06-07-2023, 08:30 AM | #1 |
Rep 5,392
F34 Final Drive Ratio?
Anyone have any insight as to the rear final drive ratio on an F34 2015 320i GT RWD with a manual transmission?
Realoem appears to list two rear differential options with the manual transmission: (see photo) The first they are calling an exchange. 1) 33107599470, 3.23 Final Drive Ratio 2) 33107603750, 3.91 Final Drive Ratio Not sure if a visual inspection of the stock rear differential on the car would help. Anyone know if a BMW part number can be found on the rear differential and its possible location? |
06-07-2023, 08:46 AM | #2 |
Rep 467
Use VIN number on Real OEM if you can't crawl under the car to get the P/No off the rear differential.
I can see a sticker on the back wall of the differential case if I look diagonal from behind the left wheel.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 Last edited by Oksamit78; 06-07-2023 at 09:04 AM.. |
06-07-2023, 08:54 AM | #3 |
Rep 5,392
06-07-2023, 09:33 AM | #4 |
Rep 58
That first one, 3.23:1 ratio sounds closer to the six cylinders 3.08, which would lead me to believe that would be for a 4-cylinder diesel engine, not 4-cylinder gas engine. The 3.91 sounds like what a 4-cylinder gas engine would have.
Before assuming anything, though, you will need to find the tag on the differential, it should have the part number on it, or it could have a cryptic number like 34:11, which would equate to 3.09 (34 / 11). If that fails, you can always mark the bottom of the tire and the bottom of the drive shaft and count how many times the drive shaft spins around when you spin the wheel once. If you count that the driveshaft spins 3 and 1/4 times around that would be about 3.23 ratio, 3 and 9/10 or almost 4 turns would be 3.91. If you cannot see the tag on the rear, if you have xDrive, you can check the front diff, as both diffs should have the same axle ratio.
(OO=00=OO)
Current: 15 335i GT Past: Tons of E30s! Wants: E31 850i 6-speed |
06-07-2023, 09:39 AM | #5 | |
Rep 5,392
06-07-2023, 10:32 AM | #6 | |
Rep 467
Like you said, I'd expect 3.91 be the one for 320i RWD Manual. FYI: My 2017 XDrive GT with B58 (6 cylinder) has 2.93 front and rear.
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
Ragnar The Redneck42.00 |
06-07-2023, 11:01 AM | #7 | |
Rep 58
The B58 has a 2.93? Must have more torque available at a lower RPM than the N55 (what I have), as it has a 3.08.
(OO=00=OO)
Oksamit78271.50 |
06-08-2023, 09:09 AM | #8 |
Rep 5,392
POST UPDATE: The owner of the car was able to get under it and found a label on the top of the rear differential that indicated that it has a 3.23 final drive ratio.
Ragnar The Redneck42.00 Oksamit78271.50 |
06-08-2023, 10:11 AM | #9 |
Rep 58
Thanks for the update! I will need to update my info about how BMW installs FDRs. This would also seem to indicate that the turbo-4 gas engines are a bit better than I realized.
(OO=00=OO)
johnung4528.00 |
