BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > M Performance Brakes
      04-24-2024, 10:41 AM   #23
viktorhanacek
viktorhanacek's Avatar
Czech_Republic
73
Drives: X6M
[QUOTE=obzen;30430371]
Originally Posted by jyerelek View Post
Did you ever install these parts? And did they help?
I returned them as soon as I got it. It made no sense how that would help so no. Just been living with the ticks ever since. Summer is almost over here so prob won’t be doing window down drives in couple months.
But they DO work. I had them on my X6M F86. BMW were later giving these to some models right during production. Now I have H&R 15+20 spacers (so I don't use these "1mm spacers" anymore).
I'm not sure, but I remember in 1addicts forum someone solved it by using two threads shorter screws
EDIT: The wheel moves on the hub, unfortunately, so it is necessary to regularly tighten, check and tighten to at least 140 Nm. I was sending it hard on circuit and my left front wheel almost fell off on the track because all the screws loosen.
      04-26-2024, 08:11 PM   #24
lllRazorlll
lllRazorlll's Avatar
Drives: 2014 435i
Keep in mind that even though you have the upgraded blue calipers, you won't be able to fit M3/4 rotors on a non-M because the knuckles are different
