05-08-2018, 01:48 PM | #133 | |
¯\_(ツ)_/¯
945
Rep 1,762
- Injen muffler - Injen intake - ER charge pipe intercooler to intake manifold
Glaciersilvermd30.00 XAoPiLLz9.00 |
05-08-2018, 03:36 PM | #134 |
Rep 2,382
Don't be surprised if you don't get it either. I rarely get mine while stopped anymore. I think when I first installed (when the video was taken), spring was still nice and new, so I got it without being under load. Now that she's more broken in, I can get it to come out while under load.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
05-08-2018, 03:37 PM | #135 |
Rep 2,382
Ah, that makes sense. I'm hoping someone with just an upgraded FMIC and no tune (or vice versa) who installed the DV+ can test this.
05-08-2018, 05:02 PM | #136 | |
Rep 307
05-08-2018, 05:18 PM | #137 |
Rep 2,382
Oh, I know. That's why I said typically it's brought on by a bigger turbo and/or an upgraded FMIC. I'm also curious to see if having it tuned (let's say on guys who have stock turbo and IC) can bring it on by controlling the solenoid.
05-08-2018, 07:57 PM | #138 |
Rep 307
We may find out soon. That will likely be me after I find time to install this.
05-08-2018, 09:11 PM | #139 |
¯\_(ツ)_/¯
945
Rep 1,762
I'll be getting a bigger FMIC within 3/4 months so I'll see how it is then.
05-09-2018, 08:26 AM | #140 |
Rep 5,457
Drives: F30
I have an upgraded FMIC and no tune. Not hearing a lot, if any flutter. Have not had a chance to stand at engine bay and listen while someone else manipulates throttle (yet). Either way, it's pretty quiet and unnoticeable.
05-09-2018, 08:51 AM | #141 | |
Rep 2,382
If you don't get it, I'd assume the tune at that point?
05-09-2018, 12:41 PM | #143 |
Rep 2,382
Definitely not. Either one is fine, but I am curious has to what brings it on with these cars. Part of me wants to say it's the tune since a stock DME is going to want to vent all boost anyway. So you probably could get it with just tune+DV+ on this car.
05-09-2018, 03:05 PM | #144 |
Rep 307
Doesn’t the spring halfway override that since it keeps more tension on the piston to keep it closed? At least on the stock tune.
05-09-2018, 06:53 PM | #145 |
Rep 2,382
It stiffens it but I'm not sure if the car can just override that completely. It makes it tougher to open for sure. Hmm. Let me get the correct answer for that.
05-09-2018, 11:51 PM | #146 |
Rep 307
I’m thinking it sends a voltage range on how much to open the DV. If it sends a certain signal to open it, let’s say 70% but the spring is stiffer, it may only open it 55%. I’m not sure though. Since it’s electronic, it’s very different from a standard bov that works off springs and vacuum.
05-10-2018, 09:34 AM | #147 | |
Rep 2,382
05-10-2018, 04:43 PM | #148 |
Rep 41
Got mine installed now...no flutter at all...i can definitely tell the difference though. the car continuously keeps pulling through the shifts. Graphs are showing minimal boost loss during shifts. But im running bm3 with stage 2 93 agg tune, ER CP/TiC/catless DP, VSFR 7" stepped intercooler, GFB DV+(now), JB4 stage 2 running map 3 for meth control, BMS Meth kit.
Still need to get exhaust on there and then ill be happy for now. I am very much pleased with the feel of the car now with the GFB DV+ in there. oh and a side note...on the 2016 model the original DV is held on by 3 - T-30 screws instead of the hex/allen heads. It was never mentioned before but the bolts that hold the EWG on were also T-40, didnt know if it had hex/allen on older models of the f30.
16 Mineral Grey F30: Injen CAI | ER CP/TiC/Catless DP | VSRF 7" Intercooler | NGK LI Plugs | BM3 running PTF stage 2 93 AGG Tune | BMS Methanol Kit | GFB DV+ | AWE Quad Exhaust Suite | Dinan Sport Springs | 19" MRR GF9 with 225 front and 255 rear | M4 CF Spoiler | VividScreen 8.8" |
05-10-2018, 04:52 PM | #149 | |
Rep 2,382
05-11-2018, 01:51 PM | #150 |
Rep 41
i tried different variations of gears and throttle at low rpms last night on my way home and on the way to work this morning. Still absolutely no flutter.
BunkerJ1032.00 |
05-21-2018, 10:23 AM | #151 |
Rep 41
so finally got it to flutter. i found 20-25mph in 3rd gear and i have to smash the gas and lift off immediately before the cars starts to speed up at all. Just enough to start a good spool and let off the throttle before it starts to surge quickly. But thats the only time i can get it to flutter and its just a low level flutter.
05-22-2018, 01:06 PM | #152 | |
Rep 2,382
05-22-2018, 06:17 PM | #153 |
Rep 41
and i have to have the windows down and music completely down...its very faint from inside the car....but if i do it every once in a while when im in the neighborhood it gets most people to turn and look...lol
05-23-2018, 12:13 PM | #154 |
Rep 2,382
Yeah, same. I typically can hear it in the parking lots between buildings or the canyons.
