05-08-2023, 05:54 AM | #1 |
Rep 72
lower control arms...
So these lower control arm bushings can leak! One side down. The hardest part was removing the little clip for the headlight leveling without destroying it.
Did the the lower middle arms too, while apart. Just stick replacements, and new axle bolt so all is tidy. -PJ |
05-10-2023, 09:17 AM | #2 | |
Rep 266
Been wondering if mine are going since I hear a slight clunk sometimes when I reverse and have wheel turned. Also the car has been pulling left and right on uneven roads. |
05-12-2023, 08:37 AM | #3 |
Rep 72
No. I purchased new front and lower arms and axle bolts through fcp auto.
Easy in, easy out. Passenger side took about an hour since I knew what I was doing and no headlight sensor. Now just an alignment. Interestingly, passenger side bushing was dry rotted and severely cracked but not leaking. My clink was fixed when the above driver side leaker was fixed. All 4 ball joints were solid but for the cost it was easy to replace all 4 arms and call it a day. |
05-12-2023, 09:18 AM | #4 | |
Rep 266
05-13-2023, 06:30 AM | #5 |
Rep 72
See my first picture. Get a flashlight and on the inner side (car side) of the long c shaped control arm, the arm itself will have black fluid around the big car side bushing. You might need to remove a few 8mm screws on the splash pan to pull it down to check.
On very low speed bumps, coming in and out of my driveway, I was getting a clicking or clunking noise from the front end. For me it was only 1 bad bushing and after replacing, the entire front end tightened up |
05-16-2023, 12:03 PM | #6 |
Rep 467
In my personal experience, I always start with checking the stabilizer bar end links first and only then move onto the control arms if there are no visible leaks around the control arms' bushings.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
05-22-2023, 02:31 AM | #7 | |
Rep 67
I need an alignment, scheduled this week. Last edited by Markoff Chaney; 05-22-2023 at 02:45 AM.. |
05-22-2023, 02:48 PM | #8 |
Rep 72
Hey, what hardware did u replace with the bilsteins? That will likely be the next item on my list but wasn’t sure what should be replaced with the dampers. There are various kits around. Thanks
05-24-2023, 01:38 AM | #9 |
Rep 67
The biggest deal with doing the struts and shocks/adaptive dampers was getting the right tools on top of the appropriate harware. There are a few good youtube tutorials combined with the Bentley Manual, you kind of get a good gauge on what you will need for the entire job.
You will need the Schwaben pass through sockets ranging from 18-24 https://www.ecstuning.com/b-schwaben...e/003046schkt/ I highly reccommend some tutorials online, you will struggle getting the front strut out and back in doing the method that is non BMW laid out by this guy He lays out all the torque specs etc, kinda misses or glosses over a few choke points, but overall is a good explainer. The pass throughs and counterholds are necessary. |
05-24-2023, 01:41 AM | #10 |
Rep 67
Main hardware you replace with the dampers are bolts and nuts that should come with your new set. The main issue is torquing to spec, and if a bolt or nut doesn't come with your "OEM" parts kit, you will have to dig that up on your own using the usual OEM online parts catalog. The hardest part was spreading the old strut with the right tool, and then clamping that same one back down after.
If you have adaptive dampers THERE IS A SENSOR ON THE FRONTS THAT WILL NEED TO BE SWAPPED OVER, EACH SIDE. It has a little QPC code looking thing on the side that faces the business end and will come off the old dampers when you replace. That is a 200$ sensor, don't fuck it up! |
05-24-2023, 11:33 AM | #11 |
Rep 467
Just FYI, the non-BMW method worked just fine for me a week ago on my XDrive/EDC fronts when I've replaced stock springs with Eibach XDrive lowering springs on my driveway. Absolutely no need to release the axle bolt.
05-25-2023, 03:09 PM | #12 |
Rep 72
Thanks!
I hadn’t reviewed the method but I’m comfortable with what I have seen. I have the “auto parts store” spring compressors and they have worked fine for me in the past. Non-BMW method will be what I use. Likely the B6 with stock springs for me. Daughter will take over the GT some day and a bit of ground clearance isn’t a bad thing for snow, steep drives, curbs (ouch), etc. |
05-29-2023, 08:19 AM | #13 |
Rep 467
That's the reason why I went with XDrive springs (front only) and not RWD springs (still light reverse rake present with stock OEM rear springs). - The car would become too low at the front for winter driving with drop springs intended for RWD cars.
05-30-2023, 12:42 AM | #14 | |
Rep 67
A 180$ alignment became a 770$ job because I was getting the alignment done the day before driving from Denver CO to Carlsbad NM, and I am very happy I found a decent trustworthy indie shop that takes good care of DIY bimmer idiots like myself. He sent the pics of the leaky boot and I had to get to NM next day or there would be a very unhappy Wife. You can see the Meyle HD thrust arm, and the shiny new B6s, splattered with axle grease.. Last edited by Markoff Chaney; 05-30-2023 at 12:59 AM.. |
