05-08-2017, 06:40 PM | #1 |
Rep 33
F30 Halogen to Xenon non adaptive
Hello Guys, I need some help with the head lights. I found some post about retrofit the headlights from halogen to Adaptive Xenon, is it the same way to do it for non adaptive? I mean the after market headlights I bought look great, but when I connected them nothing worked. so I realized the wiring had to be re-done on the plugs that go to the headlights. I got that figured out, now I get my turn signals, low beam and parking light work but my high beam and Halo lights do not work for some reason. do i need to do coding for that? is the link of the lights that I have.
05-08-2017, 07:20 PM | #2 |
Rep 33
I also do think that I could have bought defected headlights. I should be getting a new set tomorrow. ill give it a try with new ones. but if it will do the same.. most likely i need to do some coding?
05-09-2017, 10:58 AM | #3 |
Rep 33
Final Question. Do I need to code my headlights if I do not want adaptive options. all I want is High beam, Low Beam, turn signals, Halo lights and Parking lights.
05-10-2017, 12:41 PM | #4 | |
Rep 8,364
Xenons do have any option code = 522. |
05-31-2017, 02:06 PM | #5 |
Rep 33
well guys, im in the same boat again, I returned my after market headlights and purchased used OEM headlights. I have a problem with High beam and Halo lights now.
my Halo lights do not turn on at all, and my high beam is same as in the video. the shutter works but the second lens does not have light in there. what can I do to fix the high beam and Halo lights. |
06-03-2017, 02:58 PM | #6 | |
Rep 159
About the halos, you have installed the led modules (two for each housing), right? If yes, they might need coding I'm not sure. But if I have to quess, I would say that because the halos works as DRL as well as parking lights, they need coding because halogens has dedicated bulbs for parking and DRL light. |
06-04-2017, 01:01 PM | #7 |
Rep 33
thank you for the info, some one in the other post say exactly same thing about high beam. i feel dumb. do you know if control module is bad will halos stop working? I have the control modules and the voltage I get in Halos is only 3volts not enough power to power on the LEDs
07-17-2017, 03:42 PM | #8 |
Rep 33
Just wanted to let everyone know that the issue was resolved by buying new headlights that came with new LED modules and control Modules. it worked right out of the box. I tried to swap the control modules and the headlights stopped working so the problem was in both control modules.
im glad that the issue is now resolved. thank you all for all the help and info that was given. |
Tags |
f30, halogen to xenon, headlights |
