08-22-2017, 03:28 PM | #177 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
08-22-2017, 03:28 PM | #178 | |
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
Map 1 - 3 are horrible for me with MPPSK and the gas we have here... I have to use Map 5 and define custom settings to gain performance without sacrificing drivability.
Whats your IGN1 look like? What does it peak at at 5500 rpms? Quote:
08-22-2017, 07:36 PM | #179 | |
Rep 521
08-23-2017, 07:40 AM | #180 | |
Rep 484
I have read mixed opinions on long term use.. Fouling of plugs, etc. and why E85 is best.. but some dont see any issues. I suspect the type of plugs, afr, etc. have something to play in that..
Here in NY 10% ethanol... 2 gallons into 3 / 4 series takes you to E20 which isnt an issue for our motors... however what varies are your bolt ons, altitude, etc. which all have an effect on AFR - E85 introduces fuel pressure challenges because of this on the b58.. but thats for another discussion.. Quote:
08-23-2017, 07:59 AM | #181 |
Rep 248
I just remembered the first thing we did before actually removing the tuner was turn off the tune and it still brought the cel back. I think its a defective unit haha.
08-23-2017, 08:58 AM | #182 |
Rep 484
Clearly only an idiot would look for reasons other than the unit if turning it on or off caused a CEL.... Just saying.... ha ha ha
08-23-2017, 09:20 AM | #183 | |
Rep 248
In essence its not the "tune" as you think it is. It's the actual unit or wiring bundle. |
08-23-2017, 09:28 AM | #184 | |
Rep 484
LOL - I guess that was pretty important piece of information.. Kind of negates the whole octane discussion - albeit relevant nonetheless in general outside of obvious issues.
Yea - I guess it takes genius to figure it out its either the unit or the install - why even bother posting it ? Quote:
08-23-2017, 09:37 AM | #185 | |
Rep 248
08-23-2017, 09:46 AM | #186 | |
Rep 484
It shouldnt be a discussion - if the CEL comes on with the unit installed but disabled - its either the installation OR the unit. If you had a professional install / re-install and ruled out the connecting of two wires, then it should be a closed matter.
If you purchased through a credit card, put in a dispute if your not getting anywhere with Dinan... I would let them know thats your next recourse. Quote:
08-23-2017, 09:56 AM | #187 | |
Rep 248
But we will see. |
08-23-2017, 10:04 AM | #188 | |
Rep 484
So you remove the unit completely and no CEL - car drives fine
Unit installed, enabled or disabled you get a CEL - car does not drive normal Is this what your saying? And your blaming the car? Quote:
08-24-2017, 02:55 AM | #189 | ||
Rep 703
08-24-2017, 10:10 AM | #190 | |
Rep 484
V8 hugely improved drivability... night and day sifference on all maps.. so my statement is relative (in other words Maps 1-3 are not bad on 8 just not as good as Map 6 with the fuel quality im running)
09-04-2017, 12:48 PM | #191 |
Rep 15
Dinan says 426 HP and 463 lb-ft??????? 0-60????
Has anyone installed this tune with their 340i/440i xDrive MPPSK? I want to know if it really makes 426 HP and 463 lb-ft as advertised by Dinan.
Also, how much will this tune bring down the 0-60 time for an xDrive model? |
09-04-2017, 04:38 PM | #192 | |
Rep 1,011
i did a baseline and post in this thread on my 340xi MPPSK with the dinan elite piggyback and yielded a negative delta unfortunately. driveability wasn't great either. kind of like it was blatantly obvious the ECU was being lied to and the car didn't like it haha |
09-05-2017, 12:07 PM | #193 |
Rep 141
So very interesting. I had a similar experience as Monkiboy. MPPSK with Dinan stacked on top. With the Dinan the car ran rough, it was inconsistent and even inconsistent within single gear pulls. It had a bit of a mind of it's own and I was really quite disapointed.
The only day, the car ran REALLY rough, and I had the CEL come on a couple of times. I dropped it off to my dealer, apparently a spark plug had broken?! The point of the story is that BMW told them to replace all of the spark plugs and INJECTORS. My dealer questioned the injectors and BMW said "if they are made it Turkey, replace them". The car runs SOOO much smoother now, it's finally running how it should. Sounds like BMW knows there is a problem with the injectors that are manufactured in Turkey. '17 BMW 340i xDrive M Performance Edition |
09-05-2017, 01:12 PM | #194 | |
Rep 484
At least running a JB4 - Map 1 doesnt run the smoothest (mildest map) - and that depends on the day, the moon orientation, gravitational pull, etc. LOL
But all honesty its probably due to poor quality gas. Running Map 6 I can control the amount of additive boost making even less aggressive then map 1. Just not enough good quality fuel to get more then 3psi below 4k and 2psi above 4k with the MPPSK... - pretty evident with little to no timing advance. I do admit though the MPPSK by itself hits 16 psi - which is like map2 on the JB4... i hit 17 psi regularly with the JB4 - but then timing is low... so your trading off... Quote:
09-05-2017, 01:36 PM | #195 | |
Rep 248
In other news, I had the dealer reinstall the tuner and so far it hasn't caused any issues. Time will tell. |
09-05-2017, 02:19 PM | #196 | |
Rep 484
Vendors Plan on issues - deflect and scatter
All credibility was lost when verifying the install was skipped.. Octane is king when adding boost. If they told you octane/fuel quality cant cause drivability issues you're being naive at this point. An idiot can install these things - so I dont know how they could have gotten it wrong... But if its not the device, not the install, not the fuel, yet runs fine without the device.... Must be the car! Quote:
monkiboy534.50 |
09-19-2017, 01:52 PM | #197 |
Rep 1
I had my Dinan Elite for Mppsk installed last week. Location Europe, Finland, gasoline shell v-power, car Bmw 340i GT xdrive 2017. First I waited for the MPPSK for 6 months, and now, a month later Dinan. Not dynoed but tried some accelerations before and after with gps, always starting from the same spot (slight downhill). Results(2 attempts/setup):
100-160 km/h original: 5,9sek and 6,0sek 100-160 km/h MPPSK: 5,4 sek and 5,5 sek 100-160 km/h MPPSK: 4,4 sek and 4,7 sek + Dinan Elite No cel, no other problems eighter. The gearchanges are different, not as smooth when pedal to the metal but I would not say they are bad. So far, after 500km, I am quite pleased. |
ckrieg49.00 |
10-01-2017, 08:55 PM | #198 |
Rep 109
Dinan Elite and Exhaust
Long time reader, first time poster. The decision to install the Dinanatronics was simple, I wanted to retain the warranty or at least have coverage under Dinan. I do not plan on tracking my car or doing any tuning beyond this. Secondly, I didn’t want to have to remove the piggyback during normal dealer service. In addition to the Dinantronics, I installed the Dinan cat back exhaust and BMS intake. Here are my thoughts.
Dinantronics: From day one, the drivability had been fantastic, very smooth and feels OEM. Power wise, it was not a huge improvement, the difference is mostly felt between 3500 – 5000. Before or after, it almost feels stock. Although I am happy with power gains, I wish it had a bit more. I am not sure if I have already gotten used to the additional power but sometime I don’t feel the extra power. In the next few months, I plan to do a dyno to see the actuals. The Dinan app is not working and never worked. I called dinan and left a message but never got a response. I will keep trying or take it back to the local approved shop to see if they get a better response. BMS intake: Its ok, not the best since I need to take it out before taking the car into service. The noise it makes is Honda-ish. Since it has no heat shield and all it does is suck in a lot of hot air, performance gains must be negligible. I am on the fence if I keep it, most likely once I take it out for service I will replace it with a K&N drop. Currently Dinan has no intake and I do not know if at this point they will come out with one. Dinan cat back exhaust: This completely changes the car for the better. In my opinion, it is better than any M3/M4 with regardless of exhaust. Its laud at startup but not obnoxious and it quiets up in no time. The sweat spot is between 2k – 4.5k, beyond that, the engine and wind noise overpowers the exhaust. On the negative side, I wish it had a valve, we you are cruising between 2-2.5k you can hear a little drone and it bothers me. The price is also hefty; I think $1k would be more reasonable. I tried taking a video but the iPhone microphone does not do it justice. Upcoming mods: Dinan spring and from there enjoy the car and save money to get the M3. Last edited by MarcosLepre; 10-01-2017 at 09:07 PM.. Reason: add pictures |
