:22 AM | #12 |
Rep 1,035
The swirls come back almost as fast as you take them out .
I had the same issue, and used 105/205 with pretty good results. Have some pics from an old post ... http://f30.bimmerpost.com/forums/sho....php?t=1051724 |
