BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Dynamic Braking Lights-
      06-20-2015, 10:54 PM   #45
ATLBlue
Car OCD
ATLBlue's Avatar
Drives: 2017 EBII F36 430d M Sport
Originally Posted by snowghost View Post
Unless you code your car. I unlocked this feature and it works great.
Correct. Did it too. Here's my car followed by a friend at the track. The flashing comes with hard braking even if the ABS is not involved:
2017 BMW F36 430D M Sport Estoril Blue, 2002 E46 M3 Imola Red & 2006 Porsche Cayman S Artic Silver
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL
      06-21-2015, 12:42 AM   #46
DC X3M40i
DC X3M40i's Avatar
663
Drives: 2023 X3 M40i
Dude that is awesome. I have his coded on my car but I would never know if it worked or not. Nice to see what it actually looks like.
      06-21-2015, 12:46 AM   #47
Golden Arrow
Golden Arrow's Avatar
Drives: F36 430i GC
The blinking brake lights are an euro-spec thing. We don't have it in the States.
2017 430i GC
2013 335i
2004 330ci
2003 330xi (Forever in my heart )
      09-11-2015, 11:00 AM   #48
BooGooBird
BooGooBird
BooGooBird's Avatar
Drives: 2012 BMW F30 335i
Is it possible to code dynamic brake light as outer brake lights blink instead of inner lights?
      09-11-2015, 12:49 PM   #49
crono06
crono06's Avatar
Drives: 2013 335i and 2018 X3
Yes, if I'm not mistaken, this can be done. I believe I've seen it discussed in the coding section before.
      09-11-2015, 02:51 PM   #50
BooGooBird
BooGooBird
BooGooBird's Avatar
Do you know what value would be to enable outer light blink?
Thanks!!
      09-11-2015, 04:43 PM   #51
RPM90
Drives: 340i M-sport AT
This feature would be great if it were implemented on ALL cars so that drivers could learn and get used to what the extra and flashing lights are for.
BMW doing this just on their cars doesn't do much good other than perhaps get some drivers attention who is behind a BMW...maybe.
The real advancement is using LED brake lights that light up to full brightness faster than standard incandescent bulbs. That fraction of a second to full bright advantage of LED brake lights has been demonstrated to catch drivers attention better.
Coming up to full brightness results in the driver behind the car actually responding a fraction quicker and that can help avoid certain accidents.
Judging from the testing LED brake lights should become a standard requirement in all cars, as a safety feature.
BMW's idea is a good one but needs universal application.
Having a standardized brake lighting set up could help all drivers better judge the braking of the car/s in front of them.
If there were 3 standard lights in every brake light, then the 1st light comes on with light braking like lightly tapping the brake in anticipation or adjusting speed.
The second light comes on during normal braking such as slowing for a light or stop sign.
The third light would come on during a heavy braking situation, calling attention to a potential emergency braking situation.
And there could even be a flashing brake light that would be directly stating,
"FULL BRAKE NOW!"
As it is now with most all cars the brake lights come full-on whether the driver is just one of those arbitrary brakers, who step on their brakes for no known reason, or for an emergency stop. I like the idea of graduated brake lighting combined with the speed to full brightness of LED's.
      09-11-2015, 05:22 PM   #52
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
I also have it coded on mine, sadly i was never been able to witness it...
      09-11-2015, 06:26 PM   #53
BooGooBird
BooGooBird
BooGooBird's Avatar
"FULL BRAKE NOW!"
I did replaced both blinker and brake light to LED bulb, and I bought them from Japan, they are one of brightest, called cree led, but even with that, I had people bumped into my tail, so when you have led bulbs replaced and if it is possible to code brake force display blink outer light instead of inner, it will be great, and I have seen couple video clips, people with F30 on the track, their outer light was blinking, not sure if it is in euro tho, but anyway, I think that can be done by coding, just not sure where to change the value.
      09-11-2015, 06:28 PM   #54
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Anyone know how to change the deceleration value required to trigger the dynamic lights?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      09-11-2015, 06:34 PM   #55
BooGooBird
BooGooBird
BooGooBird's Avatar
should be this one
http://www.bimmerfest.com/forums/sho...rbarer_ausgang
      09-11-2015, 06:34 PM   #56
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
I have a video of mine working.
      09-11-2015, 06:35 PM   #57
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I checked these, found none of them to be 100% accurate in the F30. Found a lot of ESS options to change, translated all of them, none of them turned out to be the deceleration rate on the F30.
      09-11-2015, 07:58 PM   #58
Adamr916
Adamr916's Avatar
Drives: 2014 328d
Honestly the best way I found out that mine were working was go down an empty, poorly lit parking lot at night and floor it, then slam on the brakes and pay attention to the 3rd brake light, it's faint, but of you're actually paying attention to the light, you'll see it flash.
      09-11-2015, 08:00 PM   #59
BooGooBird
BooGooBird
BooGooBird's Avatar
It flashes with that code, but only with inner light, the light attached with truck, what I was trying to do is to figure out how to make outer light blink too instead of just inner light.
      09-11-2015, 08:08 PM   #60
Adamr916
Adamr916's Avatar
Drives: 2014 328d
My outers flash if I remember right, I'm not real sure though
      09-11-2015, 08:46 PM   #61
BooGooBird
BooGooBird
BooGooBird's Avatar
Would you mind check it? I talked to a lot ppl w/ F30, none of them got outer brake light blink so far
      09-12-2015, 05:09 PM   #62
crono06
crono06's Avatar
Thanks!!
Sorry, I don't. I checked with the person who normally does my coding and he doesn't either
      09-15-2015, 09:14 AM   #63
Adamr916
Adamr916's Avatar
Drives: 2014 328d
Girlfriend confirmed that it is my inners that flash, not the outers. I figured since I have rear fogs enabled, that it would change to the outers.
      09-15-2015, 11:09 AM   #64
BooGooBird
BooGooBird
BooGooBird's Avatar
so you are saying if i have rear fog light enabled, then it will make the outer light blink when brake hard?
      09-15-2015, 02:30 PM   #65
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
Originally Posted by Tsuyoi View Post
Page 105 of US manual. During heavy brake application, the inner brake lamps light up in addition. So no blinking.
This can be coded from inner lights to flashing (I did).
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      09-15-2015, 02:34 PM   #66
BooGooBird
BooGooBird
BooGooBird's Avatar
How about outer light blinking?
